April 6th, 2013, 08:24 PM | #1 |
Join Date: Feb 2013 Motorcycle(s): 2006 Kawasaki Ninja 250R, 2008 Kawasaki Ninja 250R Posts: 39
06 250 Won't Start, Please Help!
Alright, so I am about at the end of my rope with frustration, because everything I try to do to my bike tends to keep failing. And they are just simple mods. Anyway, my bike was running just fine yesterday, not acting funny or anything. So far the only thing that I have done to it today is: taken off the upper and lower fairings and the fairing over the front tire for paint work, obviously I unhooked the front turn signals to take off the fairing, then I changed my clutch and brake levers. That's it. And now when I try to start it it does nothing. When I turn the key my dash light light up and my tail and brake light works as well as my rear turn signals and my horn. But when I hit the starter button absolutely nothing happens.
I have checked my battery connections, my fuse box and the wires connecting to my starter button and all is well there. I cleaned the spark plugs and changed the battery a couple weeks ago and have been riding it every couple of days since then and all was well until tonight. I have even tried pulling in the clutch and brake levers and still nothing. It doesn't even try to crank. I have not messes with any of the wires pertaining to the starter button and I am pretty much out of ideas. The weather is super nice tonight and all I can hear is the roar of motorcycles and all it does is depress me more. If anyone has any ideas that I have not already tried then it would be much appreciated. Thank you. Yes I am kind a noob rider but I have been riding since last October and have not experienced anything like this. Please help
If your surroundings are not a blur, then you are riding too slow. |
April 6th, 2013, 08:48 PM | #2 |
Join Date: Jun 2012 Motorcycle(s): the cool ones Posts: 182
There's a little switch on the clutch side of the bike. It's mentioned here:
http://faq.ninja250.org/wiki/Replaci...6_brake_levers It has to be positioned in such a way where the lever pushes it in completely when the clutch is engaged. It's worth looking into it since you said you messed the levers. |
April 6th, 2013, 08:49 PM | #3 |
April 6th, 2013, 09:25 PM | #4 |
If you have a voltmeter or testing light, check that juice is reaching the starter when you push the button.
If your headlight dims when you try to start, charge your battery or try another one.
April 6th, 2013, 09:39 PM | #5 | |
But I looked very close before removing the old clutch and there was no switch or plunger as pictured. As soon as my boyfriend gets off work then I'm going to try to jump it and see if its a battery problem. I'll let you guys know how that turns out.
April 6th, 2013, 09:51 PM | #6 |
Aimless
Join Date: Feb 2013 Motorcycle(s): 01 ninja 250 Posts: 69
I didn't see any mention of the kill switch being checked. Are you sure it is in the correct position? Even if it is, I have had a bike not start because the switches internals were corroded.
I just dropped in to see what condition my condition was in |
April 6th, 2013, 10:05 PM | #7 |
Join Date: Jan 2013 Motorcycle(s): 03' Ninja 250ex Posts: 333
Have you checked your kickstand switch?? They can get dirty and loose contact. I've deleted a few of those on BMW RT's due to chronic failure.
April 6th, 2013, 10:50 PM | #8 | ||
April 6th, 2013, 11:17 PM | #9 |
Oh, and BTW I tried to jump start it, and still nothing so I know it's not the battery. I will still look into the switches tomorrow.
April 7th, 2013, 10:12 AM | #10 | |
However, a while back I had a similar problem with the same symptoms. Turned out to be a bad starter and diodes. Here's the thread: http://www.ninjette.org/forums/showthread.php?t=119364 that being said you should first check the simple things that others have suggested first, like voltage across the battery, fuses, etc. keep us updated! |
April 7th, 2013, 12:44 PM | #11 | |
April 7th, 2013, 01:09 PM | #12 | |
http://faq.ninja250.org/images/0/07/..._Schematic.pdf http://faq.ninja250.org/wiki/Starter_circuit_schematic https://docs.google.com/file/d/0B5Ag...zY5/edit?pli=1 https://docs.google.com/open?id=0B5A...QwNTg3MTU3Y2Yz https://docs.google.com/open?id=0B5A...IxZTU2M2YwOWM3
April 7th, 2013, 01:21 PM | #13 | |
http://www.ninjette.org/forums/showthread.php?t=35999 |
April 7th, 2013, 01:52 PM | #14 |
April 7th, 2013, 01:52 PM | #15 | |
April 11th, 2013, 05:46 PM | #16 |
Join Date: Apr 2013 Motorcycle(s): 2004 Ninja 250 Posts: 465
Have u tried seeing if it will turn over? There is an access cover on the left side of the bike. Once the cover is off you can get a ratchet on there and spin the engine over.
April 14th, 2013, 01:58 PM | #17 | |
Okay, so I took apart the switch panel on the right handlebar (that has the engine cut off switch and the starter button), to see if it was corroded or anything, and it looks practically brand new in there. I didn't get much more accomplished today, but I did remove the side fairings and the fuel tank to try to follow the wires to find the problem, turns out to be much harder than it sounded. I tried to find the starter relay, not sure if I found it or not, but following any wires and I still found no visual problems. Maybe if someone can direct me better to the starter relay on the pregens then I can make sure I looked at the right thing. Also I went ahead and replaced the ignition fuse in case it was blown and I just couldn't tell, still wouldn't start.
As I had mentioned before, I looked very closely around the clutch lever before I replaced it and did not see a clutch safety switch, is it possible that it somehow fell out on it's own while I was riding it or whatever and could that be why it won't start? Also I found this bit of information, quoted below, talking about water in the float bowls and how it is almost the only reason why a bike would run fine one day and not run at all the next day. But would water in the float bowls actually keep the bike from cranking at all? To remind you, my bike doesn't even try to crank, when push the starter button, absolutely nothing happens. Quote is from this site HERE: Quote:
edit: My boyfriend seems convinced that I messed something up when I replaced my clutch and brake levers, if this is even possible let me know. I am running out of things to look at here.
April 14th, 2013, 02:54 PM | #18 |
Check this thread for more ideas:
http://www.ninjette.org/forums/showt...lay#post666835 Is voltage reaching the starter? Do your lights dim?
April 14th, 2013, 02:58 PM | #19 | |
April 14th, 2013, 02:59 PM | #20 |
Join Date: Apr 2012 Motorcycle(s): 650r 2009 Vulcan 800 2005 Posts: 557
Kill switch near the throttle?
It's all about the curves. If you ride, you understand. If you have a stick skinny g/f and ride, you're 1/2 way there. |
April 14th, 2013, 03:28 PM | #21 |
yes, upon reading through the other posts you would have noticed that that was obviously checked even though I didn't mention it in my first post. The only reason I didn't mention it in my first post is because I wouldn't have started the thread in the first place if I hadn't already checked the basics. I don't mean to sound like a b*tch, but this problem is driving me super insane.
April 14th, 2013, 04:36 PM | #22 | |
I saw the mention of the kill switch after I'd posted... but it was too late.
April 15th, 2013, 11:39 PM | #23 | |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
There should be a plunger there. You must have broken off the plunger when you swapped levers. Your problem is clearly electrical. Don't mess with the engine... There IS a side stand switch. You CANNOT "presume" that voltage is getting to places. You must test the circuit! Be careful jumping bikes, a running car can overload the regulator/rectifier. The car should be OFF. By the way... did you check the kill switch?????? From the ninja 250 faq http://faq.ninja250.org/wiki/Underst...afety_switches Short version A bike can be started: in neutral with the side stand down and the clutch out in neutral, with the side stand up and the clutch out in gear, with the side stand down and the clutch in in gear, with the side stand up and the clutch in Details To successfully start the Ninja 250, a number of conditions must be met before the starter solenoid can be energized. With the above schematic it is pretty simple to follow the path the electric current needs to flow, beginning with a fully charged battery. Starting from the battery, the following conditions must be met: 30 Amp fuse in operating condition. Provides 12VDC power to the motorcycle. Ignition switch in the ON position. Provides 12VDC power to fuse #3, and enables the ignition module. 10 Amp fuse (No. 3) in operating condition. Provides 12VDC power to the run switch, tachometer, neutral lamp, and enables the ignition module. Run switch in the RUN position. Provides 12VDC to the start button. Start button. Gear selector in neutral position -- OR -- Clutch lever in pulled-in position (disengaged). Provides a path to chassis ground for the starter circuit relay, and enables the ignition module. At this juncture both the ignition module and the starter circuit relay are operational. Pressing the start button at this time will energize the starter circuit relay coil, allowing 12VDC to pass through the starter circuit relay to the starter solenoid.. When the starter solenoid coil is energized, the starter solenoid allows electric current from the battery to pass through to the starter motor, which in turn starts the motorcycle. Success!
Unregistered found this post helpful. Track Day Preparation Checklist 1. Financial 2. Mental 3. Physical 4. Gear / Bike |
April 16th, 2013, 06:10 AM | #24 |
Join Date: May 2012 Motorcycle(s): Yellow 2002 Ninja 250 Posts: 53
Does it click at all (the starter solenoid) when you try to start it? If it does, then you should verify your starter is a-ok.
Also, make sure your engine ground connection is clean & tight (it is on the right side of the engine, kinda behind where the clutch cable meets). |
April 16th, 2013, 09:31 AM | #25 | |
April 16th, 2013, 11:36 AM | #26 |
http://www.youtube.com/watch?v=DYec1yFX3YI
Here's a good video on how to diagnose starters/solenoids, It's not on a 250 but the it's the same thing for our bikes. IIRC the solenoid is on the right side of the bike and looks like this (with 3 wires connected to it one on top, two to the side): http://ecx.images-amazon.com/images/...CL._SY300_.jpg you can also find it by following the black wire that is connected to the starter (a black cylinder looking thing sitting above where the clutch is). But before doing any of this you should really look into that plunger, Remove the clutch lever and make sure it's there. |
April 16th, 2013, 01:10 PM | #27 |
Let me try to help one more time.... can you roll start it? Does the starter work in neutral?
April 16th, 2013, 03:39 PM | #28 | |
I want to thank everyone who has given me such good ideas, it's not fixed yet by any means but I wanted to thank everyone anyway. I am gonna watch that YouTube video as soon as I get home from work and hopefully it will give me more good ideas. Tomorrow I am gonna test my starter solenoid and hopefully that will be it once they are fairly cheap to replace. I will keep everyone updated.
April 16th, 2013, 03:50 PM | #29 |
You dont really need a hill or long legs to bump start............just the ability to run
http://www.youtube.com/watch?v=3Jh2wIGTFLA |
April 16th, 2013, 06:35 PM | #30 | |
April 17th, 2013, 11:59 AM | #31 |
Good News
I found out what was wrong with my bike, it was the starter solenoid. I figured it out after the simple paper clip test. Now all I gotta do is buy a new one, which I found on ebay $10. Thank you everyone for all of your help, it was much appreciated. Thank you!
April 17th, 2013, 12:48 PM | #32 |
You are welcome
May 7th, 2013, 06:26 PM | #33 |
Not fixed after all
Well, it wasn't as simple as I thought. I replaced the starter solenoid and it didn't fix the problem. And using a test light I tested the starter/kill switches and all check out alright. So if anyone has some new ideas then I am more than open, nice weather has finally arrived and I am aching to get out and ride again.
May 8th, 2013, 05:56 AM | #34 | |
I got a new starter off ebay for $30, so that wasn't bad, and it was really easy to replace. |
May 8th, 2013, 07:38 AM | #35 | |
May 8th, 2013, 07:49 AM | #36 |
Can you get your bf to help you roll start it?
The only things I can think of that interlock the starter are the clutch switch and neutral switch.
May 8th, 2013, 08:16 AM | #37 |
It's possible the starter solenoid you got is bad as well. Jump it and see. I haven't looked at the schematics but would a faulty neutral position switch prevent it to turn on? Neutral light on?
May 8th, 2013, 08:41 AM | #38 | |
If you do not hear a faint clicking noise when pushing the starter button, the relay is defective. Use the 1 ohm setting on a voltmeter and measure the resistance across the terminals. If the relay makes multiple clicks and the meter does not read zero, the relay is defective. If the relay clicks one time and the meter does not read zero, the relay is good. The trouble is in the starter motor or the motor power supply wires. |
May 8th, 2013, 08:43 AM | #39 |
Are you sure about that?
Name: That's "Sir" to you!
Join Date: Sep 2012 Motorcycle(s): Ninja 250R-F16, Versys KLE650 CAF Posts: 418
Are you absolutely, positively, definitely sure that it isn't the plunger? The reason that I ask is because I broke the plunger on my bike when I was changing the clutch lever. It's sooooooo easy to do. I was aware of the plunger, and being really careful, but I still managed to break it.
http://faq.ninja250.org/wiki/Checkin..._safety_switch |
May 16th, 2013, 09:32 AM | #40 |
Yay!
I'm pretty confident that I have finally figured out my problem. It's my clutch safety switch. I knew it was broken off before the bike quit working, so I never thought it could actually be the problem. And when I switched out my levers I took careful notice that it was already broken off and I didn't break it myself. See, when it was broken off by the previous owner there was still a small piece in there that was still engaging the switch allowing me to start the bike and ride. But I guess at some point it jiggled and disengaged the switch causing my problem. But with my trusty paper clip I just pushed it back into place and the bike started cranking. Yay! So I've got a new switch on it's way via snail mail, but luckily in the mean time I can still ride.
05 Ninja 250 won't start on its own - help! | AmyF | 1986 - 2007 Ninja 250R Tech Talk | 59 | July 8th, 2014 11:46 AM |
'07 250 won't start | heroin300 | 1986 - 2007 Ninja 250R Tech Talk | 10 | May 10th, 2014 08:59 PM |
06 ninja 250 won't start | wolfpuss | 1986 - 2007 Ninja 250R Tech Talk | 7 | February 21st, 2012 05:57 PM |
'08 250 won't start | Rynownd | 2008 - 2012 Ninja 250R Tech Talk | 84 | September 8th, 2009 10:20 PM |
'06 250 won't start | Nemy | 1986 - 2007 Ninja 250R Tech Talk | 24 | May 23rd, 2009 04:17 AM |
