July 10th, 2010, 06:55 AM | #1 |
Rear turn signals
I installed flush mount front turn signalson the rear.There are 3 wires on each signal.It uses 1157 bulbs giving me the option of using them as running lights also.Heres the rub.When the red wire and black and white wire are connected (leaving the third black wire out,the signal flash at the right cadence.When the two other black wires are connected to power (direct to battery just to see if they light),they light up the signals but then when the flasher is used they flash at a much faster rate?? What would cause that.Should I connect the 2 red wires to the bike as running lights instead and use the 2 black ones as flaashers?Doesn't seem to make sense it would nmake a difference?
Posted via Mobile Device |
Looking for 09 oem rear turn signal and front turn signals and tail fairings | mbbernas | Items Wanted | 1 | September 11th, 2013 10:48 AM |
Rear turn signals don't blink, front turn signals don't turn on | andyuc88 | 2008 - 2012 Ninja 250R Tech Talk | 3 | March 23rd, 2012 02:47 PM |
Rear Turn Signals | gogiburn | 1986 - 2007 Ninja 250R Tech Talk | 0 | July 8th, 2010 06:59 AM |
