Old May 7th, 2014, 04:34 PM   #1
dwright0723
Motorcycle(s): 08 Ninja 250
Rear Brake Bleeding Trouble
Howdy! I'm having some issues with my rear brake! I bleed it, and it stays firm for a little bit, then slowly looses pressure again to where I have to push the rear brake lever all the way down for it to work. I bleed it again, and it works for a bit and the pedal again gets lower and lower. It's done this several times. I'm not losing any fluid at all. Any ideas as to what going on here?
dwright0723 is offline   Reply With Quote
Old May 7th, 2014, 05:01 PM   #2
sonny4472
sonny4472's Avatar
Motorcycle(s): 09 250r, 09 1125r, 95 Virago
Still has air in the line.
sonny4472 is offline   Reply With Quote
Old May 7th, 2014, 06:04 PM   #3
C-Bass
C-Bass's Avatar
Motorcycle(s): Currently own: 98 Honda VTR1000, 02 Suzuki's DR200 & DR650, 04 & 08 BUSA's, 05 Ducati SS1000, 12 Ninja 250R SE
I have just developed the exact same problem on my bike!
I did the bleed thing, but haven't fixed it. More thought required....
C-Bass is offline   Reply With Quote
Old May 7th, 2014, 06:11 PM   #4
sonny4472
sonny4472's Avatar
Did either of you replace your lines? Sometimes it takes more than you would think to completely bleed a system.
I prefer to use a sealed bleeder tube full of brake fluid. Sometimes you can still pull more air into the system while you are bleeding.
If you aren't leaking any fluid than you can assume it's something else.
As time goes on, using the brake system will actually compress the air and push it to the pistons. This feels like the brakes are getting squishier with use.
I hope I explained that ok...
Old May 7th, 2014, 06:12 PM   #5
mgentz
Board Member
Junk in the threads or air in the line. Pull the blender out all the way and clean both the caliper and the bleeder.
Old May 7th, 2014, 06:16 PM   #6
dwright0723
Nope, haven't replaced lines. I've been using a bleeder bottle with fluid in it as well.. pump it up, open the bleeder, repeat till no more bubbles... Starting to get into a habit of not using the rear brakes..
Old May 7th, 2014, 06:18 PM   #7
dwright0723
Alright, I'll have to try this..
Old May 7th, 2014, 06:23 PM   #8
sonny4472
sonny4472's Avatar
Hmm, I'm now wondering about mileage. The brake line could be overly soft and relieving pressure.
BTW, Sport bikes have rear brakes?!
Old May 7th, 2014, 06:26 PM   #9
dwright0723
I have like 3k miles.. lol you don't use your rears?
Old May 7th, 2014, 06:28 PM   #10
C-Bass
C-Bass's Avatar
My bike is new, only 500 miles on it. And no loss of brake fluid.....wtf??
Old May 7th, 2014, 06:36 PM   #11
sonny4472
sonny4472's Avatar
I bet you two have two different issues.
This is what I would do:
Drain the entire system, check the brake line, stainless is always nice if it needs to be replaced.
Pull the caliper, pull pistons clean and lube everything (including bleeder and passageway)
Re assemble and refill, re bleed.
It's a super simple system, shouldn't be difficult to fix.
No, I use my rear brake, but only in emergency stops, gravel and maybe really wet weather. It's just a matter of preference for me.
* I replaced my rear pads on a bike at 30k miles just cause I felt like it.
EDIT
Check to make sure your fittings are all tight. Also your reservoir cap, just to make sure no air is being pulled in.
Last futzed with by sonny4472; May 7th, 2014 at 06:39 PM. Reason: I think slow.
Old May 7th, 2014, 06:48 PM   #12
C-Bass
C-Bass's Avatar
Air has gotten into the system on mine somehow - checking all the fittings for tightness is a good suggestion - thanks!
Old May 7th, 2014, 06:57 PM   #13
dwright0723
EDIT
Yeah, it looks like a super simple system. Thats why I'm so stuck lol.. Ill take it apart tomorrow and lube..
Lol at 30k miles?! wow! I don't feel as bad not using them now
Old May 7th, 2014, 07:02 PM   #14
sonny4472
sonny4472's Avatar
It's a matter of preference that could probably start a whole posting war, but I'm not new enough or advanced enough to really have a use for the rear brake.
Oh, to clarify something I worded stupidly earlier; don't lube the bleeder or passages, I just kinda stuck all that in one sentence. Just lube the pistons.
EDIT
https://www.ninjette.org/forums/showthread.php?t=147436
This DIY covers a lot of good angles.
Last futzed with by sonny4472; May 7th, 2014 at 07:08 PM. Reason: Lorazepam makes me slow
Old May 7th, 2014, 07:26 PM   #15
dwright0723
Got ya! Thanks for the link!
Rear Brake Light Trouble Devita818 2008 - 2012 Ninja 250R Tech Talk 16 April 18th, 2015 07:50 PM
Brake bleeding bliss Gurk General Motorcycling Discussion 6 July 2nd, 2014 08:35 PM
Brake Bleeding Question kennetht 2008 - 2012 Ninja 250R Tech Talk 16 March 4th, 2014 10:55 AM
Bleeding brake ? caineroad 2008 - 2012 Ninja 250R Tech Talk 3 September 24th, 2013 02:53 PM
Rear Brake Bleeding Problem (2011 Ninja 250) - Caliper Valve Sucks Back Fluid/Air MovingUp7 2008 - 2012 Ninja 250R Tech Talk 3 January 28th, 2013 08:46 AM
