Old October 15th, 2009, 03:08 PM   #1
min nin
Motorcycle(s): 2007 250r
New sprockets
I put new sprockets on my bike today.
Put 43-15. the bike only has 300 miles so i left the old chain on there.
This gave me 1000 rpm lower in top gear@ whatever speed. Its like having another gear, and it only took an hour
min nin is offline   Reply With Quote
Old October 15th, 2009, 03:12 PM   #2
Snake
Snake's Avatar
I put a 15T on the front and have enjoyed the "extra" gear ever since. Very good mod.
Old October 15th, 2009, 03:50 PM   #3
Well, not exactly. The new sprockets made your gearing 12.1% taller no matter what speed you're going. (15/14 * 45/43). But 1000 rpm difference is in the ball park for highway speeds; if you were turning around 8500 rpm before, it would be very close to 7500 rpm after the swap. (But if you were at half the speed, and only turning 4250 in top gear, it would only drop 500 rpm after the swap). Conversely, if you were up near redline before, the gearing switch would change 13k down to 11.6k or so, well over a 1000 RPM difference.
Old October 15th, 2009, 04:00 PM   #4
min nin
REDLINE? omg I only have 300 miles on it.
The tach is hard to read at night, could be off a little.
Old October 16th, 2009, 06:14 AM   #5
rockNroll
rockNroll's Avatar
Motorcycle(s): black
I was slapping redline all day long in the mountains one saturday. The day started with about 50 miles on the odo and ended with about 350. Don't be afraid... go ahead and goose that girl
Old October 16th, 2009, 01:34 PM   #6
nate-bama
North Alabama Mtn. ryder
nate-bama's Avatar
Motorcycle(s): 2006
i have the 15 and would like to go down in the back too..but it's so hilly around here i'm not sure yet.
QTRltrPWR
nate-bama is offline   Reply With Quote
Old October 16th, 2009, 03:04 PM   #7
iceman.kcmo
Motorcycle(s): 94 Ex250
How is the power? i like how zippy it is right now, but would like a little better milage. I mostly ride mine to work, which is mostly highway.
iceman.kcmo is offline   Reply With Quote
Old October 17th, 2009, 08:16 AM   #8
Snake
Snake's Avatar
The power is not adversly affected. I still have plenty of passing power.
Old October 17th, 2009, 06:37 PM   #9
M
Motorcycle(s): Ninja 250 x2, Ninja 650R
I have similar results. With a 15/44 setup, my RPMs at a true 80mph dropped from about 10,200 to 9,100. Also, first gear is a bit more usable.
M is offline   Reply With Quote
Old October 17th, 2009, 07:36 PM   #10
andrewexd
andrewexd's Avatar
Motorcycle(s): 07 GSXR600 (N250 sold :( )
does changing sprockets give you inaccurate miles on the odometer ? I've seen a few CL ads that say this.
andrewexd is offline   Reply With Quote
Old October 17th, 2009, 08:19 PM   #11
On most bikes yes, on the ninjette no. Our speedometer/odometer is driven off a sprocket on the front tire. Changing gearing from the motor to the driven wheel has no effect on how often the front tire turns compared to the engine.
Most modern motorcycles instead get the speedo/odo drive off of the transmission output, and in that case gearing changes do directly affect the accuracy of the gauges.
Old October 17th, 2009, 08:23 PM   #12
andrewexd
andrewexd's Avatar
I see, thanks
Old October 18th, 2009, 07:17 PM   #13
min nin
I changed sprockets to get lower engine speed, better mileage, and maybe longer engine life. If I get a little less power, it's not a problem.
I live in s.w. florida, so no fun hills or even roads with curves in them.
Old October 19th, 2009, 07:11 AM   #14
Snake
Snake's Avatar
Hills are not a problem for me. All you have to do is downshift and you have plenty of pulling power.
Old October 19th, 2009, 01:11 PM   #15
gistmarrs
Motorcycle(s): '07 250
I put on a 16T front just after I bought the bike. It made for much lower RPM at highway speeds. After swapping out to the stock tires with GT-501's, I put the 14T back on. The combination of the taller tires and larger sprocket, wasn't great. I had to feather the clutch way to much on take off.
gistmarrs is offline   Reply With Quote
Old October 19th, 2009, 02:21 PM   #16
Grn99Kawi
Grn99Kawi's Avatar
Motorcycle(s): 2000 Honda CBR600F4 (sold) 1999 Ninja 250 (sold)
I plan on swapping a 15T on mine in the spring. (keeping the 45 out back)
2000 Honda CBR600F4 Silver and Red
1999 Kawi Racing Green Ninja 250 sold
Grn99Kawi is offline   Reply With Quote
Old October 19th, 2009, 04:29 PM   #17
bobaab
bobaab's Avatar
Motorcycle(s): 2001 Kawasaki Ninja 250
That's what I did earlier this year and love it. I commuted a lot with my bike so going at a lower RPM at the same speed made my commute much more comfortable. With people going 70mph in the mornings, it sucked not wanting to keep up.
It still accelerates fine, but initially in first gear, the bike feels a tad slower. So...I just rev a bit more!
bobaab is offline   Reply With Quote
Old October 27th, 2009, 06:54 PM   #18
Grn99Kawi
Grn99Kawi's Avatar
I know that this is a subjective question, but how much slower does it feel with the 15/45 setup? Is it noticeable? Did you have to raise your launch slip rpm? Do you find that it needs noticeably more throttle to get moving?
Thanks,
Adam
Old October 27th, 2009, 06:58 PM   #19
bobaab
bobaab's Avatar
It's noticeable, but it's really not bad unless you're accelerating from a stop. Once you get going, it feels just the same. Once you get used to how it feels, you will probably barely remember how it used to feel with a 14T sprocket up front!
Old October 28th, 2009, 01:15 AM   #20
Even the "hard" break-in methods don't suggest doing that without a few oil changes thrown in there!
Old October 28th, 2009, 01:22 PM   #21
rockNroll
rockNroll's Avatar
Did you read what I quoted in that post? It was about him worrying about redlining with only 300 miles on the bike, nothing about oil changes. If it bothers you wondering, I drained and refilled the oil before that ride (no new filter).
Old May 28th, 2013, 07:48 AM   #22
kawaninja09
kawaninja09's Avatar
Motorcycle(s): 09 250r ninja
I read this add to see if i could solve a problem im having. I swapped the sprocket to 15t in the front and I was riding this weekend behind my buddy in his car and i told him to do the speed limit bc i thought my speedometer was off and it wasnt the weekend to be speeding so i followed him and it said i was doing 80 to keep up with hime but when we got to the house he said he put it on cruise at 65 and nothing more so why would i be off by like 15 mph???
kawaninja09 is offline   Reply With Quote
sprockets jcsalazar 2008 - 2012 Ninja 250R Tech Talk 10 July 29th, 2013 03:57 PM
Where to get sprockets? Graugaard 2008 - 2012 Ninja 250R Tech Talk 8 February 21st, 2013 07:38 PM
Sprockets, sprockets, ahhh sprockets?!?! shelei09 General Motorcycling Discussion 10 January 23rd, 2013 09:47 PM
how do my sprockets look reaperw 2008 - 2012 Ninja 250R Tech Talk 4 December 29th, 2011 10:20 AM
Sprockets again voodoomaster 1986 - 2007 Ninja 250R Farkles 13 April 8th, 2010 11:08 AM
