June 8th, 2023, 11:00 AM | #1 |
[webbikeworld.com] - Husqvarna’s 2024 Enduro Range is Here
Click here for full story...
Remember when KTM’s refreshed 2024 EXC lineup came out with a doozy of new specs? Well, Husqvarna has just played a wee game of copycat, releasing a completely refreshed lineup of machines for 2024. The overhaul is a longer list than usual, so let’s dig in, yeah? To clarify, KTM’s 2024 EXC range is under the same parent company as Husqvarna (Pierer Mobility Group), so while we were kind of expecting this change, we weren’t sure how much new stuff Husqvarna’s TE/FE models would be getting. Imagine our delight when we see the bit below: New Stuff for the 2024 Husqvarna Enduro Range
A chromium-molybdenum steel chassis improves resistance to compression (anti-squat equations) and gives riders a new type of flex under the caboose.* Subframe Durability has been improved with this hybrid subframe, thanks ot the use of both polyamide and reinforced aluminum – both of which beef up agility and “straight-line stability” without compromising on material strength. Bodywork Graphics (influenced by the Swedes) aids the preferred rider ergonomics, with the fairings themselves boasting a leaner design than the marque’s last bout of changes.* (Accompanying the aesthetics is a new high-grip seat – a similar idea as the unit we find in KTM’s EXC range.) Suspension Enduro-specific WP XACT Closed Cartridge spring forks, complete with mid-valve piston and “a hydrostop in the final 68 mm of travel” dress the front, while a redesigned WP XACT shock (100 g lighter and 15 mm shorter) garbs the back of the bikes. Both ends are fully adjustable by hand. Brakes BRAKTEC brakes with high-performance GSK discs dress Husqie’s rolling duties, improving handling and setting stoppage to a higher level of competition than the previous units. Advanced Electronics
A combined start/stop button, electric starter, ProTaper handlebars with ODI Grips, and Michelin enduro rubber complete the ensemble, which 3brosKTM tells us sells for the following price points: 2024 Husqvarna Enduro Range Prices 2024 Husqvarna TE 150 MSRP $10,199 USD 2024 Husqvarna TE 250 MSRP $11,249 USD 2024 Husqvarna*TE 300 MSRP $11,549 USD 2024 Husqvarna FE 250 MSRP $10,299 USD 2024 Husqvarna FE 350 MSRP $11,749 USD 2024 Husqvarna FE 450 MSRP $12,099 USD 2024 Husqvarna FE 501 MSRP $13,049 USD A view of Husqvarna’s updated 2024 Enduro range. Media sourced from Husqvarna.What do you think of Husqvarna’s new 2024 Enduro range? *Media source from Husqvarna* The post Husqvarna’s 2024 Enduro Range is Here appeared first on webBikeWorld.
[RideApart] - Husqvarna Releases Major Updates To 2024 Enduro Range | Ninjette Newsbot | Motorcycling News | 0 | June 7th, 2023 07:12 PM |
[RideApart] - Beta Gives Its 2024 Enduro Range Minor Tweaks | Ninjette Newsbot | Motorcycling News | 0 | June 5th, 2023 05:43 AM |
[RideApart] - 2024 KTM EXC Enduro Range Gets A Bunch Of Updates To Help You Send It | Ninjette Newsbot | Motorcycling News | 0 | May 25th, 2023 08:45 AM |
[visordown.com] - 2024 KTM EXC enduro range launched with updated frame, suspension | Ninjette Newsbot | Motorcycling News | 0 | May 25th, 2023 04:01 AM |
[webbikeworld.com] - Husqvarna?s 2024 MX Range | Ninjette Newsbot | Motorcycling News | 0 | May 1st, 2023 11:28 AM |
