Old December 17th, 2012, 07:57 AM   #1
kaybray
Motorcycle(s): 2009 ninja 250r
Front Sprocket Gunk?
Hello. This is rather new to me, but i'm sure familiar with all of you. I use Motul chain clean and lube. I lube my chain regularly, but notice the front sprocket has so much black gunk....me thinks I should clean it out (2009 250r around 6000 miles).
Can someone recommend an effective degreaser or any other spray I can use? Is this difficult to do? Someone must know of an easy method to clean this? Thanks guys.
kaybray is offline   Reply With Quote
Old December 17th, 2012, 08:11 AM   #2
k-os
Mineral Spirits works great for de-greasing and cleaning. Kerosene works just as well.
Old December 17th, 2012, 08:27 AM   #3
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
^this in a spay bottle + this
Old December 17th, 2012, 09:20 AM   #4
Originally Posted by kaybray View Post
......Can someone recommend an effective degreaser or any other spray I can use?.....
http://www.webbikeworld.com/r3/motor...chain-cleaner/
Personally, I love the old trusty paint brush plus kerosene.
Old December 17th, 2012, 10:11 PM   #5
kaybray
thanks. how about the cover? is that easy to come off or other components have to be removed too?
Old December 17th, 2012, 10:26 PM   #6
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Get a marker and mark the shift lever location the use a 10mm wrench and remove the shifter at the motor shaft(it going through the cover you want to remove). Then use an 8mm socket to remove the three bolts that hold on the cover, WARNING be sure not to lose the TWO dowl pins that locate the cover.
It's super easy
Old December 18th, 2012, 12:18 PM   #7
bdavison
Wartown, USA
bdavison's Avatar
Yeah, I just take the cover off, and use a plastic paint scraper to scrap all the crud out, and then slap it back on there. No sense in getting spotless with it...its just gonna crud up again.
Old December 20th, 2012, 09:34 PM   #8
CZroe
CZroe's Avatar
Took my cover off and pulled out a ton of gunk with a rag then flooded it with WD-40.
Old December 20th, 2012, 11:25 PM   #9
Jono
Jono's Avatar
+1
Old December 27th, 2012, 07:09 PM   #10
Liquidtoon
Liquidtoon's Avatar
Motorcycle(s): 09 Ninja 250r
I use gojo hand cleaner and add most of bottle to a bucket. stir it into just enough water to submerse the cover. let it sit, over night if you can. then a little rubbing with rag and rinse does great. can toss chain in too, sprocket if you're super ambitious. Just be sure to re-lube it when done.
Liquidtoon is offline   Reply With Quote
Old January 1st, 2013, 10:41 PM   #11
Old Guy on a '08
Chris
Old Guy on a '08's Avatar
Motorcycle(s): BLACK!!! '08 250R
Back in the day, I used "GUNK" on gunk and the rest of the bike to, chrome, engine. Back then it came in a quart can and you sqirted a good bit in a cup and used a brush like the one pictured above. Today you can get it in a spray can.
It nails grease, it's got a wonderful smell and you can rinse it off with cold water.
Some roads are too good to waste on four wheels!
Riding in a car is like watching a movie...
Riding on a motorcycle is like being in one....
Old Guy on a '08 is offline   Reply With Quote
Old April 8th, 2013, 09:29 AM   #12
kaybray
cleaning was no problem, but the cleaning solvent erased the marked location of the clutch lever. It shifts ok, but feels different than last year. That lever position simply raises and lowers the position that's all right? so, really it's just rider preference whether lever is higher or lower?
Old April 8th, 2013, 10:32 AM   #13
Liquidtoon
Liquidtoon's Avatar
Yes with-in reason, to low or high makes miss shifts or accidental ones more likely. It is very easy to adjust, loosen the two nuts and rotate the bar then snug the nuts back down. Takes about 5mins and makes makes it more comfortable.
A link for pictures and better details
Old November 2nd, 2013, 01:47 AM   #14
ninjawing
Motorcycle(s): kawasaki
hi peepz!
so i been reading this thread and i have same problem as most...with a little twist. i have a ton of crap build up at my front sprocket, and me want to get it clean.
HOWEVER
the sprocket cover bolts and shifter is removed... but the cover is not moving and inch. its stuck like someone clued it on there
does anyone have some tips for me how i could get it off
ninjawing is offline   Reply With Quote
Old November 2nd, 2013, 06:19 AM   #15
red5
red5's Avatar
Motorcycle(s): 09 ninja 15.256
If you removed the three bolts and the little lever from the shift rod, then dowel pins are stuck. Try using WD-40 to loosen them. As you look at the cover, one is on the bottom right corner and the other is top left, just below that round hole/divot in the cover. Spray between the cover and the engine case and it should get in there.
"We're not always doing business, but we're always open."
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." Carl Sagan
red5 is offline   Reply With Quote
15 tooth front sprocket sidekick10121 1986 - 2007 Ninja 250R Tech Talk 3 March 16th, 2014 01:04 PM
Front sprocket change help! RedNinja21 2008 - 2012 Ninja 250R Tech Talk 35 April 12th, 2012 09:28 AM
Front Sprocket Archerzz 1986 - 2007 Ninja 250R Tech Talk 66 June 29th, 2011 10:22 AM
Front sprocket, help!! cbowman78 2008 - 2012 Ninja 250R Tech Talk 34 November 14th, 2010 10:52 AM
front sprocket miniguns167 2008 - 2012 Ninja 250R Tech Talk 4 September 27th, 2009 11:59 AM
