November 13th, 2020, 08:25 AM | #1 |
Join Date: Jan 2020 Motorcycle(s): 08 Race Prepped ZX-10r, 09 Race Prepped Ninja 250 (300 motor). 74 Norton Commando 850 (Project) Posts: 54
Recommended Exhaust for 345cc.
Hi,
I would like to know if some of you have any recommandation on what exhaust to put wit a 345cc engine. I also ave an old 08 zx-10r stock header so I can "kindda" build one with it. Open to any suggestion. Thanks |
November 13th, 2020, 12:32 PM | #2 |
Seeing as how you have custom engine, there is no off-the-shelf exhaust that will be optimum. Best to build your own exhaust. Here's some reference material:
Performance Trends - Engine Analyser Pro - I use this for my turbo auto engines, you must be extremely precise with your measurements and inputs. Best to model factory engines first and make sure simulated dyno matches stock engine exactly. Then make modifications and upgrades https://www.centuryperformance.com/e...nd-length.html https://www.enginelabs.com/engine-te...gn-and-theory/ http://www.superstreetonline.com/how...om-made-header https://itstillruns.com/exhaust-head...n-8428151.html |
November 15th, 2020, 11:16 AM | #3 | |
I will check it out. |
Recommended Chain Slack | burnrich | 1986 - 2007 Ninja 250R Tech Talk | 18 | January 20th, 2014 02:22 PM |
Once more... recommended tire pressure | AlexCWO | 2008 - 2012 Ninja 250R Tech Talk | 6 | June 4th, 2013 11:36 AM |
recommended clip on and rearsets | lotus168 | 2008 - 2012 Ninja 250R Tech Talk | 24 | May 8th, 2011 10:28 PM |
Any modifications recommended? | Jsick7x | 2008 - 2012 Ninja 250R Farkles | 30 | March 22nd, 2011 02:17 PM |
Recommended by kkim. Hello! | TheGoodLyfe | New Members | 22 | May 19th, 2009 10:21 AM |
