August 16th, 2011, 09:39 AM | #1 |
Join Date: May 2011 Motorcycle(s): 2006 GSXR 750; 1983 CB750SC Posts: 277
Hill Starts
Hi, I've been practicing with my bike in an parking lot that's mostly flat. There is one paved hill leading down to another field and I use that to practice my hill starts. I was able to start on that hill fairly easily, but when I tried on an actual street, I must have stalled like five times; it was bad.
I know that practice makes perfect, but are there any tips to help me not stall so much? haha Also, I found out after all the stalls that I was in second gear. I guess one tip right off the bat would be to make sure you're in gear one. xD |
August 16th, 2011, 09:48 AM | #2 |
old git
Join Date: Mar 2009 Motorcycle(s): BMW K1300S Posts: 479
Come to a stop select first, hold on rear brake, when required increase RPM to around 5K and ease out the clutch let go of the rear brake and away you go no problem.
Steve
Some mistakes are too much fun to make only once. |
August 16th, 2011, 10:07 AM | #3 |
Yup - 2nd gear starts on a hill could be challenging. Make sure you're in first gear, and don't be afraid to use more gas and revs to get up and going. Don't slip the clutch excessively though, make sure to let it all the way out as soon as you can once you're moving.
August 16th, 2011, 10:16 AM | #4 | |
Join Date: May 2011 Motorcycle(s): 2011 Ninja 250R Posts: 190
I know with a manual transmission in a car you're not suppose to hold on a up-hill grade by riding, or slipping the clutch.... On the 250, or any bike for that matter... is it ok to hold the bike on an up-hill grade while say waiting for a stop light with the clutch partially out ?
ATGATT Quote Wild Hogs - Woody: "May be I don't want to wear a helmet, Maybe I don't want anything between me and the road" Bobby: "You will if your head falls on it" |
August 16th, 2011, 10:18 AM | #5 |
You are sleeping
Power yourself right up them hills
Lots of RPM if necessary. Lean forward a bit too. I have gotten out of some dirtbike trails with nothing but 4" boulders all over on steep inclines with the lil ninja and lots of RPM and determination!
<Yeah, it's a 250. LMFAO! Weaksauce |
August 16th, 2011, 10:24 AM | #6 |
My understanding was that bikes have slipper clutches, which allow for slippage for gradual engagement of the clutch. My fear is that if i crank the RPM's, I'll get launched when I release the rear brakes. I suppose that just means I need to practice more clutch control and get more familiar with the friction zone of my bike.
August 16th, 2011, 10:31 AM | #7 | |
"Slipper clutch" is a different term altogether, and is a special mechanism in the clutch design that allows the rear wheel to turn faster than the drivetrain. This smooths downshifts, and keeps the engine's inertia from locking up the rear wheel. A slipper clutch mechanism can be on either a wet clutch design or a dry clutch design, it isn't related.
August 16th, 2011, 10:32 AM | #8 |
Not a great idea on a bike either.
August 16th, 2011, 06:40 PM | #9 | |
ninjette.org newbie 2,000
Join Date: Jan 2011 Motorcycle(s): Ninja 250r Posts: 160
or maybe I just suck at take offs... |
August 16th, 2011, 07:50 PM | #10 |
You are sleeping
Lean forward and it won't wheelie. lol
I don't use the rear brake unless I'm in the dirt or see oil patch at a stop light.
August 17th, 2011, 09:33 AM | #11 |
Join Date: Aug 2011 Motorcycle(s): Green '08 Ninja 250R Posts: 32
I tend to use the rear brake like a hey-dummy-I'm-about-to-slow-down button for drivers behind me. I usually tap it once or twice to flash my brake light before I start slowing with the front brake.
August 18th, 2011, 09:03 PM | #12 |
I've been practicing hill starts with your guys' tips. I think I've got the hang of it now! Haven't stalled once since haha. The main thing I had to overcome was the fear to give it more gas. However, thinking I was a hot shot, I went out onto one of the streets near my house that's maybe only 2/3 as steep as the hill I practiced on. As you probably guessed, I ended up stalling the bike.
Even though the road had no cars on it, I think I got a little frazzled and forgot the basics. Should I keep practicing on the parking lot or start getting more familiar with being on the road? btw, the streets around my house are really quiet, since it's near a school and school is not in session in the summer. |
August 20th, 2011, 01:27 PM | #13 |
Join Date: Oct 2010 Motorcycle(s): 1 of them Big Four Posts: 84
1. you can brake with the rear, when you feel the clutch engage, let go of rear brake
2. one finger front brake, don't squeeze too hard, just enough where you feel the bike stop rolling backward yea, definitely practice in an empty parking lot |
August 23rd, 2011, 03:09 PM | #14 |
Join Date: Feb 2011 Motorcycle(s): '10 Ninja 250R Posts: 12
I used to have a huge problem with this. Huge as in a drop and a crash. After the crash I didn't ride until I fixed the damage ($450 and a month later, ouch), and then I realized that my problem was a combination of not enough throttle and releasing the clutch too fast.
Since then I've got 4,200 miles more on the bike with no stalling or drops. Just give it plenty of throttle and be nice and slow/gentle with the clutch (while using the rear brake to keep yourself still until you can do the rest fast enough). |
September 9th, 2011, 07:00 AM | #15 |
Ninja Dog
Join Date: Dec 2010 Motorcycle(s): 2011 Kawasaki Ninja ZX-14 Posts: 186
+100
ALL YOUR NINJA ARE BELONG TO US! |
September 9th, 2011, 07:53 AM | #16 |
Join Date: Jun 2011 Motorcycle(s): Red 2009 Ninja 250r Posts: 132
Just keep practicing and have confidence. After you feel comfortable with your clutch and gain that confidence switching gears will be a breeze and you will be amazed at the amount of control you have compared to an automatic car. A few weeks and it will be second nature
"The goal in life is to die young at a very old age" " Four wheels moves the body, two wheels moves the soul' |
September 9th, 2011, 09:32 AM | #17 | |
September 9th, 2011, 09:37 AM | #18 |
I only use the rear brake if I want to take my hands off the controls while I wait at the stop.
Use the front brake to hold the bike on the hill. It takes very little brake pressure to hold the bike there. Raise the rpms' and let the clutch lever start to release. When the bike starts to want to move, release the front brake and then go on about your business fully releasing the clutch and giving throttle, just like usual. The bike isn't rolling with the front brake applied, you're releasing it as soon as you feel the bike want to move forward.. it seems almost instant.
September 10th, 2011, 09:41 AM | #19 |
Winging It In Life
Join Date: Aug 2011 Motorcycle(s): 2010 250R; 2011 250R (sold) Posts: A lot.
If you've driven a manual transmission car, it's pretty similar. Just gently let go of the clutch until you feel its friction point. You can also hold down on the rear brake and gently roll the throttle.
2011 Kawasaki Ninja 250R (Bought - Apr 22, 2011; Sold - Feb 17, 2015) 2010 Kawasaki Ninja 250R (Bought - May 01, 2017; Current) |
September 10th, 2011, 09:54 AM | #20 |
Learn to do it properly, without the rear brake. You might/probably will eventually run into a situation where you need that right foot to be on the ground and you'll be in a pickle.
October 10th, 2011, 05:27 PM | #21 |
Kryptonite
Join Date: Aug 2011 Motorcycle(s): 2012 Kawasaki Ninja 250 Posts: 38
Figured I'd add how I've tried it and see if people think it is right or wrong. For smaller inclines, I slowly start releasing the front brake while simultaneously letting the clutch go into the friction zone. I've noticed I can either keep the bike still like this or even get it to start walking forward. The rest if just adding throttle and releasing the clutch.
I usually just hold the rear brake and do it that way, but I tried it many times that way too. Seems to work either way. This way can help if for some reason the person can't balance the bike solely on the left leg (maybe incline partly goes to the left side and the person is short so bike would lean too far and fall over). |
November 2nd, 2011, 11:10 AM | #22 |
Join Date: Oct 2011 Motorcycle(s): 2004 Ninja 250F Posts: 308
I haven't been riding long, but in a hilly area this is something I've been doing quite a bit (that is, starting on hills). Here's what I've been doing:
1.) Hold the bike in place with the front brake, both feet on the ground. 2.) Slowly give throttle 3.) Release the clutch into the friction zone 4.) Let go of the front brake as you feel the clutch start to engage Is there anything wrong with that? Just thinking through it - the only issue I see is possibly burning the rear tire on the pavement, but that should never happen unless you're gun-ho on the throttle? |
November 2nd, 2011, 12:19 PM | #23 | |
November 2nd, 2011, 07:40 PM | #24 |
Evidently not . On my ride today I paused at a stop sign on a fairly steep hill in front of a bunch of high school football jocks. Took me a good four of five stalls before I actually got going . Had to rev the thing up to a good 6-7k before it wouldn't stall, but got a good round of applause when I made it!
I need more practice, but I'm glad to hear that the technique at least is right! |
November 2nd, 2011, 07:57 PM | #25 |
I've gotten better at hill starts as well. Something that may help is holding yourself stationary on a hill with just throttle and clutch. So say you're on a steep hill at a red light. When you see the other direction's light turn yellow, give it some gas and slightly engage the clutch while releasing the rear brake (and/or front) until you can hold yourself stationary. Then once your light turns green, give it a little more gas. Once you get going a little, you can slowly fully engage the clutch. Just be careful that you don't do this too soon before you want to go because it's bad for your bike. Once you get good, you can basically skip the step where you find the balance between throttle and clutch to keep you stationary, and be able to take off from a stop right away.
November 2nd, 2011, 08:04 PM | #26 |
Join Date: Oct 2011 Motorcycle(s): 250 Ninja - Soon Posts: 96
2.) Slowly give throttle 3.) Release the clutch into the friction zone 4.) Let go of the front brake as you feel the clutch start to engage 5.) add more throttle, and release the clutch your probably stalling because the load to get the bike is greater than what the engine is putting out, add throttle, and you should be good |
November 2nd, 2011, 08:20 PM | #27 |
The problem for me is that my bike jumps through the friction zone pretty fast. Once the clutch "catches" the bike stalls. I think I got out of it by giving it a lot of throttle initially, but it really caught me by surprise with how much I needed to give it (without trying to rocket away, of course).
Last futzed with by TBC; November 2nd, 2011 at 09:52 PM. Reason: missed a word |
November 2nd, 2011, 09:07 PM | #28 | |
Join Date: Oct 2011 Motorcycle(s): 2007 EX250F Posts: 70
November 11th, 2011, 01:57 PM | #29 |
Join Date: Dec 2010 Motorcycle(s): 2011 Triumph Bonneville T100, 2010 Ninja 250R SE (SOLD), 2002 Honda Rebel Posts: 62
I live in a very hilly area. As I come to a complete stop and I'm in first gear, I put my left foot down and hold the rear brake with my right foot. As I open the throttle and hit the friction zone with the clutch lever I lift my right foot off the rear brake lever and I'm moving. I have to do this dozens of times every time I go out. Like I said, lots and lots of hills - steep ones. I'm sure I'll stall it one day but so far, no stalls using this method.
November 12th, 2011, 06:47 PM | #30 |
November 13th, 2011, 05:16 PM | #31 |
i just pop it out to the friction zone give it 6k and slowly release from there. no brake needed
November 14th, 2011, 06:34 AM | #32 | |
1/4 English, 3/4 Kick Ass
Join Date: Sep 2011 Motorcycle(s): 2002 Triumph Speed Triple 955i, '05 Suzuki SV650S(retired), '11 Ninja 250R(sold) Posts: A lot.
Even with the corvette I drive, I have to add a good amount of gas to get it going. |
November 15th, 2011, 06:36 PM | #33 | |
Internet Slut
Join Date: Sep 2010 Motorcycle(s): 04 FZ1, 07 FZ6 Posts: A lot.
November 15th, 2011, 07:59 PM | #34 |
Join Date: Oct 2011 Motorcycle(s): 06 KLR 650,12 250 Ninja, 86 DR 125, 07 CRF 100, 09 Tomos Streetmate LEL Record Holder, 88 K100 RT Posts: 434
Here's my take on how to take off on a hill for newer rider. When you come to a stop put your left (clutch side) foot down and hold the front brake momentarily until you can rock your right (throttle side) foot up on your arch so as to put downward pressure with your toe on the rear brake lever. Once you have actuated the rear brake with your foot release the front brake. You should have a feel for the timing of the traffic lights and when you think it's just about to go green slowly slip the clutch lever until you just start to feel the clutch start to grab (barely). As the light turns green roll the throttle while easing the clutch lever applying slightly more throttle as you are letting the clutch out. Once you start forward release the rear brake. Although this may be contrary to what everyone else has said (and I don't disagree just respect) I feel for a newer rider it is easier not to have to release front brake and throttle almost simultaneously. Just worry about throttle in right hand and clutch in left hand. You will almost automatically release the brake becuase of the arching forward manner in which I asked you to apply the brake. After you are comfortable with this technique then you can move to using front brake technique. Good luck and be aware of what is going on around you when riding. JMOO
wardie |
Hill Takeoffs | Shadow Monarch | Riding Skills | 28 | January 21st, 2013 06:15 AM |
hill climb | jeppo83 | Videos | 2 | November 15th, 2012 10:11 PM |
[superbikeplanet.com] - King Of The Hill | Ninjette Newsbot | Motorcycling News | 0 | October 10th, 2011 12:50 PM |
Hey from Chapel Hill | njmetty | New Members | 9 | April 29th, 2010 02:08 PM |
UP hill mess up.. and weird after | Rafalski | Riding Skills | 4 | August 21st, 2009 11:15 AM |
