Old June 27th, 2012, 07:43 PM   #1
rdrgoB
Motorcycle(s): None
High revving ninja, kept at low rpms?
I guess this is somewhat of the same post I tried in another forum. I got my bike and joined a couple, but now can't decide where to stay. But besides being a little whorish as a result of getting my bike, I have some serious thoughts.
So I've been riding my little Ninja every hour I get after work and before nightfall and have gotten quite comfortable on it (mostly at speeds up to 35mph so far - I'm taking it slow). I am developing my riding style and I quite enjoy it, but have a few questions whether they are frowned upon. I've seen a lot of back and fourth on it elsewhere and wondered what this community thought.
I'm practicing mostly in residential neighborhoods so to keep the noise down I shift at around 5k rpm and let the bike cruise at around 4k rpm. I know this is below the peak power, but is there anything wrong, as in damaging, with this? We hear about the redline but what about the other side of the spectrum?
Side Note:
Also, I've gotten into the habit of downshifting to slow down a lot. I blip throttle and regulate the clutch to get smooth downshifts when I need to slow down. It helps me keep track of the gears and I feel like I have way more control over the bike - but I barely touch the break until I'm ready to stop. The bike is pretty old and I don't want to shorten the life of the clutch even more (I hear Ninja's can go for a long time well maintained, but most that I've seen around don't have 17k miles like mine). I realize regardless of whether this damages the clutch I should tap my brakes to warn the people behind me; I'm working on it.
rdrgoB is offline   Reply With Quote
Old June 27th, 2012, 07:57 PM   #2
PsHYk
PsHYk's Avatar
Motorcycle(s): 2012-250R
i dont see why it would be a bad thing to keep the rpms low...
maybe if youre in like 6th gear and going 20mph that might cause a little stress on the engine but im not sure...
PsHYk is offline   Reply With Quote
Old June 27th, 2012, 07:58 PM   #3
str8t six
never enough
str8t six's Avatar
Motorcycle(s): Blue 2010 ninja 250R
running low RPM's is fine.
but you should atleast put pressure on the brake so it will light up your taillight to warn other cars.
custom graphics, zero gravity DB
str8t six is offline   Reply With Quote
Old June 27th, 2012, 08:40 PM   #4
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Not a two stroke...so it shouldn't. But like you said...keep pressure on rear or front brake so that you're keeping others aware...and make sure you actually practice braking as well. Emergency braking too. Get like a plastic bottle...brake as fast as you can so you stop quickly, then place the bottle there...and try to stop before it. Measure the distance, and compare to others... there are better techniques out there though lol!
Old June 28th, 2012, 09:14 AM   #5
cbdallas
cbdallas's Avatar
Motorcycle(s): 2007 Ninja 650R
It's been said on other forums that riding around at low RPMs can cause carbon buildup on the exhaust valves, but I'm not sure how much truth there is to that since even at 6K, the valves are traveling quite fast.
Carbon buildup aside, just make sure you're not lugging the engine. If you're experiencing any 'bucking' or shaking during acceleration, kick down a gear, as this is very bad for the bottom end...worse, in fact than riding around at high rpms.
cbdallas is offline   Reply With Quote
Old June 29th, 2012, 09:25 AM   #6
250rr
250rr's Avatar
Motorcycle(s): Cheap Italian Suit. Otherwise known as Dew Kitty
I ride at low rpms regularly, with occasional forays above 8 to 10k to kick loose any potential carbon buildup. As someone who is relatively new on a bike I like the lower power in the lower rpm range. I feel like the bike won't get away from me if I make a throttle input mistake. I think when (if) I upgrade to a Street Triple I will use this method to get used to it!
250rr is offline   Reply With Quote
Old June 29th, 2012, 03:53 PM   #7
4k is about the minimum. below that and it starts to lug. as long as its not lugging you are fine.
Old June 29th, 2012, 03:59 PM   #8
ally99
Ninja chick
ally99's Avatar
Motorcycle(s): '13 Ninja 300
MOTM - Dec '13, Feb '15
Originally Posted by rdrgoB View Post
Side Note:
Keep in mind that brakes are much cheaper than engines, so you may want to consider using more brakes along with engine braking. Like you stated, people behind you need to see your brake light come on, so using your brakes to stop is a good thing.
Postwhores are COOL! ~Allyson
Old June 30th, 2012, 07:57 AM   #9
rdrgoB
Motorcycle(s): None
Thanks for the input guys. I'm working on using my brakes more, but I'm still doing some engine braking. It's way more fun
And since I'm getting more comfortable on the bike I'm starting to rev it higher. Riding a motorcycle alone is fun, but I'm learning the awesomeness of the Ninja!
Old June 30th, 2012, 08:24 AM   #10
oblivion007
"scandal!"
Motorcycle(s): 2011 250R(Crashed 2/26/2014), 09 ER6n
Glad to know you're learning, be aware I try and keep my bike above 5k rpms except on take off and stops or slows traffic. I hate the lugging feeling and didn't even know it was bad. Also the bike isn't that loud stock, ask a friend to stand by somewhere as you pass him/her with some medium high rpms and see what they think.
oblivion007 is offline   Reply With Quote
Old June 30th, 2012, 09:13 AM   #11
...........I'm practicing mostly in residential neighborhoods...........
Rodrigo,
You should educate yourself to always keep the proper gear, which will load the engine in the range of 6K to 10K, regardless the velocity of the bike (except when coming to a stop).
What you are doing is not incorrect; however, in order to survive street traffic, you will need to learn some skills beyond basic operation of the bike.
If you have not done so yet, I would recommend you to take the MSF (Motorcycle Safety Foundation) course.
Best!
Old July 3rd, 2012, 01:36 AM   #12
Domagoj
Don't scare the man. Screaming around the residental neighbourhood @9k rpm and doing 30 mph is just bad manners, and has nothing to do with your engine well being.
Keeping it between 4-6k is completely reasonable in normal city driving. Everything else is basically a waste of fuel, excess noise and heat production.
You do not need peek power to accelerate slightly better than an average car, or to move at 30 mph. And you do not need to ride agressively between traffic lights because it will not save time at all, it just increases the chances of something going wrong.
High rpm engines are NOT durable engines, whatever we may like to think. Ninjette with 20k miles has probably less than 800 engine work hours, probably in 2 years or more. Compare that to marine diesels, which do those hours every 2 months, and work at peak power almost all the time.
RPMs come back down slowly when revving... Followed by smoke lilgreenninji 1986 - 2007 Ninja 250R Tech Talk 2 May 23rd, 2012 06:22 PM
