#1 |
I told you bro
Join Date: Jun 2012 Motorcycle(s): 1996 Ninja 250r Posts: 680
valves keep going out of spec. Causes?
Hey guys. I recently took my bike to a mechanic to do a valve adjustment because when I did it about a day later my valves were out of spec and loose as hell. I'm not sure if I'm being an auto hypochondriac but i it sounds like my valves are already becoming loose. Is there any sort of of issue that could be causing my valves to loosen up so quickly?
I don't know if it's a related problem but my tach hand started to flutter whenever I started getting thes valve issues and it still is.is this normal or should my tach cable sit completely still at idle? It also acts strangely when I go WOT where the bike will, after maybe a second or two of holding the throttle all the way down the rpms will suddenly shoot up. Shouldn't there be no pause? Posted via Mobile Device |
#2 |
Did you tighten the lock-nuts to spec with the feeler gauge still between the cam lobe and the rocker?
The valves typically get tight on their own, not loose. |
#3 | |
I told you bro
I have no idea how they got loose the first two times because I did tighten them to spec. |
#5 |
Join Date: Apr 2012 Motorcycle(s): 2003 Goldwing GL1800, 2002 Ninja 250, 2001 VFR800, 1999 Ducati 996 Posts: 107
Check your valve clearances and confirm whether they are actually looser, or just sound looser.
I read another thread on this site where a member was having similar sounding issues to you, and everything was fixed when he installed a new CCT. Not saying that this is true in your case, but just a thought.... |
#6 |
A vacuum test could reveal hidden problems:
http://www.freeasestudyguides.com/en...cuum-test.html http://www.austincc.edu/wkibbe/vacuumtesting.pdf As far as I know, bad battery messes with the tachometer. Some reasons that occur to me for the problem with the valves: If valves are sealing on carbon build-up, if cam shaft, guides or some rockers are getting loose, if points of contact don't receive proper lubrication, if valves are not returning back all the way during calibration. I should be quiet after what I did to your carburetor............. ![]()
Motofool ![]() .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí |
#7 | ||
I told you bro
![]() Is there anyway to check if my battery is "bad"? I haven't seen much to say it is because it's relatively new but I've run it low about 2 times. I'll look about doing a vacuum test this weekend. Also if anyone knows, whenever my my front comes off a small ledge or bump I hear a "clack". What could this be a sign of? It only started happening after my mechanic did my valve clearance. It's something in the front of the bike near the line and the tach because it happens even when my bike is off. Also no worries about the the carbs, that stuff wasn't what turned out to be the problem. |
#8 |
Bad battery means the battery starts to loose performance (hard to reach spec volts when charged / get discharged by itself relatively quickly / little b@lls for extended cranking).
http://www.batterystuff.com/kb/artic...ry-basics.html http://batteryuniversity.com/learn/a...acid_batteries Most Autoparts check your batteries for free. Deep discharges can ruin good new batteries (not saying that the battery is your problem). For the clack, check the upper track and counter-nut of the steering column: they require a fine adjustment and certain torque (easy turn but with no play). Carbs OK now: After so many weeks,.............I can finally sleep in peace ![]()
What is this sound? Is this what out-of-spec valves sound like? | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 24 | November 15th, 2021 05:48 PM |
just adjusted Valves. ... | Fakker | 1986 - 2007 Ninja 250R Tech Talk | 7 | July 2nd, 2014 10:28 AM |
Questions on valves. | krolinked | 2008 - 2012 Ninja 250R Tech Talk | 11 | February 11th, 2013 04:22 PM |
[kropotkin thinks...] - 2014 MotoGP Rules Announced: Spec ECU Introduced, Spec Softwa | Ninjette Newsbot | Motorcycling News | 0 | November 10th, 2012 12:20 PM |
[roadracingworld.com] - FIM Puts Out Request For Proposals For Spec Engine ECU, Spec | Ninjette Newsbot | Motorcycling News | 0 | December 9th, 2010 04:10 PM |
