August 15th, 2011, 03:40 PM | #1 |
james250ninjette.newbie
Join Date: Mar 2010 Motorcycle(s): 1986 ninja 250 Posts: 276
Bar ends
Anyone know what size phillips screw driver to use when getting the bar ends off dont want too stripp them
August 15th, 2011, 04:07 PM | #2 |
Join Date: Dec 2008 Motorcycle(s): 2008 250r(sold). 2013 Kymco Super8 150 Posts: 223
Not sure about the bar ends, but many screws on the Ninja's are really JIS and not Phillips heads. There are many threads that talk about the difference between the two standards as well as the difficulty of removing bar ends.
August 15th, 2011, 04:12 PM | #3 |
I hate driving...
Join Date: Jul 2010 Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12) Posts: A lot.
They are JIS but you can use a #3 phillips. You have to use a torch to heat up the bar end since they use red locktite on the screw.
09 ninja 2fiddy SE Driving slow things fast |
August 15th, 2011, 04:49 PM | #4 |
Definitely read the "similar threads" listed at the bottom of this page for some hints and tips with this. Things do not get easier if you do end up stripping them.
August 15th, 2011, 04:54 PM | #5 |
I would advise just using a 1/4 inch bit and drilling the head off the screw. then use vise grips and remove the screw if you still need to. saved me some cussing
August 15th, 2011, 05:10 PM | #6 |
Ridin Dirty
Join Date: Jun 2011 Motorcycle(s): 2011 white se 250r , 2008 zx6R Posts: 921
torch or drill, only way they are coming off..haha!
#1 |
August 15th, 2011, 05:12 PM | #7 |
Join Date: May 2011 Motorcycle(s): 2011 250R Black, 2005 ZX-6R Blue Posts: 623
My 2011 bar ends came off with #3 philips that I have that isn't pointy. It fit pretty snug. I used it with a ratchet, and they came out pretty easily. I was able to hold the ratchet against the bar end and used my other hand to use the leverage of the ratchet handle. I did not have to use heat.
August 15th, 2011, 05:15 PM | #8 |
Ridin Dirty
mine was quite the opposite..guess it depends who was squirting the thread locker that day..lol!
#1 |
October 22nd, 2011, 08:54 PM | #9 |
Join Date: Sep 2011 Motorcycle(s): 2011 150cc chinaman scooter Posts: 226
Stripped the hell out of my right side before I found my butane torch in my toolshed...Even with it stripped to hell, the heat made it a breeze to get it off! You have to get it pretty hot...I've read trying a soldering iron (this will not work)....definitely need a torch! (or drill)
bar ends.... | gkarats | 2008 - 2012 Ninja 250R Tech Talk | 9 | October 30th, 2013 05:26 AM |
Bar Ends | skilletmo | 2008 - 2012 Ninja 250R Tech Talk | 8 | March 8th, 2013 11:17 PM |
bar ends | skikman | 1986 - 2007 Ninja 250R Tech Talk | 8 | January 7th, 2013 06:15 AM |
!@#$!ing bar ends! Torch, impact screwdriver, breaker bar, etc ALL failed. :( | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 64 | September 13th, 2012 11:50 AM |
bar ends | james250ninja | 1986 - 2007 Ninja 250R Tech Talk | 13 | April 22nd, 2010 04:06 AM |
