Old June 1st, 2011, 10:32 PM   #1
mohns6062
Motorcycle(s): Kawasaki ZZR 250
Idle fluctuates
Just got the bike back together and a while after start up the idle will rise without any assistance from the user and it will only drop once given a quick twist of the throttle. It idles fine after start up at about 2000 RPM and will rise up to 3000 RPM where it will sit, it seems, until a bit of throttle is given, then it will drop below 2000 and come back up.
Any suggestions on the problem?
Background on the bike: Just finished adjusting the valves/ replacing the cam chain/ cleaning the carbs (put back together properly).
mohns6062 is offline   Reply With Quote
Old June 1st, 2011, 11:22 PM   #2
make sure all the clamps are tight and/or you didn't overlook a vacuum hose being loose or leaking.
Idle issues - Idle is different every time I start up. 106 1986 - 2007 Ninja 250R Tech Talk 6 November 13th, 2014 04:57 PM
what should i idle at EvilPooMonkey 2008 - 2012 Ninja 250R Tech Talk 7 July 8th, 2012 03:00 PM
Idle jumps to 9000 rpm on choke then wont stay idle after off Shawn250 2008 - 2012 Ninja 250R Tech Talk 1 June 19th, 2012 06:45 AM
Idle problem cgborders 1986 - 2007 Ninja 250R Tech Talk 4 May 19th, 2012 12:58 PM
Idle Question THE BIG SITT 2008 - 2012 Ninja 250R Tech Talk 22 October 29th, 2011 07:15 AM
