October 3rd, 2011, 05:22 PM | #1 |
Front/Rear turn signals
Is it possible to use 2 rear blinkers as front blinkers?
From the looks of it, they seem to look identical but I don't know if there would be any problems internally. I'm not to knowledgeable about that stuff |
October 3rd, 2011, 05:50 PM | #2 |
Join Date: Nov 2010 Motorcycle(s): '09 250 Street, '09 250 Race, '13 300 Race Posts: A lot.
Never had a problem mixing rear/fronts. The only difference I've noticed is left versus the right. The color of the connector is different. One is grey and the other is black but they still work on either side.
CVMA #55 |
October 8th, 2011, 07:44 AM | #3 |
They can use the wires from the front signals too. It's very easy to switch. The actual blinkers withouth the wires are identical, you just have to flip them so that the drainage hole faces down (LR to RF, RR to LF)
October 8th, 2011, 07:51 AM | #4 |
Join Date: Dec 2010 Motorcycle(s): 2005 ninja 250 street fighter, 2008 street fighter ninja 500, 2001 nsr 125 Posts: 812
always supplement with the old hand/arm signals. i use them exclusively with brake taps. had too many folks telling me my blinker was on.
October 8th, 2011, 08:23 AM | #5 |
Ok cool
Found a set of rear blinkers at a junkyard and just wanted to make sure they would work for the front. Thanks for the replies |
Looking for 09 oem rear turn signal and front turn signals and tail fairings | mbbernas | Items Wanted | 1 | September 11th, 2013 10:48 AM |
Rear turn signals don't blink, front turn signals don't turn on | andyuc88 | 2008 - 2012 Ninja 250R Tech Talk | 3 | March 23rd, 2012 02:47 PM |
07 turn signals, OEM front and rear identical? | davidemartindale | 1986 - 2007 Ninja 250R Farkles | 4 | September 16th, 2011 11:56 PM |
2008 ninja 250r turn signals rear - front | jorgecornet | 2008 - 2012 Ninja 250R Tech Talk | 8 | October 18th, 2009 07:14 PM |
