May 20th, 2014, 06:33 PM | #1 |
need some advice- replacing the chain
Replacing my chain what's a good one to replace it with went to cycle gear and they range in price starting at 35 bucks up to 100 plus don't want to get taken for a ride does it really make a difference if I get an inexpensive chain
May 20th, 2014, 06:40 PM | #2 |
MOTM - Mar '13, Jun '14
Then you don't need a chain!
May 20th, 2014, 06:47 PM | #3 |
Join Date: Apr 2014 Motorcycle(s): 09 250r, 09 1125r, 95 Virago Posts: 78
That was tacky CC.
You get what you pay for, but the price range sounds average. Ensure the chain is an O ring , X ring etc. I believe my last chain was about $75, I wouldn't go any cheaper. |
May 20th, 2014, 07:20 PM | #4 |
May 20th, 2014, 07:25 PM | #5 |
Join Date: Aug 2013 Motorcycle(s): 2012 Ninja 250 Posts: 450
I got this set a few months ago.
http://www.amazon.com/D-I-D-DKK-013-.../dp/B00G9TJX6I |
May 21st, 2014, 10:56 AM | #6 |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
I've been using RK. I got this one, and I just noticed the priced dropped significantly. As long as you stick with a reputable brand you should be good. DID or RK is common.
May 21st, 2014, 11:41 AM | #7 |
Those are both really good brands.
May 21st, 2014, 12:06 PM | #8 |
Track Clown
MOTM - Sep '15
Regina, PitBull or Driven are ones that i have used. might as well change out your sprockets too.
Questions about Replacing Chain/Sprockets | Bones85 | 2008 - 2012 Ninja 250R Tech Talk | 11 | April 29th, 2015 06:44 PM |
replacing chain and sprockets | skip | 2008 - 2012 Ninja 250R Tech Talk | 3 | April 24th, 2014 11:47 AM |
Replacing Chain and Sprockets | The Red Scourge | 2008 - 2012 Ninja 250R Tech Talk | 16 | December 9th, 2013 07:01 AM |
replacing chain... sprockets? | alex.s | General Motorcycling Discussion | 16 | August 29th, 2011 05:04 PM |
Replacing Chain | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 35 | March 18th, 2010 01:27 PM |
