Old May 18th, 2011, 05:27 PM   #1
play2pwn
Only the good die young
Motorcycle(s): 2011 ninja 250r SE
Wind screen bolts?
So I lost one of my windscreen bolts and bought the spiked wind screen bolts
The screws at the top were exact match but at the bottom ones they came up short?
Was wondering if removing the front fairing and putting the nuts with the rubber will make it fit.
play2pwn is offline   Reply With Quote
Old May 19th, 2011, 03:53 AM   #2
Try it and see?
Old May 19th, 2011, 05:00 PM   #3
nattygirl
nattygirl's Avatar
Motorcycle(s): 2010 Kawasaki Ninja EX250 Special Edition Red/Black
It should work just fine. I bought some colored ones off ebay and ran into the same issue. I had to take the front end off and secure the bottom bolts first before putting the fairing back on and then I did the top ones after everything back on.
'10 Ninja 250R SE Red/Blk
Mods: Projekt D FE, Protons, HB Blk Windscreen, HIDs, TBR Blk Series Slip-On, Shogun Sliders, Solo Cowl, Integrated Tail Light, Gls Blk Rear Fender, Red Accents
nattygirl is offline   Reply With Quote
Old May 19th, 2011, 10:48 PM   #4
play2pwn
So you remove the fairing and screw it from the inside?
I might do it this saturday and see, lol
I got the yana shiki ones
Old May 20th, 2011, 12:40 PM   #5
nattygirl
nattygirl's Avatar
Not from the inside. It screws the same way it would as if it were on the bike. The problem is that the screw isn't long enough to reach the rubber wellnut that it screws into, so you have to give it a little help so it can catch by pushing in the rubber wellnet so the threading is closer to the fairing. Sounds weird, but you'll see what I mean when its taken off.
2009 Stock Wind Screen Mjj Free stuff! 5 December 23rd, 2013 01:08 PM
DIY Painted wind screen Kitdog 2008 - 2012 Ninja 250R Farkles 43 May 28th, 2013 08:18 PM
Rear Hugger and Wind Screen akima General Motorcycling Discussion 17 June 24th, 2012 08:08 AM
Home made wind screen Mr Quality 1986 - 2007 Ninja 250R Farkles 5 November 9th, 2009 09:47 AM
WTB: OEM Wind Screen 00v_Lucky Items Wanted 3 June 25th, 2009 10:05 PM
