June 21st, 2011, 03:32 PM | #1 |
Join Date: Mar 2010 Motorcycle(s): Ninja 250R '09, SV650s '07 Posts: 52
Is it safe to top-off original brake fluid?
It seems as though my front brake reservoir is running a little low on brake fluid, so I was wondering whether it was safe to top-off the original brake fluid? If topping off brake fluid is acceptable, what type of fluid should I use?
Also, My front brake pads do need to be replaced urgently (EBCHH on order), but will the new pads change how much fluid rests in the reservoir? Current odometer: 13000km/8000miles |
June 21st, 2011, 03:36 PM | #2 |
The Sportisi Master
Join Date: May 2009 Motorcycle(s): 2008 Ninja 250 Posts: A lot.
the thicker pads will push some fluid back into the reservoir. using dot 3 or 4 fluid it is ok to top it off but do not over fill it. no need for a flush yet.
Sportisimoto USA is born. |
June 21st, 2011, 03:50 PM | #3 |
My level seems to be dropping and I can see that the surfaces around the reservoir look like they've been bubbled up but I don't see any fluid or wetness. I'm going to have to take care of that soon.
It still seems full (small bubble at the top is only a little bigger) but I recently noticed that the level dives down to nothing when I brake. I know some just sloshes forward, but is this normal? |
June 21st, 2011, 08:43 PM | #4 |
3/4 should be interchangeable (just don't get 5), but if it's the original brake fluid, I'd flush it. It's generally not ideal to mix old and new brake fluid. You should be replacing brake fluid every two years so your 09 is due and it only takes like 10 minutes to do
June 22nd, 2011, 07:00 AM | #5 | |
Thanks for the replies. My plan now is to install the new brake pad, then re-evaluate whether or not my motorcycle requires any additional brake fluid. |
Brake fluid | Islandmax | 1986 - 2007 Ninja 250R Tech Talk | 11 | June 22nd, 2013 04:28 PM |
2010 Ninja 250r Brake fluid bleed/Replacement and brake caliper cleaning | RandomPhantom | 2008 - 2012 Ninja 250R Tech Talk | 1 | May 30th, 2013 08:13 PM |
Replacing brake pads and brake fluid | Bones85 | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 28th, 2013 06:25 PM |
How much brake fluid ? | GiGs | 2008 - 2012 Ninja 250R Tech Talk | 5 | December 31st, 2010 06:06 PM |
Brake Fluid? | ASecretNinja | 1986 - 2007 Ninja 250R Tech Talk | 4 | January 20th, 2010 03:02 PM |
