Old February 25th, 2009, 12:34 PM   #1
MrTiddles
Motorcycle(s): 2008 250R
Underbody Lights Idea?
So, I have a few spare computer case lights which run off a 12v circuit. Any suggestions on where to start looking for a proper splicing point? Suggestions for maybe safety tips?
Thanks in advance.
MrTiddles is offline   Reply With Quote
Old February 25th, 2009, 07:25 PM   #2
Wade
Wade's Avatar
Motorcycle(s): Black 2009 Ninja 250
Hi-Tec did a write up here on his install http://www.newninja.com/index.php?PH...0&topic=1211.0
Hope this helps
Wade is offline   Reply With Quote
Old February 25th, 2009, 08:32 PM   #3
maxedpenny
Don't Be Evil!
maxedpenny's Avatar
Motorcycle(s): 08 250R
Be careful with computer lights. They normally get exactly 12v from your psu. The ninja electrical system can spike to higher voltages. I hooked up a bunch of EL wire in my car and it burned it out
maxedpenny is offline   Reply With Quote
Old February 26th, 2009, 04:36 AM   #4
empire00
empire00's Avatar
Motorcycle(s): 2009 250r SE, 2015 FJ-09
I have CCFL tubes from a computer on my bike i just ran them off the battery with a inline fuse and switch in the "trunk". last week i changed the switch out for a wireless keyfob switch like this one. http://www.svc.com/rm01.html
in theory you shouldn't have any problems with voltage sag/spike with most L.E.D. or CCFL type lights as long as you don't exceed ~10v low ~14v high. low voltage wont mess up the LEDs but it can cause a problem with CCFL ballast that will make them flicker.
I am a electrician but still YMMV
empire00 is offline   Reply With Quote
Old February 26th, 2009, 03:53 PM   #5
Viper-Byte
Viper-Byte's Avatar
Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE
I am considering putting a few LEDs into the fairings on my bike. The only problem is the lighting laws are really strict here, so I am not sure what to do.
Though if I do, I will probably just get computer LED lighting kits as they are really just LEDs, they are fine to be run on the bike. I have run then in my car with no issues.
Viper-Byte is offline   Reply With Quote
Old February 26th, 2009, 04:43 PM   #6
ninjabrewer
dirty old man
ninjabrewer's Avatar
Motorcycle(s): Blue '08 Ninja 250
Somebody did a DIY thread on the lights you are talking about, but I don't remember if it was on here or on "that other forum" Do a search and see if it was this one. I distinctly remember seeing it, because I remember saying "holy s&%*, I want that"
nb
Death tugs at my ear and says, "Live, I am coming." -Oliver Wendell Holmes, Sr., poet, novelist, essayist, and physician (1809-1894)
www.friendsofsanonofre.org
ninjabrewer is offline   Reply With Quote
Old February 27th, 2009, 01:50 AM   #7
MrTiddles
Thanks tons for the help guys, I really appreciate it. Once it warms up, I'll try to work this out and post up pics.
Old February 28th, 2009, 02:12 AM   #8
Wade
Wade's Avatar
http://www.youtube.com/watch?v=N0MBcKq7lIQ&eurl
Check that out too kinda instructional as well as cool.
Old February 28th, 2009, 04:15 PM   #9
Viper-Byte
Viper-Byte's Avatar
OK, I have found an LED lighting kit that has 2 blue LEDs I used for my PC, I am going to install them now on the forks pointing down and post back with the results.
Though the LED kit from XLS performance looks good: http://www.xlsperformance.com/bike_led_accent.htm only a little expensive at $90USD
Old March 1st, 2009, 02:55 AM   #10
Viper-Byte
Viper-Byte's Avatar
Well, I installed it and secured the LEDs with cellotape (I hadn't planned on keeping them on till I found out the regulations of them anyway.
But here is what I used:
The LEDs are in a casing that focuses the light to one position, like a torch, but it doesn't do very well as you will see below.
Them installed on the forks:
they are in a position where they are not going to hit anything and are off the suspension part of the fork, so will not impact the suspension.
The glow from the front, slightly to the left:
The view looking down from riders seat:
Something must be done about the amount of light that goes up to where the rider is, I don't know about you, but I cannot ride with lights like that in my eyes at night.
Old March 1st, 2009, 03:12 AM   #11
Wade
Wade's Avatar
It didnt look like the guy in my youtube video had that problem but i think his were further into the bike away from the front wheel more (deeper into the bike if that makes sence) Maby you could try that?
Old March 1st, 2009, 03:25 AM   #12
Viper-Byte
Viper-Byte's Avatar
Yeah, his look to be mounted right in the fairing.
I wanted to have a beam of light going over the front wheel and to the ground, hence why I put them on the forks in the position I did.
Old March 1st, 2009, 09:42 AM   #13
don't know about where you live, but here in Hawaii, any blue exterior lights are illegal.
Old March 1st, 2009, 04:03 PM   #14
Viper-Byte
Viper-Byte's Avatar
Kelly, I am going to find out the rules and regulations today for it from a person i the know, I don't think blue would go well with the green in any case. This was more of a test to see what it would look like.
The regulations I can find online say (under cosmetic lighting): http://www.landtransport.govt.nz/veh...ghts-right.htm
On a side note, I am currently running with illegal headlights (HIDs with ballasts and no change to the reflector housing)... LOL, I may want to have a look into that aswell...
Old March 1st, 2009, 09:00 PM   #15
ninjabrewer
dirty old man
THANK YOU,
I was thinking about doing that very thing......
It is any color or just blue?
nb
Old March 1st, 2009, 09:06 PM   #16
Just blue. A few years ago, there were people running around with blue lights pulling females over in deserted spots and assaulting them. Since then, any type of blue lights that is not on a police vehicle was made illegal. The police take this serious, for good reason.
There are other federal restrictions on lights as well. No red lights facing forward, no clear lights facing directly rearwards.
Old March 2nd, 2009, 08:25 AM   #17
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
it's a shame that people go and ruin things for the rest of us
Old March 5th, 2009, 01:46 AM   #18
Viper-Byte
Viper-Byte's Avatar
I am trying to figure out the best place to tap into the positive. What I want is to have the LED lights so they only come on when the low (and high beam) headlights are on, so tap into the low beam some where. I would prefer not to tap into the headlight supply if I can avoid it. So I was looking at the wiring in the service manual and I think the best place maybe to tap into the headlight relay. What do you guys think of that?
I guess it is also possible to tap into the low beam connector (that used to connect to the bulb before I installed the HIDs) in paralel (this is the least prefered method). This will give me the characteristics. Then have a fuse of its own to the circuit and also switch so I can turn it off manually and have the headlights still running and LEDs off.
I am going to have a chat to an auto electrician and see what they suggest. I think that is the best idea.
Incase you hadn't picked up, I am designing and making my own LED system
Electric start problem, lights, blinkers, and indicator lights work. claymaker 1986 - 2007 Ninja 250R Tech Talk 8 July 10th, 2012 07:04 PM
