Old March 12th, 2011, 09:15 PM   #1
Littlefreak
Motorcycle(s): 250R & ZX-10R
Another Clutch Issue...Cannot Disengage!
I've searched and gone through a few threads that have had issues with the bike not being able to engage after a clutch cable replacement. Mine is just the opposite.
My 2003 Ninja 250R clutch cable snapped on me last week. I replaced it following the service manual and the DIY instructions on other sites. Problem is that the clutch will not disengage.
1. With the engine off...I put the bike in FIRST gear and try to roll it forward. It doesn't roll as designed.
2. I pull the clutch lever and it still will not roll forward. ????
I've made several adjustements to the freeplay and have no luck.
I pulled the release lever out and reinstalled it and the cables...no luck.
I pulled the clutch cover off and didn't see anything odd with the release lever or pusher, reinstalled....no luck.
I pulled the spring plate out, checked the bearing/pusher position, and reinstalled everything...no luck.
The old part number for the cable is 54011-1295, and according to ronayers.com I am using the new part# 54011-1261
Before the original cable snapped, everything was shifting smooth. I just bought the bike a month ago.
Please help!! What am I missing? Did I somehow screw something up upon removing the old cable for the clutch side adjuster/release lever?
Littlefreak is offline   Reply With Quote
Old March 12th, 2011, 09:45 PM   #2
scotty
scotty's Avatar
Motorcycle(s): Yahama v star 650 classic
Is there any play in the cable at all? The cable should be tight though out the whole system and the lever should only have about a nickel worth of play.
scotty is offline   Reply With Quote
Old March 12th, 2011, 09:50 PM   #3
Littlefreak
The only play in the cable is the slight freeplay in the cable at the lever's (clip-on) end...per manual.
Old March 12th, 2011, 10:23 PM   #4
when you work the clutch lever in and out, is the release lever on the engine end of the clutch cable turning as it should?
Old March 12th, 2011, 11:37 PM   #5
Littlefreak
Well it doesn't seem an issue anymore, and I'm wondering if this is normal 250R behavior when the bike is cold. I warmed it up and it seemed to loosen up a bit. Took it for a short test ride and there were no issues. I'll re-adjust the cable in the morning, but the bike is shifting great. Sorry for the false alarm, but thanks for your concern and respones guys.
Old March 12th, 2011, 11:45 PM   #6
Having the clutch lever pulled with the bike in 1st gear is definitely not the same as neutral (the tire will spin if the bike is lifted), but it still should not have felt like you couldn't move it. Was the tire possibly wedged in a pavement hole or something?
Old March 13th, 2011, 07:13 PM   #7
Littlefreak
Took it for a 200 mile ride today after the final cable adjustments. Everything seems in order. I'm a happy dude.
Old March 13th, 2011, 07:40 PM   #8
mrlmd
mrlmd's Avatar
Sometimes these bikes get "sticky" clutch plates from the cohesive effects of the oil between the plates if the bike hasn't been used for a while. Pull in the clutch, rock it back and forth for a few seconds and it should loosen up and release. Occasionally you'll see it lurch forward as if in gear even with the clutch pulled in when you try and start it. Just ride it, it'll loosen up and go away, it's almost normal behavior and nothing to worry about.
Old March 13th, 2011, 09:15 PM   #9
Littlefreak
Sounds right to me. While this issue was a pain in the butt, it allowed me to get more familar with the bike.
Clutch Won't Disengage Gmon 1986 - 2007 Ninja 250R Tech Talk 21 September 23rd, 2019 09:31 PM
Clutch issues. Won't disengage, searched, tried, help mr2peak 1986 - 2007 Ninja 250R Tech Talk 21 May 5th, 2014 04:32 PM
Clutch Issue Shaol1n Monk 2008 - 2012 Ninja 250R Tech Talk 3 November 25th, 2011 09:22 PM
Clutch doesn't fully disengage power when pulled in. reaubideux 2008 - 2012 Ninja 250R Tech Talk 11 November 3rd, 2011 10:11 AM
Improperly disengage clutch ~ revs high, lower speed. Ntotot 2008 - 2012 Ninja 250R Tech Talk 12 August 26th, 2009 10:48 PM
