February 1st, 2018, 12:45 PM | #1 |
'07 250r header/exhaust
Hello,
Curious if anyone knows if the gen 2 ('08) headers/exhaust would fit on the gen 1 ('07). Trying to go 2 into 1. Thank you. |
February 1st, 2018, 01:09 PM | #2 |
Join Date: Feb 2016 Motorcycle(s): 2007 ninja 250, 14 ninja 300, 09 1125CR Posts: A lot.
MOTM - May '17
I know it been discussed before and from what i remember is that the header gap/distance between the to pipes going into the head are different. So short answer is no.
February 1st, 2018, 01:12 PM | #3 |
MOTM - May '17
Muzzy and area p exhaust use to make single side after market ones but now can only find used and were louder
February 1st, 2018, 02:58 PM | #4 |
It can be done, but you'll need to cut the header pipes off the collector as well as remove the H-pipe joint. Rotate the header pipes to fit different exhaust-port spacing. Weld back onto collector. Weld H-pipe joiner back in.
February 2nd, 2018, 05:13 AM | #5 |
Thank you.
what am i missing, 95 250R exhaust header bolt up questions (stock) | macantley | 1986 - 2007 Ninja 250R Tech Talk | 13 | May 19th, 2014 01:08 AM |
