Old February 5th, 2016, 06:22 AM   #1
[visordown.com] - First ride Indian Scout Sixty review
The 999cc V-twin is so well behaved it feels, dare we say it, Japanese.
Ben feels like a sail on an 80mph boat.
Brakes: not to be sniffed at
IN fact they’ve been back for a few years now, although less than exhaustive coverage in the UK bike press could mean some have missed the fact. Following the brand’s rebirth at the hands of manufacturing giant Polaris, there are now seven models in the line-up. The latest is the Scout Sixty.
You might have heard of the Scout, either the 1920s model that your granddad’s mum used for the school run or the more recent 2015 model. Either way, it’s a name in motorcycling lore.
The Scout Sixty shares a great deal with its elder sibling, the Scout. However, the Sixty is ‘just’ 999cc, as opposed to the 1133cc of the Scout. They use the same block but the Sixty’s bore is smaller. In the parallel universe of cruising, at 999cc, it’s a baby. It makes a sniff under 80hp and 65lbft of torque which, in this universe, is okay with me.
While the frame, suspension and engine block are the same, the Sixty only has a five-speed box as opposed to six on the Scout. At 246kg, it’s light, for a cruiser, but one of the Sixty’s real appeals is its seat height. At 643mm, it’s practically on the floor. The low stance is aided by the wheels, which are 16-inch front and rear.
The Sixty stops via the single front twin-piston brake caliper and 298mm disc, and a not-to-be-sniffed-at braided steel brake line. ABS comes as standard.
Comparing the Scout and Scout Sixty side by side, the Sixty features less chrome. It’s more - as the Yanks like to say - blacked out. It’s aiming for a younger generation both in terms of its engine capacity and styling.
Firing it up, I expected the Sixty to clatter away and do its ‘authentic American iron and grit’ bit. Perhaps I’ve been conditioned by another American cruiser brand to expect the bike to crab its way across the car park while sitting in neutral on its side-stand.
It didn't. It's mild-mannered and I didn’t expect that. Despite Indian laying on a decent amount of ‘iron and grit’ heritage nonsense in the pre-ride press conference, I expected to feel the engineered-in engine vibrations and carefully tuned ‘clunk’ into first gear.
Far from it. The 999cc twin sits obediently in neutral, humming along, making no fuss. When I select first gear, the absence of a neutral light on the dash is the first sign it’s gone in. There’s no clunk or clatter. Dare I say it, it feels very Japanese.
That’s no bad thing, although die-hard cruiser fans might relate the word ‘Japanese’ to characterless. Equally you could relate it to ‘competent’, ‘well-engineered’ and ‘precise’.
The fuelling on the Sixty is immaculate. It’s one of the best-fuelled, best-behaving engines I’ve ever tried. Sure, it doesn’t have a load of grunt, but there’s plenty on tap and it’s eager to spin up, a lot more eager than you’d think any cruiser would be. It’s almost impossible to make the motor struggle. Load it up in fifth at 40mph and it doesn’t threaten to shake itself to bits. At 90mph it feels fairly happy too.
Third, fourth and fifth gears feel close together. One of the great features of a majority of cruisers I’ve ridden is the final clunk into an over-drive-like top gear, which this doesn’t share. It feels like going from fourth to seventh. I know the Sixty is ‘only’ a baby but the engine is so good, I can’t see it struggling to pull a taller top gear, with the revs dropped right down. Winding along at 50mph and a handful of revs is one of the ways any cruiser justifies its existence. That’s sadly lacking on the Sixty.
Much faster can feel perverse on a cruiser. That ‘wind in your hair’ feeling is actually a ‘stuck in a wind tunnel’ feeling at anything over 70mph. The riding position makes you feel like the sail on an 80mph boat.
CLICK HERE TO CONTINUE READING OUR VICTORY SCOUT SIXTY REVIEW
Related Content
Revealed: 2015 Indian Scout
Indian Scout to appear tomorrow?
Indian Scout set for return
Road Test: Rockers Roll
Indian confirms new Chief Dark Horse
The Scout Sixty's cornering ability defies the meager limits of the tyres.
These don't inspire confidence
The seat's as wide as a bowl of oatmeal but still short on comfort after 50 or 60 miles.
Ben's own kerb weight of 65kg wasn't enough to get this really working.
While the seat is thicker than a bowl of oatmeal, it’s not as comfortable as it looks. Perhaps it’s full of the iron and grit that Indian kept mentioning in the press conference. Truth be told, there’s 50 to 60 miles in that seat before I’ll want to get off.
The riding position doesn’t help here either. My arse felt lower than my knees, especially when we started to get a decent lick on. I guess I’m just used to the arse-up, wrists down nature of sports bikes. However, the suspension at the rear felt overly firm and can only be adjusted for pre-load. With my own modest kerb weight of 65kg, I probably need a few more fry-ups to get the twin shocks into their optimum performance envelope. As it was, it felt like my lower back did most of the shock-absorption.
For a bike that, thanks to its low seat, feels five times as long as it is high, it’s not too bad in the bends. In fact it’s a bit of a giggle - but that giggle comes with one caveat. The Indian-branded Kenda K673 tyres are a bit vague. That’s being generous.
I didn’t have any moments but at healthy levels of lean, I never quite trusted the front. Now, I know, we’re not looking to break any lap records but I certainly wouldn’t want to break any bones and ride on a tyre with any less grip. They’re fine for pottering around but you’ll be a braver man than me if you try to keep up with mates on bikes other than cruisers. Which in a way is a shame because otherwise this bike would do it, 16-inch rims and all.
Grip the tank with your knees and use the wide bars to your advantage and you can get the Sixty to flick from side to side underneath you with ease. And I mean underneath you. It feels like you pass the bike back and forth using your knees and little else.
The foot-pegs go down easily. A tyre offering more confidence at lean would see you get the exhaust down on the right hand side too (so perhaps grippier rubber ought to stay on the shelf after all).
Riding the Sixty with the Remus aftermarket exhausts offered up a bit more bark for a bit more buck and gave the ride a little more feedback. In fact the exhaust offered a tempting glimpse into what this bike could be.
If you’re anything like me, you’ll probably appreciate a few more cubic-inches between your legs and that extra gear. In which case, walk past the £8,999 Scout Sixty and find the extra £1,500 for the Scout.
Straight from the showroom, it’s a handsome motorcycle but contrary to the marketing hype, it’s a little bland for my liking. What it’s crying out for are a few tweaks to unleash the noise and get heads turning.
But the Scout Sixty will make a great platform to sprinkle in a little of your own character. Above all else, it’s just a good excuse to head outside and while away a few hours in the saddle.
Model tested: Indian Scout Sixty
Price: £8,999
Engine: 999cc Liquid-cooled V-twin
Power: 78hp @ 6,500rpm
Torque: 65lbft @ 5,800rpm
Kerb weight: 247kg
Suspension: 120mm travel front fork, 78mm travel twin rear shocks, preload
adjustable
Brakes: Twin-piston, single front caliper, 298mm disc
Tyres: Kenda K673
Seat height: 643mm
Fuel capacity: 12.5 litres
Colours: Black/Red/White
Availability: now
  • Sign up for Visordown's weekly newsletter, Bugsplat, to get the best motorcycle news, road tests and features plus exclusive competitions and offers direct to your inbox. Register as a Visordown member here and tick the box for Bugsplat in your newsletter settings here.
Related Content
Click here for full story...
[motorcycledaily.com] - 2016 Indian Scout Sixty: MD Ride Review, Part 2 (Bike Reports Ninjette Newsbot Motorcycling News 0 January 6th, 2016 06:40 PM
[motorcycledaily.com] - 2016 Indian Scout Sixty: MD Ride Review, Part 1 (Bike Reports Ninjette Newsbot Motorcycling News 0 December 21st, 2015 05:20 PM
[motorcycle.com] - 2016 Indian Scout Sixty First Ride Review Ninjette Newsbot Motorcycling News 0 November 24th, 2015 05:10 PM
[motorcyclistonline] - First Ride: 2016 Indian Scout Sixty Ninjette Newsbot Motorcycling News 0 November 24th, 2015 10:30 AM
[visordown.com] - Indian announces the allnew Scout Sixty Ninjette Newsbot Motorcycling News 0 November 18th, 2015 04:15 AM
