Old December 14th, 2011, 10:26 PM   #1
iriemon
iriemon's Avatar
washer size for shimming
i am in the Philippines and can't find the size washers needed to shim...i found one that is 3.16 i think he said and it is also thicker...would it be considered the same if i used 1 thicker sized washer as 2 of the thinner ones...i will try it but want to get opinions first..thanks
iriemon is offline   Reply With Quote
Old December 14th, 2011, 11:05 PM   #2
saxnbass
saxnbass's Avatar
Motorcycle(s): 2009 CBR600rr
#4 or 3mm, either is said to work. I used the #4s on my buddy's bike and will be using them to shim my bike on Friday as well.
saxnbass is offline   Reply With Quote
Old December 14th, 2011, 11:07 PM   #3
iriemon
iriemon's Avatar
also is 3mm the size of the hole?
edit:never mind about size of hole i saw it in other post...but still asking about if the washer i get is thicker...would putting one of each be safe and considered like putting two under each..thanks
Old December 14th, 2011, 11:43 PM   #4
saxnbass
saxnbass's Avatar
I'd google the thickness of a US #4 washer, then see how thick yours is and figure it out. You haven't even mentioned how thick your washers are, you just said they are thicker...
Old December 15th, 2011, 12:08 AM   #5
paulforaname
paulforaname's Avatar
Motorcycle(s): Ninja 250R
mate give me your address and I'll post some to you as I got about 40 in a pack and only used 4 ( 2 on each needle) , do you want brass or stainless? i used the brass one's. as brought a pack of each as wasn't sure which to use but as most carbies have brass internals thought id go that way.
P.S.
PM me with your address etc
paulforaname is offline   Reply With Quote
Old December 15th, 2011, 12:10 AM   #6
iriemon
iriemon's Avatar
i live in the philippines...otherwise that would be a great offer...not sure what cost would be to send it here...not sure how would refund the postage
Old December 17th, 2011, 08:37 PM   #7
paulforaname
Mate, i would just put in an envelope and might cost a dollar in postage..as would put a card in there with the shims taped to card. not worried about a dollar or 2 if i can help another ninja rider out.. If I'm ever over there one day you can buy me a beer..if you want me to send over just PM me your postal address..
[RoadRUNNER] - 2015 KTM RC390: Fun Size is the Best Size Ninjette Newsbot Motorcycling News 0 September 9th, 2014 03:01 AM
Brake Line Crush Washer Size indr 2008 - 2012 Ninja 250R Tech Talk 1 February 23rd, 2012 05:15 PM
Ninja 250R Crush Washer Size/Specs? ScorpionNinja 2008 - 2012 Ninja 250R Tech Talk 3 June 10th, 2011 11:26 AM
3mm washer for shimming?? cbowman78 2008 - 2012 Ninja 250R Tech Talk 9 October 7th, 2010 02:46 PM
WTT: Size S Synergy Heated Gloves for Size M like kind headshrink Items Wanted 0 March 26th, 2009 01:45 PM
