May 21st, 2013, 03:05 PM | #401 |
Board Member
nothing has been found wrong so far. In fact everything they have checked they said I did it correctly. However they did say that I should've replaced the cam sprockets when I replaced the cam chain and that the cam chain was riding a little high on the sprockets due to this. Therefore I'm going to have them replace the cam sprockets but I don't think that's the issue its just preventative. We'll see what they come up with. They're going to keep working on it.
May 21st, 2013, 03:06 PM | #402 |
Board Member
They too wonder about the tight spots when turning the crank. They are looking into the bottom end.
May 21st, 2013, 06:22 PM | #403 |
Join Date: Mar 2012 Motorcycle(s): Ninja 250r 2010 SE Posts: 573
after putting mine together I would say that if there is tight spots without the cams installed than there is a problem. Before I installed the cams there wasn't anymore resistance anywhere.
May 21st, 2013, 07:23 PM | #404 |
Board Member
Do you think its possible that the valve springs given to me are too strong and somehow causing this? Any chance someone has stock cams they are willing to give or sell me?
So far the dealer has no definite idea. They will continue all day tomorrow again.... |
May 21st, 2013, 07:37 PM | #405 | |
Try Ebay for camshafts, also you can find stock springs on there for cheap as. I think I found my problem. Can anyone tell me if the smaller second hole faces the front or back of the bike. It is the vacuum piston out of the carb. |
May 21st, 2013, 07:55 PM | #406 |
dirty boy
MOTM - Apr '14
^ not sure how much it matters but the original larger vac hole is on the side closest to the engine, NOT the side closest to the airbox. Do you even have another hole drilled in the slide? i can't see it. But yeah, hole goes towards engine
May 21st, 2013, 08:01 PM | #407 | |
dirty boy
MOTM - Apr '14
What are your current jetting settings? |
May 21st, 2013, 10:09 PM | #408 |
I solved the problem. I think one of the boots was installed incorrectly.
The rings are sealed. It has stop smoking. I was a bit worried at first because it was smoking like crazy. When you rev the bike, the revs drop below idle then return to idle after about 2 seconds. I spoke to my tuner today. I am dropping it off tomorrow to get it sorted. I'll post the dyno results along with a video. |
May 21st, 2013, 11:05 PM | #409 |
MOTM - Sep '18, Feb '16
Drilling a second small hole next to the large one will make the slide move faster. It will only go in the carb one way.
The valve springs can't be causing a no start. Can they?
May 22nd, 2013, 03:37 AM | #410 | |
I don't think the valve springs are the problem with Mike's bike. I was thinking before that in theory I guess the camshafts would only output a certain amount of force. If the seat pressure created by the spring was higher then normal it could cause them to only open part of the way or not at all also causing the timing to be out. But how would the camshafts spin if they could not open the valves. I really have no clue why. If you have oil pressure, compression, correct timing and valve clearance, spark and fuel I have no idea. |
May 22nd, 2013, 04:00 AM | #411 |
The thing about machines is. The answers always come.
May 22nd, 2013, 04:35 AM | #412 | |
Board Member
May 22nd, 2013, 04:39 AM | #413 |
will be very interesting to see what it is.
I have a question.I just pulled a spark plug and it black as all f***. How many Jet sizes should I go down if it is so rich that it stalls? 1 or 2. I can't even make it around the block. I am running a 40 pilot and 115 main, 2 washer under each needle. I'm pretty sure when I removed a washer it help a lot. It idles well, just doesn't handle throttle. I am thinking 110 main, back the pilot screw back 1 turn. |
May 22nd, 2013, 04:46 AM | #414 |
110 for start
May 22nd, 2013, 06:01 AM | #415 |
Board Member
could I be giving it too much fuel to start?
42 pilot FP needle 4th position 118 mains screws out 2.5 turns |
May 22nd, 2013, 06:01 AM | #416 |
Board Member
everyone told me to go richer....but I think it would still start....just run bad.
May 22nd, 2013, 06:32 AM | #417 | |
Pretty much any mixture of fuel and air when compressed will explode and start the thing. If you tried starting fluid and it didn't start the jetting won't matter. There's no harm in trying but. If you can get a 40 pilot and a smaller main then maybe try that and see if it works. |
May 22nd, 2013, 06:33 AM | #418 |
Join Date: Jan 2012 Motorcycle(s): Race bikes:08 Ninja 250,11 R6,16 ZX6,SV650.3 HD-1947,2-2003,2010. 1946 Indian and a lot of dirt bikes.2 Posts: 999
42 pilot is too big/rich. remember your port work and large bores have little to do with pistons moving at a slow speed. The amount of air the throttle blade allows in, at idle, is the same as on your stock engine while cranking to start.
May 22nd, 2013, 06:38 AM | #419 | |
dirty boy
MOTM - Apr '14
As far as your jetting again once you start changing one circuit others will run differently as well. I have practically a blog about my jetting over the past 2 weeks here http://www.ninjette.org/forums/showthread.php?t=131399 if TL-DR here is summary On a stock engine, with pod filter, block off plate, full race exhaust, and BRT tis programmable advanced timing I started at 40 pilot, 3 washers under needles, and 115 main. WOT was rich, mid throttle felt ok, idle and 1/8th was good. I had 118 main, threw it in for fun. Bike still ran, WOT was very rich, mid throttle felt good, 1/8 throttle felt fine. Ordered and went to 112 main and my mid throttle was lean WOT was improved, Shimmed with 5 washers ~0.125" raised height with 5 washers and i also put in 110 main jets. 1/2 throttle feels great, WOT still feels slightly rich but much improved up to 12k rpms but leans out after that. But now my 1/8th throttle is rich. Going down to #38 pilot and probably 108 mains next weekend Sounds like your main is rich but hard to tell with out me riding it and with a rich main your mid throttle and revs can feel decent as the rich main has some overlap with the mid throttle and mid rev response. Perhaps why removing the washer felt better, because the rich main has the mid throttle slightly rich as well. So once you start going more lean with the main jet you will notice your mid throttle will start to suffer and lean out and you will have to go back in and most likely add washers to get it back to where it needs to be. Once you add washers you will also notice that your 1/8 throttle is suffering because it is to rich because of new needle height. You will then have to go down a pilot jet. See how it all feels again and with any luck good. Set idle mixture screws and you should be gold! |
May 22nd, 2013, 06:49 AM | #420 | |
I am going to go back to the settings for a stock engine/no airbox. 110 main, 2 washers and turn the pilot screws back 1 turn to about 1 1/2 turns out. I think this will help a lot. If I can get it just about right I can take it to get tuned. Will save me some cash. |
May 22nd, 2013, 07:20 AM | #421 |
[QUOTE=tubarney;688295]Thats what I'm thinking. Also the longer duration cams are going to pull less air through the engine at low revs than the standard cams due to lack to intake pressure.
Brad, I love talking engines, so take this lightly, I'm not challenging your opinion. More cam duration will allow more valve open time, increasing the amount of air that the atmospheric pressure can push into the cylinder. This is especially true at lower engine speeds. Its the cam timing and overlap that will effect the actual cylinder filling. As far as intake pressure, it is always whatever atmospheric pressure is on a given day and regulated into the engine by the throttle valve. |
May 22nd, 2013, 08:05 AM | #422 | |
Board Member
[QUOTE=bruce71198;688306]
I have been way off on jetting before and things still started! |
May 22nd, 2013, 08:38 AM | #423 | |
[QUOTE=mgentz;688323]
These carburetors are by far the pickiest I have ever worked on ! I highly recomend CR's. |
May 22nd, 2013, 10:52 AM | #424 |
I love the CR carb. But if it won't start with starting fluid there is something wrong outside the carb tune.
May 22nd, 2013, 12:49 PM | #425 |
May 22nd, 2013, 01:13 PM | #426 |
Board Member
Update. Upon one of their attempts at starting the bike it backfired hard enough to break teeth off the bronze starting gear. The tech had told me that they already tried to "loosen" the gear because they thought it was hanging up and that this confirms it. I think he's partially right because it is supposed to free spin in that direction...but....
It would be weird if this is what is causing the failure to start. The thought is that if this is hanging up, it could be putting too much resistance on the motor. Still investigating everything. .. |
May 22nd, 2013, 02:54 PM | #427 | |
the arm chair thing is fun when its not your head banging on the floor. LOL Mike I feel your pain. In 2010 I was running in the top ten in the points championship at Maxton. I blew a hole in my piston really good. I had three weeks to turn the bike around and race again. I replaced the top end of the motor and it would not start, I tried everything. Took the motor apart five times.I was up till four AM. I figured I bent the crank and the pick up was shifted, I have a motor 150 miles away. I figured I would get a couple hours sleep and drive 300 mile and go get it. When I came to bed I took a shower. But fifteen hours of fooling around with gasoline will not just wash off. I said to my wife I was sorry about the smell, She said what smell? Gas that has no smell will not burn. I ran to the garage. Sure enough I was using six month old race gas. The new fuel was in a cooler. The fuel I was using was in a matching can from under the work bench. I sprayed some new fuel in the engine and it fired right up.
May 22nd, 2013, 02:57 PM | #428 | |
May 22nd, 2013, 03:14 PM | #429 |
Board Member
It starts and instantly dies
May 22nd, 2013, 04:48 PM | #430 |
Then what? Can you repeat that over and over ? Is it like it just runs till you let go of the starter button ? It will it sputter any after you let go of the starter button?
May 22nd, 2013, 05:04 PM | #431 |
Board Member
my best description is that it will run with the starter button. it will also run with the starter button and spin up to 3000 rpm and then die. I can do this again and again.
May 22nd, 2013, 07:53 PM | #432 |
When I started my bike that was the issue I was having and then I kept giving it some throttle to keep it running until it could stay running without throttle. My exhaust ports are all gummed up with carbon/oil right now.
May 22nd, 2013, 09:24 PM | #433 | |
With the longer duration cams. Your intake and exhaust valve is kept open for a longer period of time which in turn drops cylinder pressure and hence intake pressure at all revs. At high revs the late intake closing helps because there is enough intake pressure to generate enough momentum on the intake air/fuel to fill the cylinder even though the piston is rising in the cylinder. At low revs there is not enough pressure, hence the intake air/fuel does not have enough momentum so therefore gets pushed back out the intake. It is not the amount of the air/fuel that passes through the carb that is important; this does not change much at. It is the amont of air/fuel that gets trapped in the combustion chamber. It has to do with the way air reacts in a cylinder head. its one of the reason a longer duration cam will hurt your idle. A longer duration cam does not give you more power a low revs than a shorter duration if they have the same lift. Basically you make more a high rpm, but less at low rpm. If this was a car engine, try getting a 280 degree cam to run well below 4k. Its not gonna happen. Only difference between the ninja and a car engine is the rev limit which is why I can run one. the 14k rpm limit helps to generate enough cylinder pressure. You don't need bigger jets because of a longer duration camshaft. If anything you need to lean the idle out while keeping the mains rich. Only to help with idle and low rev performance Last futzed with by tubarney; May 23rd, 2013 at 05:30 AM. |
May 22nd, 2013, 09:28 PM | #434 |
Better than nothing
What valve clearances are you running. I'm using .15mm-.19mm intake and .20mm-.24mm exhaust. Last futzed with by tubarney; May 23rd, 2013 at 05:31 AM. |
May 22nd, 2013, 09:36 PM | #435 |
Also, checking your sparks plugs works on 4 strokes the same as it does on 2 strokes. The only difference between the 2 is the way air enters and leaves the combustion chamber. Other than the fact 2 strokes fires 2 times for every 4 stroke spark.
May 22nd, 2013, 10:20 PM | #436 |
I changed to 110 main. My pilot screws were not even so I fixed them. They are 1 1/2 turns out.
It goes a lot better now. At least I can ride it to the dyno now. I can tell if has a lot more power than before. It pulls hard with very little throttle. I will try to get to the dyno tomorrow for a tune, might have to wait till Monday. Last futzed with by tubarney; May 23rd, 2013 at 05:17 AM. |
May 23rd, 2013, 01:17 PM | #437 |
Board Member
New update: dealer believes the motion pro switch was installed wrong. I have asked jason for his help.
Also when it runs he says there is a lot of top end noise. @tubarney did yours make a lot of noise on startup? I cannot imagine why but by now it might need oil!! |
May 23rd, 2013, 03:39 PM | #438 |
Fast-Guy wannabe
MOTM - Jan '13
I'll trace the motion pro wires but only if you still need me to. There's no point in tearing my bike apart if you don't still need me to.
May 24th, 2013, 12:28 AM | #439 | |
I took it for a good half hour ride today to break it in. It was still smoking a little as of yesterday but it has completely stopped now. No leaks, no lights, same amount of oil as before. Dyno Monday 27th May. Last futzed with by tubarney; May 24th, 2013 at 09:53 PM. |
May 24th, 2013, 10:32 PM | #440 |
I took it for another ride today. Absolutely thrashed it and it was fine.
The noise from the head is still there. Hopefully it will goes away when I change the oil tomorrow. I'm thinking it will because it sounds exactly the same as noisy lifters and if you have seen the oil inside it, it is all black and weird from the the assembly paste, so some clean oil should fix the problem. You want to change your oil after a couple of rides. Basically all the metal particles that are going to break off are going to do so in the first hour or 2 of operation. Also, the brand new camshafts are coated in nitride to help oil stick to them. This has to break off and wear away so your oil is going to be full of it. Here's what it sounds like. The engine is sort of cold so I didn't want to give it much throttle. I still have the stock gauges, I'll get around the koso install after I'm done stuffing around with the engine. http://www.youtube.com/watch?v=XDbO7eESBJ8 |
Shin's 250r Build Thread | Shintoxica | 1986 - 2007 Ninja 250R Farkles | 3 | August 22nd, 2013 11:10 AM |
My 250R Race Bike Build | icbm | Pictures | 5 | August 16th, 2012 11:06 AM |
Is the ninja 250r the ultimate beginner bike, or should I settle for something else? | Mulholland | General Motorcycling Discussion | 188 | April 15th, 2012 09:28 PM |
[topix.net] - Freestyler Josh Borne guest stars on Discovery's Ultimate Car Build Off | Ninjette Newsbot | Motorcycling News | 0 | June 25th, 2010 07:50 AM |
I want to buy or build an 08+ 250R racer. | Seanslides | Ninjettes At Speed | 20 | March 1st, 2010 07:34 AM |
