Old September 5th, 2013, 03:28 PM   #1
dino74
dino74's Avatar
Using a 250R radiator in a 300
The mounting bolts line up. Left:300 Right:250
Main differences:
1: 250 thermo-sensor is on the radiator while the 300's by the thermostat.
2: 250 fan is there metal legged, 300 is four plastic legs.
But is mounts and seems to work fine.
CVMA #55
Old September 14th, 2013, 11:07 AM   #2
Old September 14th, 2013, 12:21 PM   #3
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Got a weight difference? Why'd ya do it?? Looks like you could shed some weight with a 250 fan on a 300 radiator
Old September 21st, 2013, 10:45 PM   #4
red26
Motorcycle(s): Ninja 250R, GSXR600 K4, KX250F,NSR150SP, Yamaha TZM150
I think you should put the shroud back on it as the one without shroud have the rubber thingy to disperse heat from the cylinder head.
This mods is a good solution for me since i had a Koso gauge in mine, so i had to control the temp signal to the ECU manually.
red26 is offline   Reply With Quote
Red Hot Glowing Radiator Supports/Radiator Top bluebr65 2008 - 2012 Ninja 250R Tech Talk 10 March 10th, 2012 10:05 AM
