May 18th, 2011, 10:05 PM | #1 |
Join Date: Apr 2010 Motorcycle(s): 09 Ninja 250 SE Lime Green/Diablo Black Posts: 126
Rear brake touching caliper; pedal issue?
Hey guys,
So I replaced my right rearset due to a crash, and it looks like it's installed correctly. However, the rear brake pads are touching the calipers. I can still push the bike back and forth, so it's not enough to lock the wheels. 1) Do I need to adjust the rear brake pedal position? 2) Do I need to rebleed the brakes? Another issue is that I have to really push on the brake pedal with my hand to have the brake light turn on. I attached the spring for that switch to the end of the spring that pulls the brake pedal back up. Is this correct? |
May 18th, 2011, 11:03 PM | #2 | |
May 19th, 2011, 02:21 AM | #3 |
I think you mean that the pads are touching the disc. I believe that some drag is normal.
The "caliper" is the enclosure containing the brake pads and pistons. You manual tells you how to adjust the brake light switch. |
May 19th, 2011, 04:33 AM | #4 |
Sounds like everything is right. Maybe a switch adjustment (what setasai said) should be all you need. But, mine seems to be this way when I try to press it with my hands, but my feet have no issue. So, no bleeding should be necessary. Make sure that you don't have to 'press down really far' for the brake to actually actuate, as this usually means their is air in the line and bleeding will be necessary (and braking will be spongy).
Rear Brake Caliper Help | blap6798 | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 2nd, 2012 07:25 PM |
For sale: 2003 ninja 250 rear brake pedal and rear shock | ReDnEcK | Motorcycle-related | 0 | October 6th, 2010 12:02 PM |
WTB: Rear Brake Pedal | ReDnEcK | Items Wanted | 6 | September 3rd, 2010 03:52 AM |
Rear brake caliper issue | sprale | 1986 - 2007 Ninja 250R Tech Talk | 6 | December 9th, 2008 02:44 PM |
