April 23rd, 2009, 03:15 PM | #1 |
Blue Blue Blue
Join Date: Mar 2009 Motorcycle(s): 2008 Candy Plasma Blue Ninja 250R Posts: 97
Rear brake pressure
hey quick question to yall...about how hard do your rear brakes engage?...can you lock the rear tire using the brake?...ive been bleeding mine and i just cant seem to get it right...standing still, i can keep the bike from moving with just the rear brake...but when using it while moving, it doesnt seem as good.
April 23rd, 2009, 03:18 PM | #2 |
most likely you still have air in the line, m/c or caliper. you need to keep bleeding. were you getting any air bubbles at all when you stopped bleeding? how much fluid have you run through the system?
April 23rd, 2009, 03:22 PM | #3 |
Yeah you can lock the rear up. As Kelly suggested, keep bleeding keep keep bleeding.
April 23rd, 2009, 03:33 PM | #4 |
Matt, was the system completely emptied during the crash or just the reservoir? also, did you already fix the leaking washer problem?
April 23rd, 2009, 05:44 PM | #5 |
Blue Blue Blue
o...haha more fun times....i fixed the leak at the master cylinder.....but now i have a leak back near the caliper....i cant find where it is coming from...there is a slight dribble down the outside face of the calliper...i took off the hose there and cleaned off the washers and all that but when i hit the brakes i dont see it coming from there...but it is still dribbling down the front some how...i think i might jsut take the caliper off and look at it.
as for the crash...the resevior was completely empty...but i dont believe the system was emptied because when i first started bleeding fluid came out....so....gah!... |
April 23rd, 2009, 06:12 PM | #6 |
well, before you get any type of reliable braking action, you will need to fix all the leaks first.
Once you fix the leaks, bleeding the system till no air is in the system is next, but until you fix the leaks, you may not be building enough pressure to produce sufficient brake locking power plus you're most likely sucking air back into the system through the leak which in turn further diminishes your braking capabilities. First things first... fix the leaks. oh... and watch out. Brake fluid eats paint if left on there for any length of time. |
April 23rd, 2009, 07:47 PM | #7 |
Blue Blue Blue
haha yea...ive already seen some paint flecks coming off the tire.....might just have to polish them now haha
April 23rd, 2009, 08:19 PM | #8 |
black touch up paint works well, too.
April 26th, 2009, 04:55 PM | #9 |
Blue Blue Blue
fixed!...works great...engages real hard...everything is fixed now!...now time to do the jets...wooo..woo..ooo....haha
April 26th, 2009, 06:42 PM | #10 |
Join Date: Dec 2008 Motorcycle(s): '09 ninja 250 (blue) Posts: 295
Hahaha....funny. Great song too.
A woman is like a teabag; you never know how strong she is until she's in hot water! |
Lost brake pressure in the rear!! | yogurtpooh | 2008 - 2012 Ninja 250R Tech Talk | 11 | February 20th, 2015 12:52 AM |
Rear Brake Lever Travel is Excessive and Rear Brake won't Lock Tire. | N-m | 1986 - 2007 Ninja 250R Tech Talk | 14 | July 17th, 2014 04:13 AM |
08+ rear wheel, right rear set, rear brake system, seat | cuong-nutz | Items Wanted | 2 | October 6th, 2013 05:37 PM |
Rear Brake Doesn't activate Brake Light And DOT3/4 FRONT BRAKE OIL | coelgrim | 2008 - 2012 Ninja 250R Tech Talk | 16 | March 11th, 2013 05:10 PM |
Slowly increasing front brake pressure | smcbride11 | 2008 - 2012 Ninja 250R Tech Talk | 6 | April 6th, 2010 08:02 PM |
