Old July 27th, 2009, 11:27 AM   #81
randomwalk101
self wrencher
randomwalk101's Avatar
Originally Posted by headshrink View Post
So this triggers the "idiot light" on the dash at ~230 degrees? If this is true, that has got to be the simplest hack yet.... I'm surprised no one has mentioned it yet.
will i get a cookie for mentioning it first?
Old July 27th, 2009, 11:32 AM   #82
Old August 14th, 2009, 11:50 PM   #83
headshrink
headshrink's Avatar
I just tried tapping into the sensor wire (using a wire tap) to hook the "idiot light" back up. I do NOT recommend this. I ended up destroying it. Apparently the gauge is VERY picky about the sensor wire, and tapping into it really pissed it off. I got readings all over the place, some of them don't exist on this planet. I'll be ordering a replacement sensor now. Grrrrrr....
EDIT: anyone know where I can get a replacement sensor? I have been looking, and looking, but can't find anything!
Old August 15th, 2009, 05:44 AM   #84
randomwalk101
self wrencher
huh? you're kidding me right? I have it right now and it's working fine.
I didn't "cut" the sensor wire. I simply stripped a small section, soldered a piece of wire to it, wrapped it up. At the other end of this wire, I put in a spade connector (male) so that will fit into the stock plug.
Old August 15th, 2009, 11:06 AM   #85
headshrink
headshrink's Avatar
That is pretty much what I did too... except I used one of those tap thingies. I think I misjudged the gauge, so it nicked a few braids in the wire, but it wasn't totally severed.
Old August 15th, 2009, 01:08 PM   #86
headshrink
headshrink's Avatar
I took the sender off, cut and stripped the wire, and then discovered why I am likely having this problem. There are TWO wires in there, not just one (see pic below)..... I was probably shorting them out. I am in the process of repairing them right now.
Which one was the signal wire you tapped into, the red?
I'm still looking for a replacement sender (part# 17-850S), but cannot find a single vendor that sells it. If someone knows where I can get one, please let me know.
Old August 15th, 2009, 01:29 PM   #87
randomwalk101
self wrencher
You have to strip the wire like that to solder it in...can't just use the tap and go through both. If I remember correctly I soldered it into a black one...it has been awhile..can't remember now..got it all wrapped up now.
You should be fine. Just solder each wire back up and you're okay. Put some tape to isolate each wires. You don't need a new sensor.
Old August 15th, 2009, 01:42 PM   #88
headshrink
headshrink's Avatar
Thanks, I'll give that a try.
Yes, as soon as I saw there where two wires in there, I knew I did a bad thing LOL! When I first posted last night, I hadn't realized that yet.
Old August 15th, 2009, 02:19 PM   #89
headshrink
headshrink's Avatar
Update: I have it repaired, but it is acting funny now. I have to have the light disconnected when I turn it on, then reconnect it.... otherwise it won't take a temp. reading. It also seems to read a little lower when it it connected. Could this mean the light should be wired to the black instead?
EDIT: OK, I am an idiot.... you DID say black, but I thought I read red (and that was double checking it). I think I need sleep. So, if anyone wonders what would happen if you connected it to the red, this is what happens. I'm going to try to switch it back to black now..... I don't have much lead to work with
Old August 15th, 2009, 02:34 PM   #90
randomwalk101
self wrencher
Jesus man...looks like you're loosing a lot of sweats. Just solder the two wires up and leave it at that...forget about that idiot light.
Old August 15th, 2009, 02:53 PM   #91
headshrink
headshrink's Avatar
And I think it has come down to that....
No that it is hooked up to the black it is even worse!
Same issue about not taking a reading if it is hooked up when bike is turned on. But now when I connect it (after turned on), it reads ~20 degrees lower! I'm going to keep it disconnected for now, but I really want to know why this is happening. It would be nice to have it fixed.
In theory, if the senders wires are shortened, will this throw off the reading (or is wire length unrelated)?
Old August 15th, 2009, 11:34 PM   #92
VeX
That's me!
VeX's Avatar
Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR
Did you still leave the idiot light spliced into the aftermarket sender? If so that could be causing you problems. The stock sender is an "on-off" style so once a certain temperature is achieved the sensor closes the ground connection (causing the light to illuminate). The aftermarket sender is variable (hence the two wires). If you splice the idiot light into that ground it's going to likely affect the reading I would guess! The nature of temperature senders is usually a reading between .5 volts (now a days they're reading even lower then that) and 4.5 volts. So if the sender is registering perhaps 120 degrees it might output 2.5 volts. If it is sensing 200 degrees it might spit out 3.5 volts. By tapping into the ground with the idiot light it's going to pull some of that voltage from the sender causing the sensor to think the bike is cooler then it is (because it's receiving a lower voltage)
VeX is offline   Reply With Quote
Old August 16th, 2009, 12:34 AM   #93
headshrink
headshrink's Avatar
Thanks VeX. Soooo I guess the others only THOUGHT they had it working. Glad I could help
Old August 16th, 2009, 05:16 AM   #94
randomwalk101
self wrencher
Dang..looks like I need to d/c mine. I had it hooked up but it hasn't gone off (idiot light) or anything since my bike never over heated. The daytona is working like normal....i guess i'll take it out just in case.
Old August 16th, 2009, 09:43 AM   #95
VeX
That's me!
VeX's Avatar
It will likely draw current, but the sender probably works on 0-5 volts whereas the bulb is meant to operate at 12 volts Take a look at the wiring diagram. The overheat sender literally has only one wire going to it because it completes a ground So once the sender hits a predetermined temperature (very much like a thermostat) it closes internally completing the connection.
Old August 16th, 2009, 11:59 AM   #96
headshrink
headshrink's Avatar
Part of me feels vindicated... I'm not crazy after all.
Old August 16th, 2009, 12:03 PM   #97
just because you might be vindicated doesn't mean you're not crazy.
Old August 16th, 2009, 12:28 PM   #98
headshrink
headshrink's Avatar
Well now you have to go burst my bubble... thanks Kelly. Think I'll have to go back to therapy now (go on a ride). Yes, that is what I will do... right now in fact.
Old August 16th, 2009, 12:29 PM   #99
Have fun!
Daytona Water Temp Gauge Problem?? kenji_808 2008 - 2012 Ninja 250R Tech Talk 2 December 28th, 2011 04:23 AM
Water Temp Gauge etiainen 2008 - 2012 Ninja 250R Farkles 5 November 4th, 2011 04:30 PM
Daytona Water Temp Gauge Keyoa 2008 - 2012 Ninja 250R Farkles 2 April 3rd, 2011 06:13 PM
Daytona Temp Gauge wellcraft General Motorcycling Discussion 0 January 26th, 2010 07:24 PM
Daytona Temp gauge whylee 2008 - 2012 Ninja 250R Tech Talk 9 January 20th, 2010 08:50 PM
