February 15th, 2015, 05:14 PM | #1 |
Winging It In Life
Join Date: Aug 2011 Motorcycle(s): 2010 250R; 2011 250R (sold) Posts: A lot.
Changed Spark Plugs; Right Side Boot Won't Snap In Easily
I just changed out my spark plugs. The spark plug boot on the left side (clutch side) snapped into place perfectly with a little effort.
The right side (throttle side)? Nope. The boot is in, but it doesn't seem to want to go in all the way. I can still easily pull it out with very little effort. What can I do here? I have tried pushing it in with as much force as possible to no avail. I know the spark plug isn't sitting improperly. Can I just leave it be? It's not in all the way (obligatory "that's what he said"), but the boot is in. P.S: I did this with the tank in place. Edit: Pics Pointing at which spark plug boot I'm referencing: Notice the difference? Left one sits more flush than right one. |
February 15th, 2015, 05:22 PM | #2 |
Did you remove the adapter tip on the spark plug? If you didn't then you can just unscrew the cap end off the spark plug.
February 15th, 2015, 05:34 PM | #3 | |
Winging It In Life
In the How To videos I watched, they didn't mention this at all. |
February 15th, 2015, 05:36 PM | #4 |
Join Date: Jun 2012 Motorcycle(s): 2013 Ninja 300 Posts: 718
Have you tried placing the left spark plug boot on the right spark plug? If it fits, it might be a problem with the boot. If it doesn't, it could be a problem with the plug.
DISCLAIMER: I generally have no idea what I'm talking about. |
February 15th, 2015, 05:40 PM | #5 |
Winging It In Life
No. I'm short on time now, so I'll have to try this tomorrow. Need to be at work in an hour.
February 15th, 2015, 06:10 PM | #6 |
Winging It In Life
Would it be okay to ride the bike with that boot sticking out just slightly? Or do you guys think I'd be risking something mechanically catastrophic happening to the bike?
February 15th, 2015, 07:53 PM | #7 | |
https://www.ngk.com/glossary/8/spark-plug/R NGK calls it a removable terminal nut
February 15th, 2015, 08:19 PM | #8 | |
Winging It In Life
I'll update in the AM. |
February 16th, 2015, 10:09 AM | #9 |
Winging It In Life
Got the boot in tight.
My spark plugs didn't have the terminal nut you were referencing, @cuong-nutz. I pushed the boot in when I got home and it fit snuggly. I don't know what I did differently today other than not being frustrated, so maybe that was it. |
spark plugs | jcsalazar | 2008 - 2012 Ninja 250R Tech Talk | 11 | May 17th, 2015 08:44 AM |
Removing spark spark plugs? | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 26th, 2013 03:48 PM |
Changed spark plugs - idles lower with choke | ajnin | 2008 - 2012 Ninja 250R Tech Talk | 1 | August 2nd, 2011 10:16 AM |
changed battery n plugs started right up 5 min latter won't do anything? | Bostonninjabastard | 1986 - 2007 Ninja 250R Tech Talk | 11 | May 3rd, 2010 08:35 AM |
Changed plugs, bike won't idle.. | pixelpete | 1986 - 2007 Ninja 250R Tech Talk | 9 | April 20th, 2010 11:22 AM |
