Old December 16th, 2015, 05:30 PM   #1
[motorcycle.com] - Gentleman’s Hooligan Comparo: 2016 Kawasaki Z800 ABS vs. 2016 Suzu
Us MOrons enjoy the luxury of working from home offices, but imagine an alternate world where we actually had an office to go to everyday. Clearly, this scenario won’t be hard for many of you to imagine as it’s your reality. And if you’re also the type to take the long way home after clocking out, followed by a lengthier ride come the weekend, you’re the type of rider Kawasaki and Suzuki are reaching for with the Z800 ABS and GSX-S750 – unless you live in California. Neither bike is currently being offered for sale in the People’s Republic. Intended for the sportbike rider who may be more, ah, mature these days with things adults call, um, responsibilities, the two still offer middleweight performance without the supersport ergonomic commitment. They are also more affordable, at $7,999 for the Suzuki and $8,399 for the Kawi.
With the commuter/weekend warrior in mind, resident shark diving editor Tom Roderick and I set out to experience what life is like for the rest of you, incorporating freeway stints and city riding to mimic the daily grind, while playing in the local twisties to simulate your escape come the weekend.
Nine To Five
Once underway, the Zed emits just a touch more vibration than the Suzuki, especially at 6000 rpm, but both bikes are surprisingly smooth overall. The Kawasaki, and its 57cc displacement advantage (806cc vs. 749cc) makes more power (103.2 hp vs 98.6 hp), but from the saddle this advantage is barely noticeable when riding both bikes back-to-back. The Suzuki’s massive 70-pound weight advantage (436 lbs. vs. 506 lbs., ready-to-ride) gives it a better power-to-weight ratio (4.4 pounds per hp, vs. 4.9 pounds per hp for the Z) and nearly erases this power deficit.
Unsurprisingly, the Kawasaki’s displacement advantage gives it more power throughout the rev range. More disappointing is the Suzuki’s GSX-R-based engine not even cranking out 100 ponies in Gixxus guise.
Perched atop the Zed, the 800 rider has a commanding view of the road ahead, but it doesn’t take long before the board-like seat starts getting uncomfortable, bordering on painful – a major turnoff. Meanwhile, the Suzuki rider settles “into” the Gixxus, a trait common among Suzukis. At 5-foot, 11-inches, Tom notes a slightly more relaxed knee bend on the Suzuki compared to the Kawi, but the biggest difference between the two is the amount of padding in the Suzuki’s seat. “The Suzuki’s seat is the right combination of support and comfort,” Tom says.
Both motorcycles are well suited to the task of lane splitting; neither sets of mirrors extend too far out (both give decent view behind once you tuck your elbows in), and their minimal bodywork helps those with less spatial awareness to judge whether they can fit in a gap or not.
People treat you better when you wear nice clothes. No one at city hall even batted an eye towards us as we rolled by.
In The Hills
When it comes time to stretch the legs of our respective steeds, the Kawi’s power advantage is noticeable, but the Suzuki, and its considerable weight advantage, is never far behind. The Gix’s hiccup is a gearbox slightly less precise than the Zed’s, resulting in a false neutral here and there. I prefer the 750’s gauge cluster, which includes a gear-position indicator residing next to its analog tach, which is easy to read at a glance. However T-Rod favors the modern looking all-digital gauge cluster of the Z800, though it’s void of a GPI. “It looks like something built from this decade,” says Tom of the Kawi’s gauges, “unlike the the dated gauges of the Gixxus.”
When setting a quick pace on a curvy road, not much separates either bike. Ample leverage is provided by both sets of bars, but the Gixxus wins out by virtue of its lighter weight, making it less of a strain to pitch the bike from side to side. The Z800 can keep up, but its rider has to work just that little bit harder to hustle its 506 pounds around.
From city hall to the canyons, the Z800 and GSX-S750 can comfortably do both.
Preload adjustability is the only suspension adjustment on the Suzuki. It leans slightly toward commuter comfort but provides the firmness needed for spirited riding, despite bottoming too quickly over sharp bumps. The Kawi’s suspenders aren’t much better, both ends being adjustable for spring preload and rebound damping, but it feels firmer and better suited for quick riding. Both bikes will get unsettled, however, if trying to navigate rough patches of road while carrying decent lean angle. It’s here that the lower-spec suspension components of both bikes reveal their weakness. Tom sums up the suspenders on both bikes with one word: “sufficient,” but the Kawi gets the slightest of nods in the suspension category.
Neither bike comes equipped with radial brakes, but the Z800, and its petal discs, has a firmer lever and stronger initial bite, which we both prefer. In the Suzuki’s defense, it might be just a brake pad change away from being right there. However, the Kawi’s biggest advantage is its standard ABS, something the Gixxus lacks. The benefit isn’t so dramatic in ideal weather, but the peace of mind it provides when the morning dew blankets the roads (or any other time conditions are compromised) “negates the Suzuki’s lesser price tag,” says Tom.
Basic and simple, the GSX-S750 is a throwback to the Universal Japanese Motorcycle.
From a performance perspective, we both are amazed at how similar these two are. Both are Japanese inline-Fours with similar seating positions that sound virtually identical to each other. Going, stopping and turning proved very similar as well. Even fuel mileage is close; we averaged 40.4 mpg with the Kawi, 41.7 mpg the Suzuki. “If this were a blind taste test,” Tom says, “you’d be hard-pressed fingering which bike you had just ridden. They’re that similar.”
Best of Both Worlds
The decider, then, comes down to the details. The Suzuki wins on price and has a much comfier seat. But we both agree the Z800 is a better looking bike, and Tom, being the outspoken type that he is, takes it a step further.
“Sitting next to the tastefully constructed Kawasaki, the Gixxus oozes bargain-bin architecture, whereas Kawasaki should be commended for not only engineering a good-looking motorcycle but also for ingeniously disguising its bargain-bin bits and pieces. Just look at the exposed exhaust on the Suzuki, with its ugly O2 sensor and exhaust valve where everyone can see, compared to the Kawasaki’s nicely stylized exhaust that covers any inherent ugliness.”
Call us shallow, but we think the Z800 flat out is the better looking of the two. It could stand to go on a diet, though. Swap out the wooden board disguising itself as a seat and you have a very competent middleweight all-rounder.
What’s important to you? If comfort and the impact on your wallet is top priority, the Suzuki will get the job done. The Kawasaki is the better looking of the two and has ABS. Deal closed. All we’d do is comb the aftermarket for a better seat and call it a day. “Just go buy the Kawasaki,” says Tom. “You’ll be glad you did.”
2016 Kawasaki Z800+ Highs</p>
  • Good looks
  • ABS
  • Dyno chart winner
– Sighs</p>
  • She’s a porker
  • Uncomfortable seat
  • You can’t have it, California
2016 Suzuki GSX-750+ Highs</p>
  • Under 8 grand
  • Plush seat
  • Light makes right
– Sighs</p>
  • Could use toothier brake pads
  • Looks dated
Gentleman’s Hooligan Comparo ScorecardCategoryKawasaki Z800Suzuki GSX-S750Price95.3%100%Weight86.2%100%lb/hp89.8%100%lb/lb-ft91.2%100%Total Objective Scores90.6%100%Engine91.3%91.3%Transmission/Clutch83.8%80.0%Handling82.5%83.8%Brakes82.5%77.5%Suspension82.5%81.3%Technologi es76.3%67.5%Instruments80.0%80.0%Ergonomics/Comfort80.0%85.0%Quality, Fit & Finish87.5%80.0%Cool Factor88.8%75.0%Grin Factor80.0%80.0%Tom’s Subjective Scores85.6%80.2%Troy’s Subjective Scores82.1%81.9%Overall Score85.2%84.8%Gentleman’s Hooligan Comparo SpecificationsKawasaki Z800 ABSSuzuki GSX-S750MSRP$8,399.00$7,999.00Engine Engine4-stroke, liquid-cooled, 4-cylinder4-stroke, liquid-cooled, 4-cylinderDisplacement806cc749ccFuel SystemEFIEFIValve TrainDOHC, four valves per cylinderDOHC, four valves per cylinderHorsepower103.2 @ 10,100 rpm98.6 hp @ 10,000 rpmTorque58.1 lb-ft @ 7800 rpm54.9 lb-ft @ 8900lb/hp4.904.42lb/torque8.717.94Transmission6-Speed6-SpeedFinal DriveChainChainFront Suspension41mm inverted fork with rebound damping and spring preload adjustability. 4.7-in travel41mm inverted KYB telescopic fork, preload adjustableRear Suspensionmonoshock with rebound and spring preload adjustability. 5.4-in travelLink-type monoshock, 7-position preload adjustableFront BrakeDual 277mm petal-type rotors, 4-piston calipers, ABSDual 310mm discs, 2-piston calipersRear BrakeSingle 216mm petal-type rotor, single-piston caliper, ABSSingle 240mm disc, 1-piston caliperFront Tire120/70-17120/70-17Rear Tire180/55-17180/55-17Rake/Trail24.0º/3.9 in25.0º/4.1 inWheelbase56.9 in57.1 inWheelbase56.9 in57.1 inSeat Height32.8 in32.1 inMeasured Weight506 lbs436 lbsFuel Capacity4.5 gal4.6 galTested Fuel Economy40.4 mpg41.7 mpgAvailable ColorsMetallic Spark Black/Flat EbonyPearl Glacier WhiteWarranty12-month limited warranty12 month unlimited mileage limited warranty.Gentleman’s Hooligan Comparo: 2016 Kawasaki Z800 ABS vs. 2016 Suzuki GSX-S750 appeared first on Motorcycle.com.
Click here for full story...
[motorcycle.com] - 2016 Kawasaki Z800 ABS Video Review Ninjette Newsbot Motorcycling News 0 November 10th, 2015 06:52 PM
[motorcycle.com] - 2016 Kawasaki Z800 ABS First Ride Review Ninjette Newsbot Motorcycling News 0 October 30th, 2015 03:21 PM
[motorcycle-usa.com] - 2016 Kawasaki Z800 ABS First Look Ninjette Newsbot Motorcycling News 0 June 2nd, 2015 12:10 PM
[motorcyclistonline] - 2016 Kawasaki Z800 ABS | FIRST LOOK Ninjette Newsbot Motorcycling News 0 June 2nd, 2015 10:50 AM
[motorcycle.com] - 2016 Kawasaki Z800 ABS Preview Ninjette Newsbot Motorcycling News 0 June 2nd, 2015 06:50 AM
