September 4th, 2011, 04:12 PM | #1 |
exhaust/jetting qestion
Hey guys,
I wanted to know. If I put on a slip on exhaust. Put a k&n airfilter in it and removed the snorkle would I have to rejet the carbs? Or can i get away with shimming? Thanks. |
September 4th, 2011, 06:19 PM | #2 |
you should get a full pipe and remove the airbox and replace it with pod filters, then rejet it
September 4th, 2011, 06:36 PM | #3 |
Join Date: May 2009 Motorcycle(s): 2008 Kawasaki Ninja 250R, 2009 KTM 690 SMC, 2001 Suzuki GSX-R 750 (track bike) Posts: 172
You can get away with shimming, but it won't be perfect. You'd be better served by rejetting.
September 4th, 2011, 06:42 PM | #4 |
September 4th, 2011, 08:21 PM | #5 |
airbox delete helps... its not a ton of work to jet http://www.factorypro.com/tech_tunin...m_engines.html
September 4th, 2011, 09:20 PM | #6 | |
September 5th, 2011, 07:41 AM | #8 |
Ridin Dirty
Join Date: Jun 2011 Motorcycle(s): 2011 white se 250r , 2008 zx6R Posts: 921
+1
#1 |
September 5th, 2011, 09:11 AM | #9 |
Milkshake Drinker
Join Date: Aug 2011 Motorcycle(s): 2007 Orange DRZ400-S, 2005 Ninja 250 & Custom Thundercunt Dirt Chopper Posts: A lot.
I mean no disrespect, but I've never seen a forum where so many people want to spend hundreds of dollars on a new exhaust, and then desperately want to avoid spending $5 on new jets. It really baffles me.
"What a sweetheart."- ninja_sleeper to me |
September 5th, 2011, 09:19 AM | #10 |
Ridin Dirty
i think its more the technical aspect involved with jetting for most as oppsoed to exhaust which seems to most who have never done it to just unbolt the old and put the new on..which jetting is easy, its just a little time consuming pulling the panels off to get to the carb. on a side note, removing the airbox and doing pod filters makes changing jets quite easy, all i need to remove is the side panels under the seat and the seat itself to pull my carbs out
#1 |
September 5th, 2011, 09:22 AM | #11 | |
Milkshake Drinker
Almost all the performance gains come from rejetting, so I guess I just don't see the point of an exhaust without rejetting.
September 5th, 2011, 09:30 AM | #12 |
Ridin Dirty
to someone who knows how to rejet this is true, but if youve never rejetted a bike before exhausts just seem way easier..lol! im with you though, changing jets is not difficult at all.
#1 |
September 5th, 2011, 11:15 AM | #14 |
earplugs when you ride make riding so much more pleasant
September 5th, 2011, 11:36 AM | #15 |
Because jets arnt 5 dollars. Jets are between 70 and 100 dollars depending on if you go dyno jett factoruy pro or area ps
September 5th, 2011, 11:41 AM | #16 |
Jet kits are $70 - $100. Skippii's point has always been that the kits are a waste of money, as the individual jets are quite cheap if you know what you need.
September 5th, 2011, 12:03 PM | #17 | |
Correct. I prefer to use individual jets since they are quite a bit cheaper. I will stress that buying genuine Keihin or Mikuni jets is a must. |
September 5th, 2011, 01:12 PM | #18 |
Ridin Dirty
Jetsrus.com they are actually right about $5 each lol, then you buy the pack of washers to shim the needles at radioshack for like $3 .
#1 |
September 5th, 2011, 01:23 PM | #19 |
but to answer the OP's question, if you want to get a slipon, and remove the snorkel, shimming should be sufficient.
but jetting really isnt that bad. The hard part is getting the carbs OFF the airbox and then getting them back on. jetting really just takes patience, some mechanical aptitude, and lots of test-riding |
September 5th, 2011, 01:51 PM | #21 |
yes I can imagine it would be but the OP only mentioned removing the snorkel and changing the filter
I'm actually considering the airbox delete, but every time i go to order parts I think about how long it will take me to hack it out and then rejet and get it all running to the same point I have it at now. Really all i want to do is ride my bike, not work on it. Besides, I already spent time tuning my carbs for my setup now. I don't want to do it all again... |
September 5th, 2011, 02:14 PM | #22 |
i need to convince cuong to tune my fzr... i hear he's the master of carburetors. you might even call him the masterburetor...
Help with jetting and/or exhaust | 2weelz | 1986 - 2007 Ninja 250R Tech Talk | 4 | April 9th, 2014 03:46 AM |
exhaust + jetting? | jmk420 | 2008 - 2012 Ninja 250R Tech Talk | 35 | June 23rd, 2013 08:33 PM |
Full exhaust + airbox mod = how hi maintenance are the carbs/jetting? | 675Raisinator | 2008 - 2012 Ninja 250R Tech Talk | 14 | December 27th, 2011 12:05 PM |
Dyno Charts with jetting and stock exhaust? | KURT | 2008 - 2012 Ninja 250R Tech Talk | 5 | February 27th, 2011 10:03 AM |
08 250R Dyno / after full exhaust + jetting | Order | Videos | 20 | January 19th, 2011 11:12 PM |
