Old December 15th, 2011, 01:43 PM   #1
ryanG19
ryanG19's Avatar
Motorcycle(s): 2012 Ninja 250r Candy Apple Lime
Mounting 12v socket and LEDs on same line?
Hello all,
I've been lurking for a while and the search function didn't bring up these two together, so I figured I'd ask. I'm planning on wiring up a 12v socket and about 8 24cm strips of LEDs to my bike. I plan on wiring it directly to the battery and using an inline 20 amp fuse, 12 gauge wire, an on/off switch, and then grounding it back to the battery.
Is it safe to wire both the 12v socket and the LEDs to the same 12 gauge line as long as it takes place after the inline fuse? Will having my phone charging (12v socket in use) pull more electricity into the LEDs and blow them? Thanks for the help, and I will be sure to take a lot of pictures of the finished product.
ryanG19 is offline   Reply With Quote
Old December 18th, 2011, 08:37 PM   #2
Skippii
Milkshake Drinker
Skippii's Avatar
Originally Posted by ryanG19 View Post
Hello all,
It'll be fine.
You can run as many things as you want in parallel, it won't change the voltage.
I wired up something straight to the battery through a fuse that ran an LM7805 into an LED, a GPS charger, Cell phone charger, and mp3 player charger.
"What a sweetheart."- ninja_sleeper to me
Old December 22nd, 2011, 06:19 AM   #3
ryanG19
ryanG19's Avatar
Thanks for the answer. I ended up running them together and it looks/works great. I'll post some pics later this week.
WTB Headlight Socket mholme Items Wanted 4 December 31st, 2014 10:34 AM
[SOLVED] Mounting my Tri Flush mount LEDs CalvinAmI 2008 - 2012 Ninja 250R Farkles 35 August 5th, 2013 11:08 AM
light socket question Proto 2008 - 2012 Ninja 250R Tech Talk 4 August 9th, 2012 07:33 PM
Help! Dropped socket into engine... CmichRider 1986 - 2007 Ninja 250R Tech Talk 3 July 19th, 2011 03:55 PM
12V Socket - Max power output? AgentX 2008 - 2012 Ninja 250R Farkles 15 September 12th, 2010 07:55 PM
