Old July 21st, 2009, 10:34 AM   #1
liltenatattoo
Motorcycle(s): 2008 blue 250r "KameSane"
dried out washer on windscreen?
I just noticed the other day my rubber washer that holds the windscreen bolts in, is all dried out and cracked. does anyone else have this problem?
I ordered a new windscreen, and now i have to order these rubber washers. The bike is a little over a year old. Does this happen often with rubber washers??
Can you guys check your bikes to see if this has happened to you?
liltenatattoo is offline   Reply With Quote
Old July 21st, 2009, 10:42 AM   #2
Sound Wave
Ramen Rider
Sound Wave's Avatar
yeah, the wellnuts are really junk on these bikes. if you see the diy by kkim on his windscreen install, you will see that his ripped too.
one of my windscreen ones ripped and i think 2 of my fairings ones also. as recommended by one of the members here, i bought some replacement m5 wellnuts, but haven't tried them to see if they are actually the correct ones.
Old July 21st, 2009, 12:44 PM   #3
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
I always armor-al all the rubber stuff to keep it from getting brittle (not tires or grips).
Old July 21st, 2009, 01:23 PM   #4
liltenatattoo
doesn't that stuff dry it out more eventually? is there anything else i can use to put on the rubber besides that? not a bad idea to lube it up.
Old July 22nd, 2009, 12:21 AM   #5
Nickds7
Nickds7's Avatar
If armor-al has carbolic acid in it, it will help the rubber from drying up and becoming brittle.
Nickds7 is offline   Reply With Quote
Old July 22nd, 2009, 10:05 AM   #6
MotoPsycho
Motorcycle(s): '08 Ninja 250
Yep, this has happened to me plenty of times. I ordered new ones the first time I removed my side fairings and they fell out. About the same time i was waiting for these well nuts to be shipped i discovered that all motorcycle dealerships have packs of them for sale. doh! go to a shop and pick up a bunch so you'll always have spares on hand.
MotoPsycho is offline   Reply With Quote
Old July 22nd, 2009, 10:09 AM   #7
tjkamper
tjkamper's Avatar
Armoral will help them out, but they are still really weak and can get ripped if not handled with finesse.
Old July 22nd, 2009, 11:42 AM   #8
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Welcome Matt!
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
washer preload forks eddiekay 2013 - 2017 Ninja 300 Tech Talk 2 July 22nd, 2014 09:55 AM
[kropotkin thinks...] - 2012 Magny Cours WSBK FP1 Results: Rea Fastest On Dried Track Ninjette Newsbot Motorcycling News 0 October 5th, 2012 04:20 AM
Mirror plastic washer?? cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 2 March 13th, 2012 01:28 PM
washer size for shimming iriemon General Motorcycling Discussion 6 December 17th, 2011 08:37 PM
missing a washer! seedanpaint 2008 - 2012 Ninja 250R Tech Talk 6 March 9th, 2009 03:17 PM
