#1 |
Adjustable Front Fork?
I tried searching the forum and checked the owner's manual but could not find out if the front forks/shocks are adjustable or not. I was able to adjust the rear shocks but not the front.
Are the fronts adjustable? If so how? Thanks! =] |
#2 |
IC2(SW)
Other than changing parts, No.
#3 |
What is it that you want to change? They are adjustable... sort of, but not in the same, easy "turn a knob/screw" way that other modern sport bikes are.
#4 | |
Ideally I'd like the bike a little lower without using a lowering kit or messing up the geometry of the stock bike. |
#5 |
kkim,
If you can elaborate or point me towards a wiki or page that shows how to adjust them, I would appreciate it =] Thanks! |
#6 |
That's odd... most people want to stiffen up the front end. What tire pressures do you run? sometimes that can make a world of difference in suspension "feel".
what is your weight? http://faq.ninja250.org/wiki/Front_suspension_upgrades |
#7 | |
#8 |
sounds to me like a lowering kit is your best answer. While it may limit cornering a bit and change the inherent handling built into the bike, the changes are small enough that one can adapt to them easily. Lower it just enough that will suit your needs. (1/2-1"??)
by doing so, you could lower your seat height and stiffen up the suspension. What's your riding/experience level? |
#9 |
Normaly people will go to a higher weight fork oil to stiffen up the forks but I don't know if you can go any lower on the weight.
#10 | |
#11 |
What are you wearing on your feet?
I suggest thicker soles (work boots) if you're not using them already. If you are, just ride the bike for awhile and see if you get used to it before modding it. Having your heels 1/2 inch of the ground is trivial once you've got a little bit of experience IMO. That's about where I'm at. To me the biggest issue with not being able to get my feet all the way down is moving the bike around in driveways/parking lots. Getting way up on tiptoe makes this a huge PITA, especially if you have to deal with slight inclines (crowned roads, driveways like mine). At the height of the Ninjette I don't have a problem even though I can't get both heels down at once. With the 32"+ seats on bikes like the R6, though, it's just not worth the hassle. |
#12 | |
#13 |
If you are a beginning rider, that tells me you won't be pushing the bike to it's limits quite yet, so the cornering clearance and handling changes that lowering brings should not be a hindrance/problem. Once you gain more experience, remove the lowering kit once you gain the confidence and skills to handle a stock height bike.
#14 |
Remembers when air forks and shocks were the rage on dirtbikes, and then later dirt bikes used shrader valves to bleed off air that accumulated as the forks heated up. Now snowmobiles are adding air shocks.
Bet all the kids who wear Fox sweatshirts at the mall didn't know it all started with the Fox Air Shox. Further bet they wouldn't care anyway. Who thought their logo would be such a valuable thing. |
#15 |
I liked those schrader valves on the forks.
#16 |
yeah and just a few years earlier we were adding air to stiffen the ride, rather than a stiffer spring. kind of surprised me when i saw the snowmobiles coming out with air suspension recently.
#17 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
You can convert them to adjustable. There are aftermarket end caps that allow some adjustability. But you'd have to switch to clipons because the caps wont work with the stock bars.
#18 |
Thanks Bryan for bringing post back to original. I got carried away reminiscing and hijacked the post.
Front Fork Repair ? | Ninjesterai | 2008 - 2012 Ninja 250R Tech Talk | 7 | March 25th, 2012 02:08 PM |
[motorcyclistonline] - Fully Adjustable Race Tech Fork Cap Gold Valve Kit for the ST1 | Ninjette Newsbot | Motorcycling News | 0 | September 19th, 2011 05:00 PM |
[sportrider - latest stories] - Fully Adjustable Race Tech Fork Cap Gold Valve Kit fo | Ninjette Newsbot | Motorcycling News | 0 | September 16th, 2011 02:40 PM |
Front fork Valve Emulators? | empire00 | 2008 - 2012 Ninja 250R Tech Talk | 5 | July 21st, 2009 01:30 PM |
