Old May 4th, 2012, 07:18 AM   #1
road_warrior64
Smog Block Off Plate - $10 !!!
http://www.ebay.com/itm/Kawasaki-Nin...1cb9f0&vxp=mtr
I just ordered one. Considerably cheaper than others I've seen.
JC
road_warrior64
road_warrior64 is offline   Reply With Quote
Old May 4th, 2012, 08:15 AM   #2
jjb84
care to explain the benefits?
jjb84 is offline   Reply With Quote
Old May 4th, 2012, 08:17 AM   #3
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
Nice find!
Old May 4th, 2012, 08:26 AM   #4
Read the ebay posting. It explains.
Old May 4th, 2012, 08:34 AM   #5
jjb84
Thanks...
For all those that didnt pay any attention to the listing...
These plates are used to block off and remove the air induction system (AIS) which is used to burn unburned exhaust gases by injecting fresh air (secondary air) into the exhaust port, reducing the emission of hydrocarbons. Once these plates are installed the air injection system can be safely removed.
These Smog Block Off Plates are CNC'ed from 3/8 inch thick 6061 T-6 billet aluminum and each kit contains all the necessary parts (One block off plates, a vacuum cap and instructions) needed to remove the AIS from any bike listed below. The main reason of removing the AIS is to get an accurate Air:Fuel (A/F) ratio when dynoing the bike. The air injection system pumps fresh air directly into the exhaust stream in order to burn off any unused fuel. Unfortunately by doing this the A/F ratio is thrown off by the extra "fresh air" in the exhaust stream. By removing the air injection system you can achieve an accurate A/F ratio. This kit also works well for racing/track day bikes because it removes all unnecessary equipment from your bike for reduced weight and ease of maintenance. Make sure to remove the screws and reed valves that are located under the stock caps to allow the new plates to make a full and tight seal.
Old May 4th, 2012, 10:05 AM   #6
dubojr1
dubojr1's Avatar
I capped mine with a $.59 bolt, some rtv sealant, and a zip tie.
Total cost =$ .61
Similar to this:
And this is by far the easiest & cheapest way!
[roadracingworld.com] - Video: Installing Smog Block-Off Plates On A Yamaha FZ-09 For Ninjette Newsbot Motorcycling News 0 January 4th, 2015 10:51 AM
[roadracingworld.com] - Video: Installing Smog Block-Off Plates On A Yamaha FZ-09 For Ninjette Newsbot Motorcycling News 0 January 4th, 2015 10:40 AM
[roadracingworld.com] - Video: Installing Smog Block-Off Plates On A Yamaha FZ-09 Str Ninjette Newsbot Motorcycling News 0 January 4th, 2015 09:40 AM
Smog Block cbinker Ninjettes At Speed 5 January 26th, 2014 09:12 PM
PowderKeg Racing Smog Block Of Plates Ricmon 2008 - 2012 Ninja 250R Tech Talk 2 August 22nd, 2012 12:31 PM
