December 12th, 2013, 04:19 PM | #1 |
Join Date: Sep 2013 Motorcycle(s): '06 Kawasaki Ninja 500 Posts: 71
petcock question.
I recently did a rebuild on my petcock got the k&l kit off eBay. When i was replacing the diaphragm I dropped the plastic spacer that the diaphragm sit in. When i went to put the new one on I noticed that the plastic piece had a flat side Anderson a side with a circular indent. Does anyone know what side the plunger is supposed to be pressed against? The flat side or the circular indent side?
Just so everyone knows this question is referring to an ex500 not the 250. I asked this same question at the ex500 forum site but know one wants to answer me since I called fog a douchebag. Thanks for any help if you can give any. |
December 12th, 2013, 07:44 PM | #2 |
Board Member
Well I don't like fog either but there is no reason for name calling...
Have you tried looking at the parts diagram or the thread on here about petcock rebuilding? |
December 12th, 2013, 07:54 PM | #3 | |
No I haven't thought about looking at a parts diagram that's probably a good idea, thanks I will check it out to see. |
December 12th, 2013, 08:08 PM | #4 |
Just checked the 250 wiki and even though the petcock on the 250 is a little different than the 500, I believe I seen that the washer side of the diaphragm sits against the circular indent. I know it sounds stupid but I had no reference points from the 500 wiki, no one really went in-depth like someone did on the 250 wiki. Thank you mgentz for the advice, tomorrow I will make sure I put it in properly.
Rebuilding the petcock and have a question. | 93etgocart | 2008 - 2012 Ninja 250R Tech Talk | 15 | April 3rd, 2015 06:01 PM |
Petcock / Fuel Tap question | pdxdavid | 2008 - 2012 Ninja 250R Tech Talk | 9 | October 9th, 2013 08:28 PM |
Petcock Question | az3200 | 1986 - 2007 Ninja 250R Tech Talk | 3 | June 3rd, 2013 06:25 PM |
removing gas tank - petcock question | james250ninja | 2008 - 2012 Ninja 250R Tech Talk | 5 | August 25th, 2011 11:23 AM |
petcock question | Realirony | 2008 - 2012 Ninja 250R Tech Talk | 6 | March 9th, 2009 11:55 AM |
