November 2nd, 2011, 06:59 PM | #1 |
Perpetual Newb
Join Date: Mar 2011 Motorcycle(s): 2010 MIB Ninja 250R [sold]; 2006 CBR600RR [sold]; 2013 Triumph Street Triple R Posts: 782
Clutch doesn't fully disengage power when pulled in.
I was adjusting my chain tension tonight and while the bike was up on stands, after I'd tightened everything back up and lubed up the chain, for one reason or another I started up the bike - still on the stands, in nuetral, kickstand down - and got a hair up my keister and hopped on the bike, put up the kickstand and put it in first gear. Clutch was obviously pulled in at the time but I was freaked out when I noticed that, while the bike's in first gear with the clutch lever pulled against the hand grip (to cut power to the rear wheel), the rear wheel was moving under power.
Shifted back to nuetral and it stopped spinning. Got off the bike, clutch lever squeezed all the way, shifted the bike into first gear and the wheel started spinning again. I was able to stop the spinning with one hand holding the clutch lever in and using my foot to stop the tire with some force (not the brightest thing to do, but I was curious how much power was getting to that rear tire) but as soon as lifted my foot off it'd start spinning again. I let go of the clutch lever completely, to fully engage the engine's power to the rear wheel and this time was unable to stop the wheel, I could slow it, but not stop it (didn't do it for long at all, afraid of damaging the transmission). Took the bike off the stands and so the weight of the bike (and me) were on the tire and with the bike running, in first gear, clutch lever pulled in all the way, the bike wouldn't move. My weight + the bike was enough to keep it from rolling. With this same setup, except with me standing next to the bike so as to remove my weight from the rear tire it wouldn't roll but it sure seemed like it just barely wasn't going to roll. I didn't have much play in the clutch lever to begin with but I took what little slack there was in the clutch lever out. Also used the steps in the shop manual for pulling the slack out where it attaches down at the bottom/side of the engine and it still spins. I have no idea if it's always been this way or what as this was the first time I've ever decided to do this. The more I think about it I'm concerned about what kind of damage I may be inadvertently causing to the engine/transmission when I'm stopped at a light in 1st gear, clutch pulled in all the way but with a bit of power still trying to spin that back tire. Luckily, it's still under warranty so if need be I can take it to the dealership to get checked out but if it's something simple enough I'd just assume fix it myself. Any suggestions? |
November 2nd, 2011, 07:15 PM | #2 |
It doesn't sound like there is anything wrong with it. Its just the way wet clutches work.
November 2nd, 2011, 07:37 PM | #3 |
nothing wrong with your bike
http://sandollarmotorcycleclub.com/ |
November 2nd, 2011, 10:32 PM | #5 |
That rider dude.
Join Date: Apr 2011 Motorcycle(s): 2011 White Ninja 250 SE. Posts: A lot.
From what I understand, and please someone correct me if I am wrong, even when the clutch is pulled fully in, there's always a little power going to the rear wheel. The engine is never fully 100% disengaged from the engine when in gear. It'll move a little. When you sit on it, if it doesnt pull you forward and you can still rock and what not, I'm sure you're fine and its normal.
In fact, im about 99% sure it's normal and that there's always a little power being put in.
Mods: flushmount Led front binkers, diode mod, pazzo levers, clear tank pad, racing replica grips, bike monkeys integrated tal light, zx-2r vinyls, rearsets, red bar ends, and more red accented stuff. |
November 2nd, 2011, 11:58 PM | #6 |
Normal.
November 3rd, 2011, 04:34 AM | #7 |
Perpetual Newb
So what you're all saying is that it sounds like the clutch/tranny has some serious problems and will most likely need to be replaced? Am I right? Just want to make sure I didn't miss anything.
Thanks guys. Glad that it's normal. Feel like an absolute moron now, but I'm glad to know there's nothing actually wrong with the bike. |
November 3rd, 2011, 06:40 AM | #8 |
While the Ninja 250 is not maintenance free, it will give you a lot of miles of trouble free service if you stick to the factory required maintenance schedule.
The only problem I'm aware of with the clutch is on the pregen (not sure about the newgen) the clutch basket rattles and causes the bike to make a ticking sound at idle. Harmless, but can be annoying.
November 3rd, 2011, 06:58 AM | #9 |
Join Date: Oct 2011 Motorcycle(s): 1999 Kawasaki ZRX1100, 2006 Yamaha R1, 2006 Kawasaki ZZR600, 2009 Kawasaki Ninja 250R, 2017 Kawasaki Z900 Posts: 320
Every bike I've owned spun the rear wheel when running in neutral on a stand. Especially when it was cold.
November 3rd, 2011, 09:14 AM | #10 |
Smoker
Normal, now put that slack back in your clutch cable before you toast your clutch plates.
November 3rd, 2011, 10:09 AM | #11 |
Perpetual Newb
November 3rd, 2011, 10:11 AM | #12 |
whew
Clutch Won't Disengage | Gmon | 1986 - 2007 Ninja 250R Tech Talk | 21 | September 23rd, 2019 09:31 PM |
Clutch issues. Won't disengage, searched, tried, help | mr2peak | 1986 - 2007 Ninja 250R Tech Talk | 21 | May 5th, 2014 04:32 PM |
bike dies with clutch pulled in slowing down | robertkh100 | 2013 - 2017 Ninja 300 Tech Talk | 62 | December 24th, 2013 06:16 AM |
Another Clutch Issue...Cannot Disengage! | Littlefreak | 1986 - 2007 Ninja 250R Tech Talk | 8 | March 13th, 2011 09:15 PM |
Improperly disengage clutch ~ revs high, lower speed. | Ntotot | 2008 - 2012 Ninja 250R Tech Talk | 12 | August 26th, 2009 10:48 PM |
