December 12th, 2016, 08:23 AM | #1 |
Adjusting AirFuel screw
EL250
Adjusting Air Fuel screw with idle screw both run at 1200+- Engine already Warm up Done Valve adjusting Running test/adjusting one at a time Carb one run adequately at settings 2 1/2 turn, set to 2 3/4 turn Carb two Problem to run smoothly at same idle screw setting (default at 2 1/2 turn) Need to increase throttle for engine to run What is possible cause..? Thanks in advances |
December 12th, 2016, 09:12 AM | #2 |
Blockage in idle mixture passages on carb #2 would be my guess.
Have you synced the carbs? I would try that and see what that shows you. If there is a problem it's going to take significant adjustments to get them close. At that point it's showing you they need to come off and be gone through. |
December 12th, 2016, 09:37 AM | #3 | |
December 12th, 2016, 11:10 AM | #4 | |
Float levels should also be checked, as well as removing and carefully cleaning all the jets and other passages. |
December 13th, 2016, 04:40 AM | #5 |
it seem my bike will have different vac pressure when throttling from idle position. possible butterfly valve leaking/gap or pilot jet or something else that i'm not so sure.
Done idling manometer check and settle for now. |
Adjusting clutch. | ZeroGravity360 | 2008 - 2012 Ninja 250R Tech Talk | 16 | May 21st, 2016 04:40 PM |
2008+ Ninja 250 Carburetor Screw size, allen screw size! | Runeknight95 | 2008 - 2012 Ninja 250R Tech Talk | 4 | March 2nd, 2015 11:49 AM |
Adjusting headlights? | uKER | 2013 - 2017 Ninja 300 Tech Talk | 2 | July 8th, 2013 07:50 PM |
Adjusting the Idle Mixture Screw | conrya5 | 2008 - 2012 Ninja 250R Tech Talk | 22 | March 18th, 2013 05:03 AM |
Help with adjusting the values | Ingersoll | 2008 - 2012 Ninja 250R Tech Talk | 2 | January 14th, 2010 08:08 AM |
