Old August 27th, 2011, 07:09 PM   #1
Sicafied
Motorcycle(s): Ninja 250r
Is this safe? (nail damage in tire)
Hey guys, new rider here. Had my 250r for a few months now and I noticed a huge nail in my rear tire. After riding for a few days, I noticed that the nail was gone, and the hole is filled up with something. Is it possible to fix the tire or should I replace it? Also, is it safe to keep riding with the tire in this condition? Thanks.
Sicafied is offline   Reply With Quote
Old August 27th, 2011, 07:25 PM   #2
TheMojoRider
Motorcycle(s): Ninja!
I wouldn't recommend riding it as is since you don't know what this is and when it will let go. My general rule is I will plug and ride with a tire if the hole is towards the middle and replace the tire if the hole is on the sides.
TheMojoRider is offline   Reply With Quote
Old August 27th, 2011, 07:28 PM   #3
Sicafied
Thanks for the response, where can I get these plugs?
Old August 27th, 2011, 07:32 PM   #4
gfloyd2002
User Title Free Since '12
gfloyd2002's Avatar
Motorcycle(s): '10 Ninja 250R Special Edition Green
MOTM - Feb '12
Not safe. You can ride with a plug if it is in the right place towards the center, but even that creates some debate. People don't like to mess around with repaired tires on motorcycles when the stakes are so high. Magical self-healing nail hole isn't a close call at all though - change the tire right away. You are asking for a very fast loss of air pressure at speed. I've had a blowout on a motorcycle, and let me tell you that it is NOT fun. Not something you want to mess around with when your life is at stake.
"Improvement makes straight roads, but the crooked roads without improvement, are roads of genius." — William Blake
gfloyd2002 is offline   Reply With Quote
Old August 27th, 2011, 07:39 PM   #5
TheMojoRider
Kragen, Pep Boys, etc. Any car store and even some hardware stores. Hard to tell how big it is but would recommend replacing the tire if the hole is very big. I only plug small holes. If you decide to put a plug in it, keep an eye on your pressure for a few days and see if it is still consistent. I also check a plugged tire more regularly, though tire pressures are set nearly before every ride. Yes, tires are THAT important.
Old August 27th, 2011, 07:44 PM   #6
TXJ
Cranky Old Fart
TXJ's Avatar
Motorcycle(s): 08 DRZ400SM
I'd replace it. Consider the cost of a new tire vs the road grime in it now (probably w/ the nail still in there) popping out and creating a dangerous situation, and the peace of mind knowing your tire is safe.
It's probably losing pressure, have you been monitoring it daily?
You can get tire plug kits pretty much anywhere. Amazon has them for $8 or so. Any auto parts store, walmart etc would stock slime plug kits as well. But my vote is still to just replace the tire.
I have plugged tires before, it's a safe repair. But it makes me extremely paranoid. I only ride on a plugged tire if I don't have a extra one while waiting until a new one arrives.
TXJ is offline   Reply With Quote
Old August 27th, 2011, 07:49 PM   #7
HKr1
IC2(SW)
HKr1's Avatar
Nail's gone and something is in the hole...... Whats in the hole??
Old August 27th, 2011, 07:50 PM   #8
Sicafied
I'm thinking of playing it safe and just replacing the tires. I don't know how the nail came out though, it was nailed in there pretty hard lol. How much would a new set of tires cost? And how much would it cost to have a mechanic put them on? Thanks again everyone
Old August 27th, 2011, 07:50 PM   #9
Sicafied
I'm not sure, i tried prying it out but its pretty sticky.
Old August 27th, 2011, 07:59 PM   #10
TheMojoRider
Whats in the hole??
The fourth dimension
Old August 27th, 2011, 08:05 PM   #11
AeroXtasy
New 2-Wheel Addict
AeroXtasy's Avatar
Motorcycle(s): Blue 2009 250r Kawasaki Ninja
I believe that's your best bet! I'm not sure about either of your other questions for sure, so I'll leave that to be answered by others that are more knowledgeable.
AeroXtasy is offline   Reply With Quote
Old August 28th, 2011, 06:39 PM   #12
Sicafied
Hey guys, after taking a closer inspection i've realized that the hole is actually filled in with a plug. I'm not sure how that happened though, must've been one of the guys at my university o:
Nail Polish on rear tire -- damaging? corksil General Motorcycling Discussion 51 April 28th, 2015 04:20 AM
I'm on the road and I got a nail in my tire SSG54 General Motorcycling Discussion 5 July 18th, 2013 07:07 AM
Nail In My Tire! gilmorec61 2008 - 2012 Ninja 250R Tech Talk 18 February 9th, 2012 06:03 PM
Will changing a tire damage wheel stripes? headshrink 2008 - 2012 Ninja 250R Tech Talk 4 November 27th, 2009 07:21 AM
Nail Question BlueTyke General Motorcycling Discussion 9 March 8th, 2009 02:47 PM
