Go Back   ninjette.org > General > Pictures
Old May 14th, 2012, 03:56 PM   #1
alley
Motorcycle(s): 1999 ex 250
my pre gen build
stock-ish. has woodcraft clip-ons, flush mounts and a custom fender.
now. k&n, muzzy pipe, modified stock muffler and tail chop.
gsxr shock and sonic springs coming soon.
and only 804 miles.
alley is offline   Reply With Quote
Old May 14th, 2012, 04:36 PM   #2
love the shorty tail
Old May 14th, 2012, 04:57 PM   #3
Hoodie Ninja
Motorcycle(s): 2011 Ninja 250R Special
Agreed.
Hoodie Ninja is offline   Reply With Quote
Old May 14th, 2012, 06:17 PM   #4
alley
thanks seat is finished. need to get pics tho.
Old May 14th, 2012, 06:25 PM   #5
NJ Ninjette
NJ Ninjette's Avatar
Motorcycle(s): 2012 Ninja 250R, 2007 Husky TE 250, 2002 KTM EXC 250r
+2
NJ Ninjette is offline   Reply With Quote
Old May 14th, 2012, 06:47 PM   #6
I thought people only bobbed the tails to save weight for racing but then the tail would be gutted of the street equipment too.
Old May 14th, 2012, 10:31 PM   #7
Jono
Jono's Avatar
You going to shorten the side fairings and put them back on?? It looks awkward as it sits now.
Old May 15th, 2012, 03:46 PM   #8
alley
yes
Old May 15th, 2012, 06:49 PM   #9
Jono
Jono's Avatar
Cool! Can't wait to see how it turns out.
Old May 16th, 2012, 08:04 AM   #10
Get a can on that thing. When I was testing my Muzzy for leaks, I started it with open headers for just a second. Sounded like sh*t because it was all tin-y and shallow sounding. The can sounds so much better and gives it some depth (conveniently, it's also quieter than my Two Brothers slip-ons were)
Anyhow, I love the paint scheme; it's the best one! Get some custom made side fairings on there, and raise the tail a little bit You'll like what it does for the handling. I can't wait to see what you come up with when you finish this project
Old May 16th, 2012, 08:09 AM   #11
The tail might get raised by the GSXR shock, I dunno.
It lost the mount for the exhaust hanger but I'm sure the OP could still rig something up.
Old May 16th, 2012, 08:14 AM   #12
I'm pretty sure the GSXR shock is a tad shorter than the newgen shock. The newgen shock is a tad longer than the pregen shock. I'm not sure what that means for the comparison from GSXR shock to pregen shock though
When all else fails, I really really love my soupy's adjustable dogbones on my pregen. I got them shorter than the typical ones for raising the tail instead of lowering it. Really great quality parts, and really great service. I love how they make my bike fall into turns and give me adjust-ability between different tire combinations to keep it in that sweet spot that doesn't have the tail so high that it's unstable, but at the same time, turns on a dime.
Old May 16th, 2012, 04:00 PM   #13
alley
the gsxr shock is a few mm's shorter than stock. but I have woodcraft clip-ons http://www.woodcraft-cfm.com/cgi-bin...tion&key=12-01. the front of the bike is dropped at least 2". I also increased the angle of the tail when i chopped the subframe.
I do have a can on it. Its a completely gutted stock muffler, perforated tube and packing in it with a custom tip.
I really need to check the valve adjustment and part throttle fueling. It stumbles bad taking off at a light.
Old May 17th, 2012, 08:46 AM   #14
Ah, so lowered front means you're still aggressive on turn in. Good
As for the mid-throttle fueling, trying raising your needles with SAE #4 washers (or if you can't find those, 3mm ID 6mm OD that are about .5mm thick work well also) That should richen up your mid-range.
Old May 17th, 2012, 10:39 AM   #15
alley
I have #40 pliot jets, 5 washers and #112 mains. its fine mid and full throttle, just 1/16th to 1/8th throttle
Old May 18th, 2012, 09:37 AM   #16
Is it getting a soupy feeling right when you roll off of idle when you try to take off without using much throttle? At 1/16-1/8 throttle, you're in that area of the throttle where the needle taper, needle height, and idle mix are all still having a large effect on the fuel delivery.
A bogging feeling, like I'm pretty sure you're experiencing because I just re-jetted for the 2nd time and I had the same thing going on, is a symptom of rich jetting. I would try taking one washer off the needles; if that bog is still there after that, I would turn the mix screws in about 1/8 turn.
After taking the 5th washer off the needles, does the bike surge when at about 10k with barely enough throttle to keep a steady speed? If it does, put the 5th washer back on. If not, keep it off.
Anyhow, this is a great page to read for info on jetting.
So it this.
Old May 20th, 2012, 07:52 PM   #17
alley
Old May 23rd, 2012, 11:52 PM   #18
beninja
beninja's Avatar
That's awesome, are you going to be putting the middle fairing piece back on?
beninja is offline   Reply With Quote
Old May 24th, 2012, 03:46 PM   #19
alley
A bogging feeling, like I'm pretty sure you're experiencing because I just re-jetted for the 2nd time and I had the same thing going on, is a symptom of rich jetting. . [/URL]
You hit the nail on the head, TOO RICH. Much better now.
Took the rear wheel off today. I'm gonna install the gsxr shock, paint the swing arm and rear wheel. Will report back with pics.
Old May 24th, 2012, 03:48 PM   #20
alley
Yes I am. I'm just deciding the best approach.
Old May 25th, 2012, 09:48 AM   #21
cerberusrex25
Accesories Guru
cerberusrex25's Avatar
Motorcycle(s): '99 EX250(Cafe/fighter project)
Gorgeous, I wish I could get a muzzy for mine.
cerberusrex25 is offline   Reply With Quote
Old May 26th, 2012, 09:31 AM   #22
Dave, just to make you a little jelly:
If you can get your hands on a used on, GET IT! totally worth it. The difference is noticeable and I really appreciate mine. Just make sure to get a swingarm stand and keep the center stand to attach when you need it.
Old May 28th, 2012, 04:27 PM   #23
cerberusrex25
Accesories Guru
Excuse me while I write you a deed to all of my jellys!!!!!!, What did you do to your two bros slip ons?
Old July 1st, 2012, 07:05 PM   #24
alley
Update:
sorry about quality, its a night shot.
Old July 1st, 2012, 11:21 PM   #25
beninja
beninja's Avatar
solid! looks so good, the color is a little off but it doesn't detract from the fact that it looks cool!
Old July 2nd, 2012, 02:27 AM   #26
That looks freakin' awesome! That Muzzy pipe looks just like a Kerker 2-into-1 exhaust. I can't make it out, but what are you using as an exhaust hanger now that you've gotten rid of your passenger pegs? I need to move up to something better than the zip-tie I'm using.
Old July 2nd, 2012, 06:55 AM   #27
alley
Coat hanger
Old July 2nd, 2012, 08:52 AM   #28
hahaha! I sold them to zzrguy in May-ish when I bought the used muzzy
Posted via Mobile Device
Old March 27th, 2013, 01:15 PM   #29
alley
Back with an update!
Old March 27th, 2013, 01:18 PM   #30
Nice use of the stock parts.
Old March 27th, 2013, 01:52 PM   #31
alley
looking to put mx bars on it soon, so my woodcraft clip ons are for sale. can not post in the market place yet but i will as soon as i am able (hint hint mods).
Old March 27th, 2013, 02:08 PM   #32
BRad704
Big Dreams, Small Wallet
BRad704's Avatar
Motorcycle(s): 08 Ninja 250R (Sold), 93 VFR750F (In Pieces)
You've just made me realize what it is about pre-gens that I DON'T like... It's the tail being too long for the snubnose.
Great work on your bike and I really like the stubby tail and streetfighter style front.
~BRad
BRad704 is offline   Reply With Quote
Old March 28th, 2013, 09:37 AM   #33
StephenA
Riding Ruby..
StephenA's Avatar
Motorcycle(s): 2014 Yamaha Bolt R-Spec, 2007 Ninja 250R
how much were you thinking about for the clipons?
Unregistered
StephenA is offline   Reply With Quote
Old March 28th, 2013, 09:43 AM   #34
alley
For sale thread for clip ons
http://www.ninjette.org/forums/showt...896#post657896
Old March 28th, 2013, 06:44 PM   #35
alley
Old April 1st, 2013, 08:18 PM   #36
alley
Old April 2nd, 2013, 04:36 AM   #37
BRad704
BRad704's Avatar
The brushed finish on the upper looks really good with the black mounts and bars.
~BRad
Old April 2nd, 2013, 07:37 PM   #38
alley
I painted the triple. I used a belt sander to level the entire top of the triple, which in effect gave it the brushed look.
Old April 16th, 2013, 09:43 AM   #39
That's exactly what I wanted to do with mine to make a different-style triple. What type of sand paper do I need to use? I plan to use SV650 clipons so can I also use this technique to take some room off below the triple so that I can mount my clipons slightly higher?
I was looking at pregen spacers intended for lowering and using those instead of sawing the original risers, but I like your results. I want to make the triple look more like the newgen with a keyhole surround, so I've got more work ahead of me.
I need to invest in a clamp... and a workbench to attach it to.
Old April 16th, 2013, 01:31 PM   #40
alley
I would not suggest removing any material from the bottom of the triple.
I don't know what kind of sand paper was on the belt sander. It's my buddies bench mounted belt sander.
Is the spacing for the forks different between the pregen and the newgen? What about the stem? Might be better off starting with a newgen triple.
New-gen engine in Pre-gen frame. Oil leak under exhaust ports. AFazakerley 2008 - 2012 Ninja 250R Tech Talk 11 June 5th, 2016 02:03 PM
Pre Gen Caffe Latte Race Build dukeswift 1986 - 2007 Ninja 250R Farkles 5 July 17th, 2014 08:36 AM
96 Pre Gen Racebike Build Rollingmenace 1986 - 2007 Ninja 250R Tech Talk 32 December 23rd, 2013 01:41 PM
Bike size, new gen vs pre gen(zzr) bowerbird100 General Motorcycling Discussion 6 August 1st, 2013 05:49 PM
Pre-gen (2007 and older) and "new pre-gen" (2008-2012) frames kjohng General Motorcycling Discussion 5 February 27th, 2013 10:03 AM
