Old November 23rd, 2013, 03:20 PM   #1
CrossProduct
Mirror mounting holes
Hi - another question about a recently-acquired 2007 Ninja 250R. The bike came without mirrors, so I got a pair of aftermarket ones which are supposed to fit. The weird thing is that what seem like the obvious mounting holes to use on the bike don't seem to line up: on both sides, if I remove the rubber seal and look through the mirror holes in the front fairing, I can see what look like corresponding holes (two arranged vertically on each side) on the main body of the bike. But these seem to be too far "inward" (i.e. towards the centerline of the bike) and so don't really overlap with the fairing holes - I can see them, but I don't think I could get a screw through the fairing hole and into them.
I assume I'm doing something stupid, since the fairing (while a bit damaged) looks to be on ok and in the right place, judging by its position around the headlight, but I can't figure out what. Could there be a part missing? Thanks in advance for any suggestions.
Last futzed with by CrossProduct; November 23rd, 2013 at 04:23 PM.
CrossProduct is offline   Reply With Quote
Old November 24th, 2013, 01:25 PM   #2
baxtc1
baxtc1's Avatar
Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50.
The two holes on each side, one is threaded for the bolt, the other is for the locating pin. If the fairing has been damaged, there is a fair chance the frame for the speedo/mirror/fairing mout is bent.
You could try to straighten it, in my case, I just bought a second hand one.
Good luck.
baxtc1 is offline   Reply With Quote
Old December 10th, 2013, 05:44 PM   #3
Lychee
sail away
Lychee's Avatar
The fairing stay is bent. Break it out and man handle it to the right spot. It may never mount perfectly again though. You may have to push the fairing one way in order to mount the mirror.
Old December 10th, 2013, 05:52 PM   #4
nice name. can you do Dot products as well?
Old December 10th, 2013, 07:26 PM   #5
I feel like this may be a case of right twix vs left twix.
[RoadRUNNER] - Pot Holes, Sink Holes, and Buckled Roads Ninjette Newsbot Motorcycling News 0 August 26th, 2014 03:01 AM
Damaged left footrest stay mounting holes mgorven 2008 - 2012 Ninja 250R Tech Talk 17 February 9th, 2014 11:59 AM
What are these holes? Madman44 General Motorcycling Discussion 17 August 14th, 2012 02:33 PM
What are these holes?? Cuongism 2008 - 2012 Ninja 250R Tech Talk 5 August 24th, 2010 04:58 PM
Exhaust: anyone drill 5-6 holes? ScorpionNinja 2008 - 2012 Ninja 250R Farkles 12 August 3rd, 2009 05:19 AM
