Old December 5th, 2015, 10:51 AM   #41
smokinsingle
L8APEX
smokinsingle's Avatar
Motorcycle(s): 07 KTM 950SMR, 06 KTM 450SMR, 99 KTM 300MXC, 00 Derbi GPR 50, 09 Ninja 250 racebike, race with www.cra-mn.org!
What pressures are recommended for the A13's?
www.joemillersmoderngarage.com www.starr-cycle.com
***The most important concept of science isn't memorizing facts, it's observation of phenomena.***
smokinsingle is offline   Reply With Quote
Old December 5th, 2015, 07:33 PM   #42
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I'm not sure what's recommended but everyone I've talked to runs them between 28 and 32 hot off warmers. Exactly where is personal preference.
I run 29/29 cold (no warmers) and don't have any issues with the tires, though my setup has the suspension as the weakness so I may not be riding the limit of the tires
Old December 22nd, 2015, 12:37 PM   #43
Dsheumaker
Dsheumaker's Avatar
Motorcycle(s): 14 Ninja 300 (Track Only), 07 CRF150RB
Ive been running 29/29 cold on the street with these tires! absolutely amazing tires and they seem to last for forever! Mine still look like they did when i got them as a MA take off.
Dsheumaker is offline   Reply With Quote
Old December 28th, 2015, 11:16 PM   #44
Shenanigans
Motorcycle(s): 09 Ninja 250, Grom, GSXR
From RTS site
Fitment specs Front: 110/70R17 Alpha 13
Suggested Pressures: Hot on the warmers 33psi, or cold 30psi
Fitment specs Rear: 150/60Rx17 Alpha 13
Suggested Pressures: Hot on the warmers 33psi, or cold 28psi
Shenanigans is offline   Reply With Quote
Old December 29th, 2015, 09:47 AM   #45
Dsheumaker
Dsheumaker's Avatar
Originally Posted by Shenanigans View Post
From RTS site
I have been running these pressures and have been getting good wear, i mean drop a few psi tho, try to get a little more heat into them.
Old December 29th, 2015, 11:37 AM   #46
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
The A13 has amazing wear, though a lot of that is the bike. The pirellis wear very well as well but the A13 seems to last a bit longer (1000+ miles longer)
Old December 29th, 2015, 02:33 PM   #47
Shenanigans
Old January 20th, 2016, 10:06 AM   #48
daverdfw
Motorcycle(s): 2009 Ninja 250
I just ordered a set of these for my 2009 250. My bike still has the IRC Road Winners on them, from 2009 with 3500 miles. Hard as rocks!
daverdfw is offline   Reply With Quote
Old January 31st, 2016, 02:39 PM   #49
daverdfw
Has anyone here bought from racetireservice.com ? I put my order in over 2 weeks ago, emailed on status no reply, called, no answer.
Old February 7th, 2016, 03:59 PM   #50
GregS
Motorcycle(s): Ninja 300, GSXR-750, Ducati M1100
Did you ever get your tires? I've never had a problem with these guys.
GregS is offline   Reply With Quote
Old February 7th, 2016, 04:53 PM   #51
daverdfw
I will get them this week. They said it was too cold in Reno to ship them.
Old February 10th, 2016, 04:26 PM   #52
hfd1 tuner
Motorcycle(s): many mostly racebikes cbr565 fzr490 ex250ish
The Dunlops do not like freezing temps they can crack if smacked around. They were down on ft tire stock as well big shipment was missing ft.'s. Been testing the alpha's on 2 ktm390's and ran them at Jennings in endurance races and this past weekend on the ex250r they work good. psi is what works for different riders. I look at psi rise off track and core temp. we run 31 rear 29 ft for the most part hot off warmer.
hfd1 tuner is offline   Reply With Quote
Old February 10th, 2016, 10:37 PM   #53
daverdfw
yeah the cold makes sense. I got them yesterday. So the 150 seems big for the 250 but I guess it fits on the rim ok?
Old February 11th, 2016, 01:39 AM   #54
hfd1 tuner
it is a little squeeze to mount but it works good on the track. This tire is a good one, I come from old school racing back when the k591 was a new tire that everyone raced. I would say the a13 is a very close match to the bridgestone med slick. The Michelin cup evo ft is better by a little bit.
Old February 11th, 2016, 10:51 AM   #55
GregS
I use the Alpha on the back and the Michelin Cup Evo on the front, although I wish the Cup was available in 110
Old February 11th, 2016, 11:00 AM   #56
ROADandTRACK
R&T Suspension
ROADandTRACK's Avatar
Originally Posted by Sirref View Post
when is michelin going to add something for track use?
The Michelin 120 race front with a 150 2ct works great and last longer than anything I've used.
ROADandTRACK is offline   Reply With Quote
Old February 11th, 2016, 04:28 PM   #57
GregS
Keith - I might give the 150 2ct a try after I wear this new Alpha out.
Old February 11th, 2016, 06:43 PM   #58
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
thanks for the heads up, I think I'll be sticking with the alphas for now since I have a good supply of them but I'll consider that in the future
Old February 13th, 2016, 10:10 AM   #59
AwDang
Motorcycle(s): 286, 296, 599, 799
Welp, i found the end. About 12 hrs ride time on this one
AwDang is offline   Reply With Quote
Old February 13th, 2016, 10:22 AM   #60
GregS
So how did you like them?
Old February 13th, 2016, 10:32 AM   #61
AwDang
I'm not fast enough to tell a difference between tires
Old February 13th, 2016, 10:40 AM   #62
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
I might try a set of these. Dunlop has some killer deals for our club....$225 or less for a pair of tires.
Goin' fast on slow bikes!
Old February 13th, 2016, 11:54 AM   #63
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
I am going to test out some bridgestone slicks 90/17 front and 120/17 rear, one thing to consider is that going up in tire means more rotating mass which is very important to consider for these bikes.
TEAM ALFALFA
www.apexassassins.com
Old February 15th, 2016, 07:21 AM   #64
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
Pretty good deal right there.
Old February 15th, 2016, 07:57 AM   #65
taz
taz's Avatar
MOTM - May '17
So do you have to run tire warmers for the a13's?
Old February 15th, 2016, 07:31 PM   #66
ninja-turtle
ninja-turtle's Avatar
Motorcycle(s): Kawasaki 636
I personally run them on warmers and make sure I'm around 30f/28r at Jennings around 60-70 degree weather.
I have ran them without warmers and they did not grip as much the first two laps. After the first two laps I pushed it much harder and it seemed to grip just fine.
ninja-turtle is offline   Reply With Quote
Old February 17th, 2016, 07:53 AM   #67
tgold
Motorcycle(s): 2006 1050 Speed Triple, 2010 250 Ninja racebike, YZF320RR? Racebike
MOTM - Nov '15
Are tire warmers necessary? I'll answer by asking another question: Is racing motorcycles necessary? The answer to both is: No.
However, I think there are good reasons to use them if you want to win.
Here's one of the main reasons why I use tire warmers: When I race I expect to be competing for the win. If I give a second or two to my competition at the beginning of a race because I'm waiting for my tires to come up to temperature, well I'm essentially ok with giving a handicap to the riders I'm competing with. In the classes I run in, the races are only 8 to 10 laps long. Why would I want to handicap myself for as much as a quarter of the race? If I can go into the first turn of the first lap at my own race pace I do not give up an advantage to others. Most passing is done in the first lap of the race, so again, why give up such an opportunity?
BTW, the last race I won, the time difference between first and third place was four tenths of a second.
Aside from that, going into a race in the best emotional and mental state possible is also vital. The confidence that using tire warmers can impart is a big factor in attaining a good mental state. Don't believe me? Just use tire warmers for half a day, then intentionally don't use the front warmer for a session or two. I promise you you'll be thinking about it for at least a few laps.
tgold is offline   Reply With Quote
Old February 17th, 2016, 04:31 PM   #68
GregS
I don't use them on my bike, but there again I'm not competing so it's no big deal to take it easy for a lap or two.
Old February 27th, 2016, 06:32 PM   #69
daverdfw
Got mine mounted the other day, the mechanic questioned the pressures on the dunlop site. He called local dunlop contact with RTS, cold pressures should
32 front and 23 rear. add 2 PSI if on warmers.
Old February 28th, 2016, 10:21 AM   #70
GregS
Hmm.. that's not right, should be as follows.
Front = 30 cold and 33 hot
Rear = 28 cold and 33 hot
I've tried the pressures above and they work well.
More info here
http://dunlopracing.com/tires-products/alpha-13/
Old March 2nd, 2016, 06:55 PM   #71
RaceBikeRentals
Pimpin
RaceBikeRentals's Avatar
Motorcycle(s): Bunch of em
There is nothing wrong with running 23 psi in the rear. I'm guessing some people go far lower than that. Its a matter of personal preference.
-Richard
MotoList.com <<<List your stuff!
RaceBikeRentals is offline   Reply With Quote
Old March 3rd, 2016, 11:00 AM   #72
GregS
I don't have a problem with people's personal preferences on tire pressure, I was more concerned that somebody quoted him the pressures as being from RTS when their website specifies differently.
Old May 20th, 2016, 09:16 AM   #73
ROADandTRACK
R&T Suspension
Both of these bikes ran an 8 hour endurance race running some of the fastest 250 times. Tires are still great.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old May 20th, 2016, 09:33 AM   #74
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Which tires are those? Please and thank you.
Old May 20th, 2016, 09:46 AM   #75
ROADandTRACK
R&T Suspension
Michelin 120 EVO front and a 150 2CT rear
Both bikes on VonHertell R&T Suspension front and rear
Old June 1st, 2016, 09:21 PM   #76
daverdfw
here is what my front and rear A13 look like after 2 track days running 32f 23r
Old June 2nd, 2016, 05:50 AM   #77
tgold
MOTM - Nov '15
How was the grip? (Please don't say: "Stuck like glue.") And, (If you don't mind) what would you say your skill level is?
Thanks
Old June 2nd, 2016, 08:31 AM   #78
daverdfw
Thanks
since I am a novice, on 3 track days so far, I am not pushing the limits of the tire. I mainly posted to show wear at the pressures I was running for anyone that was curious.
Old June 2nd, 2016, 09:06 AM   #79
tgold
MOTM - Nov '15
You gave me exactly the info I was looking for. Thanks!
Old June 2nd, 2016, 09:11 AM   #80
daverdfw
I thought running 23 on the rear would be low, but I think the rear looks ok, what do yo guys think?
[roadracingworld.com] - Dunlop Launches New I RIDE Dunlop Marketing Campaign/Sweepsta Ninjette Newsbot Motorcycling News 0 May 7th, 2014 05:10 PM
[kropotkin thinks...] - Dunlop Press Release: Dunlop To Test Moto2 Tires At Phillip I Ninjette Newsbot Motorcycling News 0 February 21st, 2014 05:50 AM
[roadracingworld.com] - Dunlop Senior Road Race Manager Mincone To Transfer To Dunlop Ninjette Newsbot Motorcycling News 0 February 18th, 2014 03:40 PM
[motorcycle-usa.com] - Dunlop Names 2014 Elite Team Dunlop Squad Ninjette Newsbot Motorcycling News 0 February 4th, 2014 03:50 AM
[cyclenews.com] - Dunlop Announces Its Elite Team Dunlop Squad For 2014 Ninjette Newsbot Motorcycling News 0 January 30th, 2014 01:40 PM
