July 1st, 2009, 08:45 AM | #1 |
Join Date: May 2009 Motorcycle(s): 09 Ninja 250R Special Ed Posts: 99
I did my 1st oil change question!
alright another Oil post i know!!
but i followed the DIY for the oil change and I filled it upo in between the 2 lines, but i did it on the stand and if I try to level the bike by hand which is awefully hard it goes all the way up to the top level! ok so if I sit on it and look while trying to have it level then it goes down again so i'm all confused any tip to figuring this out!? |
July 1st, 2009, 08:53 AM | #2 |
Join Date: May 2009 Motorcycle(s): 09 ninja 250(red) Posts: 193
try holding the bike from the right side. use your leg to hold it up so you can look at the glass.
Or have someone hold it up for you while you look |
July 1st, 2009, 09:18 AM | #3 |
Live Life
Join Date: Nov 2008 Motorcycle(s): 2009 Green SE Ninja 250 Posts: A lot.
Duvi - without a rear stand to hold the bike I would suggest you use a piece of 2x4 under the side stand. It wont make it exactly level but it will be close enough and the weight will be on the 2x4 and stand.
Until you are really familiar with your bike I would not try to balance it by hand, on the right side, bent over looking at the oil level. If it starts to go on you . . . well let's say it wont be pretty.
- ATGATT - Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots |
July 1st, 2009, 09:38 AM | #4 |
What does the owners manual say on how to check the oil level? The owners manual for the "pre-gen" says to check it with the bike on the centerstand which the "new-gen does not have. So go by what the manual tells you to do.
July 1st, 2009, 09:44 AM | #5 |
Bike needs to be straight up and down for the oil sight glass to be accurate. Easiest way is to get a helper. You sit on bike, helper gives you a thumbs up that the oil is in between the two lines. Second easiest way is on front/rear stands if they hold the bike relatively level. Anything other than that will require you to find a way to be able to see the sight glass while the bike is sitting straight up and down.
I know what kkim did is to first confirm that the oil level was correct, then he put the bike on just his rear stand to see where the correct level in the sight glass would be when on a rear stand; now he can check the oil level when it's just on a rear stand.
July 1st, 2009, 09:50 AM | #6 | |
Join Date: Dec 2008 Motorcycle(s): 2009 SE Ninja 250R Posts: 796
July 1st, 2009, 09:54 AM | #7 |
Are you sure? IIRC my 06 manual said on a level surface too (i.e. not on side or center stand)
July 1st, 2009, 10:25 AM | #8 |
IC2(SW)
I just add two quarts with filter change. Start it up for a minute, turn it off and see if there's oil in the window...... I see oil, Iam done
July 1st, 2009, 10:45 AM | #9 |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250R Posts: A lot.
If you dont have stands or a friend.
Get on the right side of the bike. Place your left hand on the rear seat and apply the front break with your right hand. Go down to one knee. Pull the bike lightly towards you untill it feels weightless. (that is when it is balanced upright). Look at the glass. Let the bike roll softly back to its left side by straightening your elbows. Let go of the bike once it is securly set on it's side stand. Stand up. Your done!
Addicted to anything that has an engine and rolls. |
July 1st, 2009, 10:54 AM | #10 |
Manual says 1.7 quarts for oil and filter change. 1.4 for just oil.
July 1st, 2009, 02:29 PM | #11 |
I cheat and hold the camera low with the lcd screen rotated so I can see it
July 1st, 2009, 05:34 PM | #12 |
IC2(SW)
July 1st, 2009, 06:52 PM | #13 |
Join Date: Mar 2009 Motorcycle(s): '09 Ninja 250 Black Posts: A lot.
isn't 1 quart = 1 litre? Mom checked her conversion chart cause we only have litres on our oil containers and she said a litre was equal to a quart.
I'm not small, I'm fun sized |
July 1st, 2009, 06:56 PM | #14 |
It's close, but different enough to matter:
1 US quart = 0.946352946 liters (thanks, google conversions!)
July 1st, 2009, 07:00 PM | #15 |
Well close enough for me. I asked her to have an idea on how much oil i was gonna need. Another day or two riding and i'll be ready for my next oil change, going synthetic.
July 2nd, 2009, 05:10 AM | #16 |
You'll love the synthetic. I was shocked at how different the bike felt after changing.
July 2nd, 2009, 08:58 AM | #17 |
yeah I did the rotella T synthetic but I did over fill it so now I am debating if I should find somehw to take it out from the cap or loosen the drain bolt!
it is not that much I maybe put 2.2q in it |
July 2nd, 2009, 11:44 AM | #18 |
Duvi, you can just loosen the drain bolt to let some come back out, or you could use a long pipette like a turkey baster to take some back out of the top
July 2nd, 2009, 12:30 PM | #19 | |
July 7th, 2009, 08:19 AM | #20 | |
Join Date: Jun 2009 Motorcycle(s): Kawasaki Ninja 250R Posts: 50
wow... thank you so much bro HKr1... your information very useful for me..
www.anekaban.com Chemonk Modified Authorized Dealer in Bali The Best Body Kit Quality in Indonesia |
oil change question | ProdigyRacingLA | 2008 - 2012 Ninja 250R Tech Talk | 8 | April 19th, 2012 06:46 PM |
1st oil change 600 miles, 2qts too much? | dimeified | 2008 - 2012 Ninja 250R Tech Talk | 5 | August 18th, 2009 07:38 AM |
1st oil change - not so well. | dmonaco05 | 2008 - 2012 Ninja 250R Tech Talk | 24 | June 1st, 2009 07:57 PM |
Did 1st oil change--have questions | birdy | 2008 - 2012 Ninja 250R Tech Talk | 9 | March 19th, 2009 10:20 AM |
Oil change question | JCCJMM_ | 1986 - 2007 Ninja 250R Tech Talk | 4 | December 4th, 2008 05:38 PM |
