#1 |
Join Date: Jun 2009 Motorcycle(s): 2008 ninja 250 Posts: 271
valve cover removed question
what are the two tubes in between the spark plug holes
Would it hurt to clean them? the image is sideways every time I resize that happens but the tubes look very dirty http://www.ninjette.org/forums/attac...1&d=1386802469 Last futzed with by mikedabike64; December 11th, 2013 at 04:22 PM. Reason: add photo |
#2 |
Cant see the pic
#3 |
ok sorry
I tried to post the picture again but they connect to the reed valve and they are very dirty,
I wasn't sure if there was any way I could clean that out with maybe a little contact cleaner or something, I did not know if that acted like a PCV valve where it just takes gas is to be reburned I wasn't sure what direction the gases were going, I figured I would ask before I start shoving q-tips down there :O |
#4 |
do you mean the sparkplug well drain holes? they go to under the exhaust ports to drain fluid built up near the sparkplug
#5 |
when you take off the valve cover
there are two gaskets with two circles on each gasket
the big circles around the spark plug well hole, the little circles around these metal tubes on top of the valve cover there is a smaller reed type valve that sits over these tubes compared to most other bikes I see the tubes inside their bikes are very clean mine are completely black and carbonized I was just wondering if I should clean them out or not, I was doing the valve clearance and noticed it. |
#6 |
i believe those put fresh air into the exhaust in order to "clean it up". unless you need to pass smog i dont think they affect anything
#7 |
thank you Alex,
valve cover gasket | drewsley | 1986 - 2007 Ninja 250R Tech Talk | 8 | August 21st, 2014 04:59 PM |
Bar Shake and Valve Stem Question | Dredgshadow | 2008 - 2012 Ninja 250R Tech Talk | 12 | May 31st, 2014 06:47 PM |
Trouble removing valve cover. | Floki | 2008 - 2012 Ninja 250R Tech Talk | 6 | January 4th, 2014 06:06 AM |
Removing the Valve Cover | n4mwd | 1986 - 2007 Ninja 250R Tech Talk | 19 | June 24th, 2013 08:25 PM |
Question re valve check | adouglas | 2008 - 2012 Ninja 250R Tech Talk | 16 | July 7th, 2010 05:53 PM |
