Old May 19th, 2009, 09:08 PM   #1
tylerdurden119
tylerdurden119's Avatar
Motorcycle(s): BLACK 09 250r, burnt orange 09 zx 6r
two bros slip on
So I was just installing my slip on, and the replacement bushing doesn't fit on the inside. Outer one is fine but the inside one's outer diameter doesn't mesh up just quite with the inner diameter of the hanger. I got it partially in by threading the bolt and crankin er down. But it's not fully seated and its about as far as i can get it to go, hand cranking(don't want to break or fack anything up). So waht should I do, grind a bit off the bushing with a dremel, take it to a machine shop. The outer one has a bit of play in it so i can't see it being super important for it to be 'that' snug. I'm thinkin of just takin the dremel to it. I got it all mounted up anyways, seems solid. But I just had to get it on to hear it, definitely gonna straighten it out. Also there's a bit of a leak(ever so slight) where the slip on pipe meets the stock pipe. It says in the manual to use soem sort of 'high temperature silicon' any recommendations and where I could find it???
tylerdurden119 is offline   Reply With Quote
Old May 19th, 2009, 09:13 PM   #2
a picture would reeeeally help.
Hi temp red RTV.
Old May 19th, 2009, 09:30 PM   #3
tylerdurden119
jackpot, found the cam the other day!
it might be kinda hard to see, but its out about an eighth.
Old May 20th, 2009, 06:40 AM   #4
Cali619
Giggity Giggity
Cali619's Avatar
Motorcycle(s): 08 ninja 250R aka Hiryu
just wondering if your spacers are maybe backward. on my Jardine the larger one was on inside smaller one on outside.
Facebook DY Fender chop, Danmoto CB slip-on w/baffle, Airbox removed, Kleen-air removed, shimmed needles, Mikuni #117.5 Main jets, K&N RU-1822 air filter pods
Cali619 is offline   Reply With Quote
Old May 20th, 2009, 01:51 PM   #5
tylerdurden119
Dremel did the job, not sure how much I took off, maybe a sixteenth or less. Posted it on another forum and apparently alot of people are having this problem with the two brothers exhaust. But it all worked out, woulda been nice to just bolt everything up but c'est la vie. Only thing left to do is take it all apart and install that permatex heat silicone, and then it'll be golden. Sounds amazing btw.
Old May 20th, 2009, 04:35 PM   #6
Jiu Jitsu Player
Live 2 Ride Forced 2 Work
Jiu Jitsu Player's Avatar
Motorcycle(s): 2008 RED 250r
I had a similar problem but I was using an aftermarket hanger . I wound up just using that sapcer on the outside and tightening the crap out of it. It worked perfectly because the can needed a bit more clearance on the outside and having the spacer the spacer there provided just enough.
SAVAGE MODE: [ON] OFF
www.7milesdown.com
Jiu Jitsu Player is offline   Reply With Quote
Two bros slip on FS sharky nrk Motorcycle-related 10 June 5th, 2014 10:15 AM
Reducing noise on Two bros Slip on? k24_cm7 2008 - 2012 Ninja 250R Tech Talk 8 April 20th, 2013 01:32 PM
Bros Aluminum Slip On illrational Motorcycle-related 6 March 11th, 2011 07:35 AM
FS: Two Bros Racing Slip on GeneJunkie Motorcycle-related 5 October 4th, 2010 07:58 PM
2 Bros Slip on Exhaust Question Jiu Jitsu Player 2008 - 2012 Ninja 250R Tech Talk 12 July 16th, 2009 08:43 PM
