October 15th, 2014, 10:53 PM | #41 | |
another option is a tank bag, I have the rapid transit recon19L, it's magnetic, and converts into a backpack with the supplied straps. Hope this helps. |
October 15th, 2014, 11:03 PM | #42 |
Join Date: Oct 2014 Motorcycle(s): 2005 Kawasaki Ninja 250 Posts: 24
Ha, interesting,
I never thought a top case could be easy removed. Is that big enough for a helmet? |
October 15th, 2014, 11:21 PM | #43 | |
They make cases in a wide variety of sizes, and options as well. Here is a link you can check out to give you some ideas. http://www.twistedthrottle.com/twist...inja-250-88-07 Hope this helps |
October 15th, 2014, 11:55 PM | #44 |
Thanks Ghostt,
that's a very useful link. Do you need a rack for your case? Do your case come with necessary mounting? I'm kind of like your idea. Does the case sit on the back seat or it extend at the back of bike? |
October 16th, 2014, 12:13 AM | #45 | |
it did come with everything to mount it to the rack. If you look at the pictures on the twisted throttle site, you can see it extends past the back of the bike.
October 16th, 2014, 12:23 AM | #46 |
Wow, it seem like a wonderful solution to have a case and rack within $100 as most of other source I search way more than that.
Why you choose the medium than large one? The large one seem have better review and cheaper. Really thanks Ghostt. I need to take some time to study about it. Have a good night. |
October 16th, 2014, 12:29 AM | #47 | |
You should shop around, maybe even check out eBay
October 16th, 2014, 06:36 AM | #48 |
Join Date: Aug 2014 Motorcycle(s): 2007 Ninjette Posts: 809
@edward2014, the case on JCWhitney is good, but also consider the GIVI cases. GIVI is top dollar, but top quality, as well.
If you don't want to shell out the $100 for the rack, buy some aluminum and make your own: http://faq.ninja250.org/wiki/Hard_luggage
"That's what" -she |
October 16th, 2014, 07:57 AM | #50 |
Join Date: Apr 2014 Motorcycle(s): 1980 Yamaha XS850G Midnight Special, 32k Miles; 2000 EX250F, <5000 Orig Miles Posts: 98
My brother has a large Givi top case on his BMW F650GS. Its nice.. can fit a full face helmet and then some.
His has reflectors on it but also a real brake light that OPTIONALLY can be hooked up with two wires to the brake lights. |
October 16th, 2014, 09:04 AM | #51 | |
October 16th, 2014, 10:21 AM | #52 |
Man, that is COOL! I am literally copying your DIYs to my to-do list..
Keep it up!
October 16th, 2014, 11:14 AM | #53 | |
October 16th, 2014, 01:31 PM | #54 | |
I would check Amazon too they might have a better price and they are very easy to return things too.
October 16th, 2014, 03:28 PM | #55 | |
I saw some listing on Amazon but not one for Ninja 250. |
October 16th, 2014, 04:32 PM | #56 | |
October 16th, 2014, 04:35 PM | #57 | |
October 19th, 2014, 04:55 PM | #58 | |
October 19th, 2014, 06:39 PM | #59 |
@Roark, I don't got that TwistedThrottle yet. According to mounting instruction and others photo it only have 4 screw position to hold and no screw at the rear grab bar.
I search thru several different racks even some from Asia also. They are not exact fitted for Ninja 250 and may need some touch up. Size and strength is not that clear but shipping define take longer. |
October 19th, 2014, 06:45 PM | #60 | |
Being new to the 88~07 model and finding these two threaded holes in the bottom side of the grab handle, what possibility could Kawasaki put there? After doing some research I of course found the answer in an old post: http://forums.ninja250.org/viewtopic...135c2bec2737cd So that's what there for, very cool so all I need is a pair of bank sensor bolts. But after looking at the ones on my pegs they really did look good enough, wrong color, and just didn't seem like it would hold the hook due to its just straight. So then I began to look at other Kawasaki bank bots, and I found the ones that not only have a ball end on it, but they are the proper color, as long as it black, and they even have loctite already on them. So here's the pictures so all can see, the bolts are cheap enough, and it gives you two more solid points to hook or tie too. So there you have it.
October 19th, 2014, 08:44 PM | #61 |
You sir, have earned my gratitude. Good stuff
October 19th, 2014, 09:04 PM | #62 |
Np always glad to contribute to the cause.
Believe it or not this does help when carrying stuff, I have one of those bungee cargo nets, and the two extra points helps tremendously.
October 19th, 2014, 09:14 PM | #63 |
I can imagine..
I just ordered the large top case from JCWhitney! http://www.jcwhitney.com/garage-pro-...rid=c14523u0j1 And with my 20% code/free shipping/no minimum, it was $35 shipped!
October 19th, 2014, 09:16 PM | #64 | |
October 19th, 2014, 09:21 PM | #65 |
I will attempt to fabricate a rack when I get the case in (plus the free time )
If I can't, $100 isn't so bad! I'll post up my attempts if they produce anything of merit
October 19th, 2014, 09:23 PM | #66 |
Good plan, nothing wrong with giving it a try yourself. I look forward to your attempt, good luck.
October 19th, 2014, 09:34 PM | #67 |
Check this link, it might give you some more ideas,
http://forums.ninja250.org/viewtopic.php?p=223404
October 19th, 2014, 09:39 PM | #68 |
Thank you, Ghostt. Your wisdom exceeds your post count, haha.
Another example of the great wealth found in the archives of old.
October 19th, 2014, 09:41 PM | #69 | |
After taking a good look at the mounting system from twisted throttle, I believe that is very easily made assuming you have the raw materials. Good thing the pdf has all the specs of the attaching hardware.
October 19th, 2014, 10:10 PM | #70 | |
Also, why are you attempting to sell your touring windscreen? Seems like a necessity for long distances.
October 19th, 2014, 10:19 PM | #71 | |
Here is my review of it: Okay road test done, and here is my official review of the 7 JUROCK windscreen, but first here is the info from their website: http://www.7jurock.com/store/index.p...&productId=324 Product Information* OEM Measurement 11.5" Height, 10" Width* 7Jurock replacement windshield for*KAWASAKI 250R NINJA*1988 – 2007 Models*follows the same lines and contours as the original Kawasaki*OEM windscreen.*7Jurock offers:* 12" – 18" Height, 14" Width.*This*windshield is wider than the original, providing the rider arms*torso wind protection.**Beautifullyhandcrafted from 0.187 (3/16") thick cast military aircraft grade acrylic, specified for optical clarity.*Available in Clear,*Light Gray and Dark Gray.* All shields are D.O.T. approved and are manufactured to order.**Edges are hand ground*and polished.***CNC cut and drilled ready to install.**Height is measured along the center line of the windshield and width near the top.**NOTE:* Dark Gray is 0.125 (1/8"). Note:*No*mounting hardware, mounting brackets, mounting kits and/or any accessories (required for installation) will be included with the purchase of our Replacement Windshield. Ok now that that's out of the way, let the review begin; I would first like to extend a special thank you to Sonia Torres, from 7 JUROCK. She answered all my emails promptly, and always had the answers, and was great to deal with, she even took my order over the phone. I ordered the 18" in dark smoke(73% tint) and I asked if they could add a flip to it, Sonia said yes, I also told her I'm a tall person(6'3"/with a 34" inseam) and can they make the flip more aggressive, she said yes as well. So I placed my order and waited like a kid waiting on Santa Claus for FedEx to show up. After what seemed like forever it arrived, the windscreen was exceptionally packaged, so no damage during shipping. I tore into the box like a Christmas present, and was not disappointed, the finish on the windscreen was top notch, no rough edges, and no distortion. I was worried that an 18" might be too much,and look bad, too big,etc..... Installation was a breeze, as it should be if the windscreen is well made, and this one is superior, fit was dead on, fastening holes are clean and no rough edges. After installation I was relieved that it looked great, and not too much as I had worried about. Road test, so now comes the meat of the review. Now with the stock windscreen the wind use to hit me about mid chest, not much protection, as expected. So now at highway speeds, and maybe at time a little bit over, the windscreen hits me about the middle of my full face helmet visor, and almost little on my chest, and shoulders, the only downside was I found myself a bit warmer than usual, due to lack of airflow over myself, which is to be expected, and not a bad thing. So there you have it, 7 JUROCK is the probably the only manufacturer whom make such a screen for the bike, add to that the number of options you can choose, and very affordable. If anyone has any further questions, feel free to as myself, or give Sonia Torres a call at 7 JUROCK. *7Jurock.com orders are custom-made, and ship within 7 business days*
October 20th, 2014, 07:43 AM | #73 | |
World Class Ninja
Join Date: Sep 2014 Motorcycle(s): 2002 Ninja 250, 96 VFR750, 79 Yamaha XS1100 Special Posts: 224
Life is not a journey to the grave with the to arrive safely in one pretty and well preserved piece, but to skid across the line, thoroughly used up, worn out, leaking oil, shouting, GERONIMO! |
October 20th, 2014, 09:37 AM | #74 |
@Rustitution, if there's anything a Ninjette needs, it's the face of an alien.. HAHA
October 20th, 2014, 09:38 AM | #75 |
@Ghostt, WOW man, you've got to slow down on these mods.. My to-do list is only so big!
That's a great link and write up, and for $80, it's a steal! Awesome, work, man.. As always
October 20th, 2014, 09:41 AM | #76 | |
The best part of most of my modifications is they are easily done, and inexpensive, with just a little bit of work to do.
October 20th, 2014, 05:07 PM | #77 | |
October 20th, 2014, 06:17 PM | #78 |
No problem, hopefully by then my site probation time will be up, and I'll be starting a blog about it all.
October 20th, 2014, 09:22 PM | #79 | |
btw, I love your sig "zx5r" and "zx2r" Perhaps it should be the ZX2.5R.. That's way better. LOL
October 22nd, 2014, 10:59 AM | #80 |
That did cross my mind, but I was trying to keep the Kawasaki style, maybe next time, as I'm planning to do something with the original fairings that the bike came with, an don't ask I'm not giving any hints at this time .
First walmart trip! | Twitchy Stitch | Ride Reports | 20 | June 3rd, 2014 02:48 PM |
Luggage? | Adrrrrianna | Cargo Space | 3 | April 16th, 2013 03:19 PM |
touring luggage | sm0kediver | Cargo Space | 17 | February 9th, 2011 02:51 PM |
Who does Luggage???? | cnichols79us | Cargo Space | 31 | May 18th, 2010 06:45 PM |
my cousin and i at walmart :P | stryder | Pictures | 12 | May 6th, 2010 04:41 PM |
