Old June 21st, 2011, 08:14 PM   #1
Donnyd21
Motorcycle(s): 2008 250R
Brake light housing question....
Why is it that after I pullmy seat off I can see 2 holes on the left and right side of the brake light housing that are empty? Are there supposed to be brake lights there? i only have one light in the center...
Donnyd21 is offline   Reply With Quote
Old June 21st, 2011, 08:26 PM   #2
road_rascal
Motorcycle(s): ___
Here ya go. I plan on doing this soon.
road_rascal is offline   Reply With Quote
Old June 21st, 2011, 08:28 PM   #3
Donnyd21
Im going to do that tomorrow
Old June 21st, 2011, 08:47 PM   #4
Snake
Snake's Avatar
This mod makes the tail look wider and makes the rear more visible.
Old June 22nd, 2011, 05:54 AM   #5
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
As to the why, in other countries the outer assemblies were for turn signals. In the US there's a minimum distance from the center of the brake light bulb to the center of the turn signal bulb, and the stock housings are too close to qualify. So, they were left empty and turn signals on stalks were added. The red lenses were left in so that it wouldn't look funny.
Old June 22nd, 2011, 06:31 AM   #6
whiteboy
whiteboy's Avatar
Motorcycle(s): 2009 blue ninja 250r
Awsome mod doing this today and hope it lasts me till I get the integrated system
If you’re going to lead, then lead. If you’re going to follow, get the hell out of my way!
whiteboy is offline   Reply With Quote
Old June 22nd, 2011, 10:41 AM   #7
M
Motorcycle(s): Ninja 250 x2, Ninja 650R
Here's my actual installation that expands on the FAQ pictures and narrative:
http://forums.ninja250.org/viewtopic.php?t=62619
The Rally - Oklahoma
M is offline   Reply With Quote
Old June 22nd, 2011, 11:23 AM   #8
Donnyd21
Just got done doing it, took me a hour start to finish and $11 in parts from Autozone, I had to buy the 2 wire sockets (#85803) instead of the 3 wire as they had to order the 3 wire, if you guys can get the 3 wire do that (#84725) as I spent a good while trying to get the solider to stick to the 2 wire socket for a ground, I used 2397 bulbs for the outsides instead of 1157's, the 2397's use a tad less energy than the 1157's, I also used some 5 min epoxy to keep the sockets from falling out of the housing even tho they fit nicely into the stock housing without having to cut or trim anything, bulb replacement is easy if they go out just like the center bulb, just remove the cover. Looks way better now, a LOT brighter even in the day time, WELL worth the money, I get my 15T front sprocket coming in tomorrow so ill be back into the bike again.
Old June 22nd, 2011, 11:26 AM   #9
road_rascal
Motorcycle(s): ___
Nice install writeup. I'm going the local auto parts store tomorrow and get the 3 wire sockets.
Old June 22nd, 2011, 01:22 PM   #10
greg737
Motorcycle(s): -
Warning: If you put incandescent lights in the two empty brake housings you'll be back on the forum asking why your headlight and instrument cluster go dim when you're idling at a stoplight.
Incandescent lights = drawing lots of watts
LEDs = drawing next to nothing
The EX-250 produces about 180 to 200 watts of power (even at idle). The reason for the variable range of the estimate is that some rotors are better than others (i.e. the magnets installed in the rotor are of variable quality and can be damaged/degraded during handling/installation if the rotor is dropped or even bumped hard).
The EX-250 in stock condition uses about 120 watts of power (out of the estimated 180 to 200 watts available). So you've only got 60 to 80 watts to play with when you're adding lights and farkles.
Old June 22nd, 2011, 02:30 PM   #11
Snake
Snake's Avatar
Justin, this mod applies to the pre-gen models.
Old June 22nd, 2011, 02:34 PM   #12
Snake
Snake's Avatar
Great point Greg. The same thing happened to me when I did the mod and put filament type bulbs in. The instrument panel would go dim when I came to a stop and especialy whilth the brake lights on. I switched all three to led's with less power drain and brighter than stock. A real plus plus.
Old June 22nd, 2011, 05:01 PM   #13
Donnyd21
Where can I get LED lights that will fit into the housing??
I just bought another brake housing, I am going to wire this all up nice so its plug and play and throw it up on ebay.
Old June 22nd, 2011, 05:29 PM   #14
Snake
Snake's Avatar
Most auto parts stores should have them I bought mine from Dennis Kirk.
Old June 22nd, 2011, 05:32 PM   #15
Donnyd21
I mean a LED light that will fit into the OEM socket or will they have to be re-wired and custom installed into the housing? Got any links?
Old June 22nd, 2011, 05:40 PM   #16
Snake
Snake's Avatar
www.denniskirk.com
They sell led lights that fit in the stock sockets.
Old June 22nd, 2011, 08:36 PM   #17
Donnyd21
You guys were right, I am getting dimming with brake lights applied, just ordered 1157 type LED lights.
Old June 23rd, 2011, 12:07 PM   #18
road_rascal
Motorcycle(s): ___
My search for the 3 wire socket (84725) is turning up zilch. Nobody in the MN metro area has one, plus Carquest says that it looks like Dorman may be discontinuing the socket as they don't have that part number in their system. Is does cross over to a Standard (brand?) 57-4845 and they only have one in Kansas City. I may have to order them online. Plus none of the local MC shops carry any of the LED 1157 bulbs- all special order. I was hoping to do this mod over the weekend.
Old June 23rd, 2011, 02:25 PM   #19
Snake
Snake's Avatar
We speak from experience Grass Hopper.
Old June 23rd, 2011, 02:47 PM   #20
road_rascal
Motorcycle(s): ___
Ok- looks like I found another option at the parts store. Dorman #85860 fits pretty well. All I had to do was Dremel a little notch on the side to allow the ground wire tab to stick through. Then I can fill hole/gap/whatever with 30 minute epoxy to secure it in. I may cut off the six tabs around the socket as they're really not needed. Hopefully I'll have this wrapped up by Sunday.
Old June 23rd, 2011, 05:59 PM   #21
Donnyd21
^Those will work, I ordered some 1157 LED's off ebay yesterday.
Old June 24th, 2011, 09:40 AM   #22
road_rascal
Motorcycle(s): ___
Got 'er done this morning. The job went much better than I expected. Lots of light in the rear now. I used 3mm bullet connectors (soldered) instead of crimp (I have a ton of bullet connectors) and shrink wrap. Nice and neat. I also used 2397 bulbs in the pods. I'll probably swap them out with LED's whenever I get a chance.
Rear Brake Doesn't activate Brake Light And DOT3/4 FRONT BRAKE OIL coelgrim 2008 - 2012 Ninja 250R Tech Talk 16 March 11th, 2013 05:10 PM
stupid question about brake light housing... poo poo 2008 - 2012 Ninja 250R Tech Talk 16 March 10th, 2010 06:24 PM
