Old July 16th, 2012, 08:36 AM   #1
DaBlue1
DaBlue1's Avatar
Review: Bridgestone Battlax BT-45 140/70-17 and 120/70-17
After running stock size tires for the last 3 years, I decided to go up a size on my rear tire. I wanted to test out a little more girth. I ordered a BT-45 to replace my worn out Continental Conti-Go (130/70/17). Compared to the Conti's, on paper they are very close in size, however up close is a different story. I took pictures and compared the BT-45 to an old Conti that had already been mounted and slightly compressed.
I got the BT-45 at Motorcycle Superstore for $100.99 and free shipping. Last year I paid $86 and some change for the Conti-Go, this year the same tire was as low as $99 and as high as $169 with shipping. I have so far put over 4k miles and 13 months on the Conti-Go's. They now look more like Conti-gone. Hopefully I can get a little more mileage out of the BT-45's.
Just like the rear tire, I also went up a size in the front. Instead of a 110/70/17, I'm now sporting a 120/70/17. Compared to the Conti-Go's, there is a difference in diameter but not too much in the width.
Exploring/Carolina was more than gracious enough to help me get these tires mounted. He schooled me on how to use the Cycle Hill Stand built by No-Mar and the No-Mar static tire balancer. He's got 5 bikes so this equipment gets a workout. His garage is a regular cycle shop and air conditioned too!
Here are the specs for the front tires;
Continental Conti-Go 110/70/17
Width -4.76
Dia. -23.46
Circum. -73.66
Bridgestone Battlax BT-45 120/70/17
Width - 4.80
Dia. -23.8
Circum. - 74.73
Specs for the rear tires;
Continental Conti-Go 130/70/17
Width -5.59
Dia. -24.63
Circum. -77.33
Bridgestone Battlax BT-45 140/70/17
Width - 5.70
Dia. -24.7
Circum. - 77.58
Fit
The rear tire gave us a little fight but we managed to get it on. Poor Bill couldn't figure out why it was so tight until I told him it was a bias ply tire, which has a much stiffer sidewall than a radial. The front was a lot easier and both balanced out real well. Both tires look good with little evidence of pinching on the rim. In the stock configuration (14/45 sprocket combo), this tire would be really tight fit in the swingarm, but doable. Because the sidewall is so stiff, there's little chance of sidewall flex. My wheel is pulled back approx .12mm, which makes for plenty of clearance in the swingarm.
Handling
While we were mounting the tire it was raining and was raining right up till the time we finished, so my first test on these new tires was going to be 8 miles back home on rain slick roads. Because the tires were brand spanking new I didn't push them, but they were very, very stable and never felt like they would slide out. Honestly I really couldn't tell the road was wet except for the fact that I could see it. About 2 miles out from the house it was drizzling, but again the tire felt solid for turning on wet surfaces.
On a dry warm surface you can definitely feel the stickiness of these tires. Much better than the Conti's. Good with acceleration out of the corners, tracks well while leaned over. No sketchiness when transitioning from side to side. As far as the Ninja's "flickability" goes, on these tires the bike feels a slight bit heavier, so that it's not as quick to go over, but a slight adjustment of the riding style fixes that quickly. The bike actually feels like it has the handling of a bigger bike. With a little more width (both front and back) the bike leans over a tiny bit more. The Conti's, even when they were newly mounted had a very slight handlebar wobble around 45 mph. The BT-45's are well balanced and exhibit no such wobble. The small change in front wheel diameter did make a small change in the speedo reading. Before the speedo read approx 5 mph faster, now it is an avg. of 4 mph faster than actual speed.
I'll be able to put more time and distance on these tires @ The Ninja 250 Rally in August to see how they really perform.
Last futzed with by DaBlue1; September 10th, 2012 at 03:17 PM.
Old July 16th, 2012, 09:25 AM   #2
i like the bt45s.
Old July 16th, 2012, 01:44 PM   #3
cuong-nutz
cuong-nutz's Avatar
I might give them a try after I wear out my S20s. A downgrade but I want to see what kind of mileage I can get out of them. I managed to get roughly 7k out my BT16s.
HalfFast Racing Team
Old July 16th, 2012, 01:51 PM   #4
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
I only got 2000mi out of my bt45s
AFM #676
Supersports are for n00bs
Old July 16th, 2012, 04:05 PM   #5
the video makes it look more like .1mi
Old July 16th, 2012, 04:29 PM   #6
johnjohn
Motorcycle(s): Honda, Buell, Kawasaki, Suzuki, Yamaha
BT45's are dual compound tires you should get great milage out of them. previous poster must be spinning the wheels. I use Bridgestone BT45's on the rear and Avon AM26 Roadriders on the front. Both bias belt tires. Grip is not an issue. These are on a 2001 ZZR 250.
johnjohn is offline   Reply With Quote
Old July 16th, 2012, 04:41 PM   #7
so what do you think of the 120 and turn in force, blue?
Old July 16th, 2012, 04:59 PM   #8
NinjaBoyEddy
NinjaBoyEddy's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250r special edition
What size s20 do you have up front?
I'm thinking of going 120 up front that's why I ask.
NinjaBoyEddy is offline   Reply With Quote
Old July 16th, 2012, 04:59 PM   #9
NinjaBoyEddy
How does the bt45 120 feel? Did you have to mod anything for it to fit?
Old July 16th, 2012, 05:30 PM   #10
DaBlue1
DaBlue1's Avatar
I like it. It feels like it's heavy, but it's just the tire grabbing better. At slower speeds you can tell it the most, higher speeds it's really stable but still easy to get over. Not a lot more force needed to get it to turn though. To me the 110's seemed to follow grooves too much when leaned over. Not so much with these 120's
No modding necessary for the 120.
Old July 16th, 2012, 05:35 PM   #11
cuong-nutz
cuong-nutz's Avatar
I still have the BT16 110 up front. Will a s20 replacement soon though.
Old July 16th, 2012, 05:43 PM   #12
i'm going to try a 90w front tire soon. im kinda scared. LOL
Old July 16th, 2012, 06:00 PM   #13
DaBlue1
DaBlue1's Avatar
Doing anything to the suspension?
Old July 16th, 2012, 06:35 PM   #14
its at 15w oil, stock springs with added preload set for 30mm sag. no emulators or special valving. forks are at 20mm on top of the triple with stock rear height currently. i had an r6 shock on the rear before but i didn't like the setup i had which took me from about 130mm travel down to about 100mm on the rear, so i put the stock rear shock and linkage back on. it seems like the rear shock is less important on these bikes but i think i'm going to make a new pivot knuckle to get back the 3cm lost travel and go back to the r6 shock just for the damping control. the tires will be the bridgestone slicks. not sure about compound details or anything yet. i will probably need to make some changes to stiffen things up im thinking. probably drop the forks down to 5mm just cause of the tiny front tire
Old July 17th, 2012, 05:53 AM   #15
DaBlue1
DaBlue1's Avatar
.... i will probably need to make some changes to stiffen things up im thinking. probably drop the forks down to 5mm just cause of the tiny front tire
I was going to say, moped tires need some help.
Old July 17th, 2012, 08:13 AM   #16
LOL they are the bridgestone moto3 slicks
Old July 17th, 2012, 08:28 AM   #17
Boom King
So, where's the reverse?
Boom King's Avatar
I'm considering switching out the rear and going with the BT45; either in 130 or 140. Probably going to leave the crappy stock IRC on the front though. Hopefully, that doesn't cause any issues.
Old July 17th, 2012, 09:04 AM   #18
DaBlue1
DaBlue1's Avatar
To be honest, you may want to go ahead and get a matching front tire. Either size BT-45 is going to grip much better than that IRC, that's probably loosing what stickiness it had.
Old July 17th, 2012, 09:46 AM   #19
always make sure your front tire has the same or more grip than your rear tire. my opinion.
Old September 6th, 2012, 08:12 PM   #20
BlueJeepYJ
Lets go ride!
BlueJeepYJ's Avatar
Motorcycle(s): Ninja 650
HOLY CRAP! I just installed this setup on my 09 coming from the worn squared IRC's. WOW! It was like going from Flintstones rock wheels to riding on clouds! Highly recommended! Going to really test them out this weekend!
BlueJeepYJ is offline   Reply With Quote
Old September 7th, 2012, 03:55 PM   #21
Lil_Green_Demon
Winging It In Life
Lil_Green_Demon's Avatar
Motorcycle(s): 2010 250R; 2011 250R (sold)
Nice, OP. I've got the same rear tire, except mine is a 140/80-17. Front is still the stock one, but I'll be switching it up to a 120 soon enough.
Lil_Green_Demon is offline   Reply With Quote
Old September 10th, 2012, 09:22 AM   #22
cuong-nutz
cuong-nutz's Avatar
Well I killed the sides of my front 110 BT-16 and installed a used 120 BT-16 yesterday. As @DaBlue1 mentioned:
The 120 front makes the bike feel heavy when tipping over into a turn due to the increased width and contact patch. Also the tire profile was a whole lot rounder and less of a V as compared to the 110. Takes more effort to turn in but after that, the front feels really stable in turns with bumps and cracks.
I'm still running a 150/60/17 rear S20.
Old October 23rd, 2012, 02:05 PM   #23
cuong-nutz
cuong-nutz's Avatar
@DaBlue1, so how are the 45s treating you so far? Wear, grip, handling, etc., I'm thinking about taking the plunge and switching to 45s.
Old October 23rd, 2012, 03:54 PM   #24
DaBlue1
DaBlue1's Avatar
The tires have been great. I only have a 1710 miles on them, so they are still in good shape, no flat spotting on the rear yet. I really like the way they feel when lean over and going over cracks and grooves. I even notice a little more stability when the wind picks up or passing those slow, turbulence making 18 wheelers.
I got a good opportunity to test them in the rain and the twisties back in August during the Ninja 250 Rally. Really stable and confidence inspiring in those riding conditions. I'd buy them again for the way I ride.
Old October 23rd, 2012, 04:22 PM   #25
I liked everything about mine except the way they wore on my pregen. They seem to be fine on newgens though, so that's not really a concern.
If you want a tire that grips well, turns in predictably, and gets very good wet grip, the BT45 is a great tire.
[visordown.com] - Bridgestone Battlax S20 EVO tyre review Ninjette Newsbot Motorcycling News 0 May 1st, 2014 09:50 AM
[motorcycle-usa.com] - Bridgestone Battlax S20 Tire Review Ninjette Newsbot Motorcycling News 0 September 13th, 2013 04:40 PM
[motorcycle-usa.com] - Bridgestone Battlax R10 Race Tire Review Ninjette Newsbot Motorcycling News 0 August 2nd, 2013 08:20 PM
Bridgestone Battlax BT-016 tire review on Ninja 250 VIDEO. Skippii Videos 6 August 22nd, 2011 12:21 PM
[motorcycledaily.com] - Bridgestone Battlax BT-003 Racing Street: MD Product Review Ninjette Newsbot Motorcycling News 0 July 22nd, 2009 06:40 PM
