June 8th, 2023, 10:01 AM | #1 |
[cycleworld.com] - Kawasaki Announces New Graphics, Colors for 2024 KLX Models
A first look at the updated 2024 Kawasaki KLX lineup.
Click here to view on their site. Kawasaki announces new styling and colors for the 2024 KLX off-road lineup. (Kawasaki/)Kawasaki has updated the entire off-road KLX lineup for 2024 with new styling. The KLX300R, KLX230R, KLX140R, and KLX110R receive new colors and graphics to match the KX competition line. Additionally, Kawasaki updated its 300 dual sports, the KLX300 and KLX300SM with new colors and graphics as well as granting both models with an updated LED headlight. 2024 Kawasaki KLX300R ($6,199) The 2024 Kawasaki KLX300R is the flagship model in the KLX off-road lineup. Based on the dual sport variant, the KLX300R is essentially a stripped-down version of the KLX300. Utilizing the same 292cc fuel-injected DOHC liquid-cooled single-cylinder engine, semi-double-cradle frame, 43mm inverted telescopic fork, and Uni-Trak shock, both models share a nearly identical specs sheet. The 2024 Kawasaki KLX300R in Battle Gray ($6,199). (Kawasaki/)Additionally, the 2024 Kawasaki KLX300R features full-size off-road wheels (21-inch front, 18-inch rear), a six-speed transmission, and adjustable ergonomics. For 2024 the updated appearance of the KLX300R is available in Lime Green or Battle Gray. The 2024 Kawasaki KLX300R in Lime Green ($6,199). (Kawasaki/)2024 Kawasaki KLX230R ($5,049) The 2024 Kawasaki KLX230R is Team Green’s largest air-cooled off-road KLX. As seen in other KLX models, the 230R is the stripped-down off-road version of the KLX230 dual sport. Fitted with the same 233cc fuel-injected SOHC single-cylinder engine, six-speed transmission, 32mm Keihin throttle body, and high-tensile-steel box-section perimeter frame, both KLX230 models share many of the same parts. The 2024 Kawasaki KLX230R in Lime Green ($5,049). (Kawasaki/)As an off-road-only model, the 2024 Kawasaki KLX230R sports additional suspension travel over its dual sport sibling. Utilizing a 37mm telescopic fork offering 9.8 inches of travel plus Uni-Trak linkage and monoshock with 9.9 inches of suspension travel, the KLX230R has a seat height of 36.4 inches while the dual sport variety sits closer to the ground with a 34.8-inch seat height. Fitted with 21-inch front and 18-inch rear wheels, the KLX230R sports a full-size stance and opens the door to a wide range of tire options. The 2024 Kawasaki KLX230R in Battle Gray ($5,049). (Kawasaki/)Both KLX230 and KLX230R come in “S” variants (shorter seat height) for 2023, but have not been released as 2024 models. Currently only the KLX230R has received updated styling and colors for 2024, with the 2024 Kawasaki KLX230R available in Lime Green or Battle Gray. 2024 Kawasaki KLX140R ($3,649), KLX140R L ($3,949), KLX140R F ($4,249) Kawasaki offers the 2024 KLX140R in three variants. All three KLX140R models utilize the same 144cc SOHC air-cooled single-cylinder engine fed by a 20mm Keihin carburetor and five-speed transmission. The chassis is identical across the model range with a high-tensile-steel box-section perimeter frame, 1.5-gallon fuel tank, 220mm front disc with dual-piston caliper, and 186mm rear disc with single-piston caliper. Need more power? The KLX140R engine is 32cc larger than the KLX110R. (Kawasaki/)2024 Kawasaki KLX140R ($3,649) The KLX140R is the smallest of the three in terms of wheel size, seat height, and ground clearance. Fitted with a 17-inch front wheel and 14-inch rear, the 2024 Kawasaki KLX140R has a 30.7-inch seat height and 9.3 inches of ground clearance. The KLX140R utilizes a 33mm telescopic fork with 7.1 inches of travel and a Uni-Trak linkage and shock with five-way preload adjustability and 7.1 inches of travel. For 2024 the Kawasaki KLX140R is available in Lime Green or Battle Gray. The 2024 Kawasaki KLX140R in Battle Gray ($3,649). (Kawasaki/)2024 Kawasaki KLX140R L ($3,949) The KLX140R L is the midsize option in the KLX140 lineup. Featuring a 19-inch front wheel and 16-inch rear, the 2024 Kawasaki KLX140R L has a seat height of 31.5 inches and 10 inches of ground clearance. Running a 33mm telescopic fork and Uni-Trak linkage and shock with piggyback reservoir, fully adjustable preload and 22-way-adjustable rebound damping, the suspension offers 7.1 inches of travel front and rear. The 2024 Kawasaki KLX140R L is available in Lime Green or Battle Gray. The 2024 Kawasaki KLX140R L in Lime Green ($3,949). (Kawasaki/)2024 Kawasaki KLX140R F ($4,249) The KLX140R F is the largest of the three KLX140 models. Featuring full-size off-road wheels, the 2024 Kawasaki KLX140R F bridges the gap between the smaller KLX140 models and the more powerful KLX230R models. Fitted with 21-inch front and 18-inch rear wheels, the KLX140R F has a 33.9-inch seat height, 12.4 inches of ground clearance, and increased suspension travel. The 33mm telescopic fork offers 7.5 inches of travel while the Uni-Trak linkage and shock with 20-way-adjustable rebound damping and threaded preload adjustability provide 7.9 inches of travel. The 2024 Kawasaki KLX140R F is available in Lime Green and Battle Gray. The 2024 Kawasaki KLX140R F in Lime Green ($4,249). (Kawasaki/)2024 Kawasaki KLX110R ($2,849), KLX110R L ($3,049) Completing Kawasaki’s off-road KLX lineup are the 2024 KLX110R and KLX110R L. Both models feature the same 112cc SOHC air-cooled engine fed by an 18mm Keihin carburetor with a screw-type throttle limiter. Many of the chassis components are shared across both models, such as a 1.0-gallon fuel tank, 42.3-inch wheelbase, drum brakes, suspension components, and 14-inch/12-inch wheel sizes. The Kawasaki KLX110R is the start of a riders KLX journey. (Kawasaki/)2024 Kawasaki KLX110R ($2,849) The KLX110R is fitted with a 30mm hydraulic telescopic fork and a single hydraulic shock, both providing 4.3 inches of suspension travel. Sitting the lowest of all the KLX models, the KLX110R has a 26.8-inch seat height and provides 8.5 inches of ground clearance. The 2024 Kawasaki KLX140R in Lime Green ($2,849). (Kawasaki/)2024 Kawasaki KLX110R L ($3,049) What differentiates the KLX110R L from the smaller variant is increased suspension travel, ground clearance (10.4 inches), a taller seat height (28.7 inches), as well as a four-speed manual transmission with a clutch. Utilizing the same suspension components as the KLX110R, the larger KLX110R L offers 5.5 inches of travel up front and 5.2 inches in the rear. The 2024 Kawasaki KLX110R and KLX110R L are available in Lime Green and Battle Gray. The 2024 Kawasaki KLX140R L in Battle Gray ($3,049). (Kawasaki/)2024 Kawasaki KLX300R Specs MSRP:$6,199Engine:4-stroke single, DOHC, liquid-cooledDisplacement:292ccBore x Stroke:78.0 x 61.2mmCompression Ratio:11.1:1Transmission/Final Drive:6-speed/chainClaimed Horsepower:N/AClaimed Torque:N/AFuel System:DFI w/ 34mm Keihin throttle bodyClutch:Wet, multi-disc; manualEngine Management/Ignition:TCBI Electronic AdvanceFrame:Semi-double cradleFront Suspension:43mm inverted telescopic fork, compression damping adjustable; 10.0 in. travelRear Suspension:Uni-Track gas-charged shock w/ piggyback reservoir, compression, rebound damping, and spring preload adjustable; 9.1 in. travelFront Brake:2-piston caliper, 250mm discRear Brake:1-piston caliper, 240mm discWheels, Front/Rear:21 in./18 in.Tires, Front/Rear:3.0 x 21 / 4.6 x 18Rake/Trail26.7°/4.2 in.Wheelbase:56.5 in.Ground Clearance:10.8 in.Seat Height:35.2 in.Fuel Capacity:2.1 gal.Claimed Wet Weight:282 lb. / 287 lb. (CA model)Contact:kawasaki.com 2024 Kawasaki KLX230R Specs MSRP:$5,049Engine:SOHC, air-cooled, 4-stroke singleDisplacement:233ccBore x Stroke:67.0 x 66.6mmCompression Ratio:9.4:1Transmission/Final Drive:6-speed/chainClaimed Horsepower:N/AClaimed Torque:N/AFuel System:DFI w/ 32mm Keihin throttle bodyClutch:Wet, multi-disc; manualEngine Management/Ignition:TCBI Electronic AdvanceFrame:High-tensile steel, box-section perimeterFront Suspension:37mm telescopic fork; 9.8 in. travelRear Suspension:Uni-Track, single shock, spring preload adjustable; 9.9 in. travelFront Brake:2-piston caliper, 240mm discRear Brake:1-piston caliper, 240mm discWheels, Front/Rear:21 in./18 in.Tires, Front/Rear:80/100-21 / 100/100-18Rake/Trail26.5°/4.4 in.Wheelbase:53.5 in.Ground Clearance:11.8 in.Seat Height:36.4 in.Fuel Capacity:1.7 gal.Claimed Wet Weight:254 lb. / 262 lb. (CA model)Contact:kawasaki.com 2024 Kawasaki KLX140R Specs MSRP:$3,649Engine:SOHC, air-cooled, 4-stroke singleDisplacement:144ccBore x Stroke:58.0 x 54.4mmCompression Ratio:9.5:1Transmission/Final Drive:5-speed/chainClaimed Horsepower:N/AClaimed Torque:N/AFuel System:20mm Keihin carburetorClutch:Wet, multi-disc; manualEngine Management/Ignition:Digital DC-CDIFrame:High-tensile steel, box-section perimeterFront Suspension:33mm telescopic fork; 7.1 in. travelRear Suspension:Uni-Track, single shock, spring preload adjustable; 7.1 in. travelFront Brake:2-piston caliper, 220mm discRear Brake:1-piston caliper, 186mm discWheels, Front/Rear:17 in./14 in.Tires, Front/Rear:70/100-17 / 90/100-14Rake/Trail27.0°/3.3 in.Wheelbase:49.6 in.Ground Clearance:9.3 in.Seat Height:30.7 in.Fuel Capacity:1.5 gal.Claimed Wet Weight:205 lb.Contact:kawasaki.com 2024 Kawasaki KLX140R L Specs MSRP:$3,949Engine:SOHC, air-cooled, 4-stroke singleDisplacement:144ccBore x Stroke:58.0 x 54.4mmCompression Ratio:9.5:1Transmission/Final Drive:5-speed/chainClaimed Horsepower:N/AClaimed Torque:N/AFuel System:20mm Keihin carburetorClutch:Wet, multi-disc; manualEngine Management/Ignition:Digital DC-CDIFrame:High-tensile steel, box-section perimeterFront Suspension:33mm telescopic fork; 7.1 in. travelRear Suspension:Uni-Track, single shock w/ piggyback reservoir, spring preload, rebound damping adjustable; 7.1 in. travelFront Brake:2-piston caliper, 220mm discRear Brake:1-piston caliper, 186mm discWheels, Front/Rear:19 in./16 in.Tires, Front/Rear:70/100-19 / 90/100-16Rake/Trail27.0°/3.8 in.Wheelbase:50.6 in.Ground Clearance:10.0 in.Seat Height:31.5 in.Fuel Capacity:1.5 gal.Claimed Wet Weight:209 lb.Contact:kawasaki.com 2024 Kawasaki KLX140R F Specs MSRP:$4,249Engine:SOHC, air-cooled, 4-stroke singleDisplacement:144ccBore x Stroke:58.0 x 54.4mmCompression Ratio:9.5:1Transmission/Final Drive:5-speed/chainClaimed Horsepower:N/AClaimed Torque:N/AFuel System:20mm Keihin carburetorClutch:Wet, multi-disc; manual clutchEngine Management/Ignition:Digital DC-CDIFrame:High-tensile steel, box-section perimeterFront Suspension:33mm telescopic fork; 7.5 in. travelRear Suspension:Uni-Track, single shock w/ piggyback reservoir, 20-way rebound damping, spring preload adjustable; 7.9 in. travelFront Brake:2-piston caliper, 220mm discRear Brake:1-piston caliper, 186mm discWheels, Front/Rear:21 in./18 in.Tires, Front/Rear:2.75 x 21 / 4.10 x 18Rake/Trail27.0°/4.6 in.Wheelbase:52.4 in.Ground Clearance:12.4 in.Seat Height:33.9 in.Fuel Capacity:1.5 gal.Claimed Wet Weight:218 lb.Contact:kawasaki.com 2024 Kawasaki KLX110R Specs MSRP:$2,849Engine:SOHC, air-cooled, 4-stroke singleDisplacement:112ccBore x Stroke:53.0 x 50.6mmCompression Ratio:9.5:1Transmission/Final Drive:4-speed automatic centrifugal/chainClaimed Horsepower:N/AClaimed Torque:N/AFuel System:18mm Keihin carburetor and screw type throttle limiter on grip housingClutch:Wet, multi-discEngine Management/Ignition:Digital DC-CDIFrame:Backbone frame, high-tensile steelFront Suspension:30mm hydraulic telescopic fork; 4.3 in. travelRear Suspension:Single hydraulic shock; 4.3 in. travelFront Brake:Cable-actuated 90mm mechanical drumRear Brake:Rod-actuated 110mm mechanical drumWheels, Front/Rear:14 in./12 in.Tires, Front/Rear:2.50 x 14 / 3.00 x 12Rake/Trail24.8°/2.0 in.Wheelbase:42.3 in.Ground Clearance:8.5 in.Seat Height:26.8 in.Fuel Capacity:1.0 gal.Claimed Wet Weight:168 lb.Contact:kawasaki.com 2024 Kawasaki KLX110R L Specs MSRP:$3,049Engine:SOHC, air-cooled, 4-stroke singleDisplacement:112ccBore x Stroke:53.0 x 50.6mmCompression Ratio:9.5:1Transmission/Final Drive:4-speed/chainClaimed Horsepower:N/AClaimed Torque:N/AFuel System:18mm Keihin carburetor and screw type throttle limiter on grip housingClutch:Wet, multi-disc; manualEngine Management/Ignition:Digital DC-CDIFrame:Backbone frame, high-tensile steelFront Suspension:30mm hydraulic telescopic fork; 5.5 in. travelRear Suspension:Single hydraulic shock; 5.2 in. travelFront Brake:Cable-actuated 90mm mechanical drumRear Brake:Rod-actuated 110mm mechanical drumWheels, Front/Rear:14 in./12 in.Tires, Front/Rear:2.50 x 14 / 3.00 x 12Rake/Trail24.2°/1.9 in.Wheelbase:42.3 in.Ground Clearance:10.4 in.Seat Height:28.7 in.Fuel Capacity:1.0 gal.Claimed Wet Weight:168 lb.Contact:kawasaki.com
[cycleworld.com] - Kawasaki Announces the Return of the Eliminator for 2024 | Ninjette Newsbot | Motorcycling News | 0 | June 6th, 2023 04:30 PM |
[webbikeworld.com] - Kawasaki Announces 2021 Off-Road KLX and KX Models | Ninjette Newsbot | Motorcycling News | 0 | June 2nd, 2020 06:02 AM |
[RoadRUNNER] - Suzuki Announces Colors and Pricing for 2017 and 2018 Models | Ninjette Newsbot | Motorcycling News | 0 | January 14th, 2017 06:01 AM |
[motorcycledaily.com] - Suzuki Announces Colors and Prices on Several Models ? New GS | Ninjette Newsbot | Motorcycling News | 0 | January 13th, 2017 10:00 AM |
[sportrider - features] - BMW Announces New Colors For Some 2016 Models and Introduce | Ninjette Newsbot | Motorcycling News | 0 | July 6th, 2015 11:40 AM |
