Old June 4th, 2012, 01:58 PM   #1
NHrider19
Snorkel removal questions
So I've been reading alot about removing the snorkel from the airbox and it seems like it is a good mod to do, my question is, do I have to have a jet kit to do this or is it something i can do and get away without using one, I have a stock exhaust for right now. I plan on getting a jet kit down the road. but for right now can i run without a snorkel without a jet kit.
NHrider19 is offline   Reply With Quote
Old June 4th, 2012, 02:37 PM   #2
mkulchar
mkulchar's Avatar
Motorcycle(s): 2010 250r ninja
im no wiz at jetting, but if you removin the snokle you should at least shim the neeedles cause you will be running very lean and could damage the engine.
mkulchar is offline   Reply With Quote
Old June 4th, 2012, 02:39 PM   #3
NHrider19
and I could do this simply by placing washers under the needles?
Old June 4th, 2012, 02:41 PM   #4
mkulchar
mkulchar's Avatar
yes, tho someone correct me if im wrong. I would use the search tool and look around to be sure, cuase there are hundreds of posts about shimming and exhaust stuff.
Cuase im no expert
Old June 4th, 2012, 02:53 PM   #5
xSean13
xSean13's Avatar
Motorcycle(s): 2010 Ninja 250r (sold) / '03 CBR 600RR
You may not need to shim at all. I shimmed with 2 washers when I installed my slip-on & removed the Clean Air System (got an assortment pack at Radioshack & just used the smallest ones that would fit). After i removed the snorkel, my bike was running rich, so I just removed one washer and it rides better, I haven't tested it back with 0 washers.
xSean13 is offline   Reply With Quote
Old June 4th, 2012, 03:12 PM   #6
NHrider19
Ok again cause im running with stock exhaust but was just wondering if i could get away without shimming if i just remove the snorkel
Old June 4th, 2012, 03:42 PM   #7
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
I tried the removing snorkel w/o shimming ..bike seem to run fine, but it was running a bit lean. Ended up just putting the snorkel back in.
In reality, removing it gives no extra bonus to do it without shimming!
Old June 4th, 2012, 03:48 PM   #8
NHrider19
So if I remove it, I should either jet it or shim it. correct?
Old June 4th, 2012, 03:50 PM   #9
EsrTek
EsrTek's Avatar
Removing snorkel w/ stock exhaust = shim
removing snorkel AND replace can w aftermarket = shim
removing snorkel AND replace full exhaust = jetkit
Old June 4th, 2012, 04:09 PM   #10
NHrider19
So Would i be able to run a jet kit if i just remove snorkel and install a slip on, or is it just shimming and a better choice since it is cheaper to do. or can u only run a jet kit with a full exhaust?
Old June 4th, 2012, 05:02 PM   #11
EsrTek
EsrTek's Avatar
You can do a full jetkit anytime.. just no real need for it, for anything less than a full exhaust change including header pipes.
Old June 6th, 2012, 09:05 AM   #12
edxmon
edxmon's Avatar
Motorcycle(s): '08 Ninja 250R (SOLD - 2/16/2013)
Got dam Sean, this is why you are my bro (aka guinea pig), even after putting the jisu on my bike it still feels and smells rich. When letting of the throttle the RPM dip way below 1500 and the exhaust stinks. I think I may have to remove a washer, OR add some super thing brass ones I "borrowed" from the ME lab of my University
Mods/Add-on list: DanMoto Jisu, Snorkel delete, Shimmed needles, K&N Drop-In filter, T-Rex frame sliders, Shogun swing-arm spools, CBR250 Rear Hugger, Buell XB Pegs. DIY polished rim lips
edxmon is offline   Reply With Quote
Snorkel Removal Driddle 2008 - 2012 Ninja 250R Tech Talk 9 July 18th, 2013 07:51 PM
Snorkel Removal on EFI Ninja 250R? hackeron 2008 - 2012 Ninja 250R Tech Talk 16 February 2nd, 2012 10:43 AM
snorkel removal 4x4kayak2112 1986 - 2007 Ninja 250R Tech Talk 14 March 9th, 2011 04:28 PM
Quick Question About Snorkel Removal LegB4Wicket 2008 - 2012 Ninja 250R Tech Talk 8 December 11th, 2010 10:49 AM
inconsistent throttle/rpm after shimming and snorkel removal Hokie11 2008 - 2012 Ninja 250R Tech Talk 3 July 23rd, 2009 03:17 PM
