December 5th, 2013, 07:50 PM | #1 |
Join Date: Dec 2013 Motorcycle(s): 2007 Ninja 250 "sold" 2014 ninja 300 "Gold" 2000 DRZ400S (Sold the POS) K7 GSXR600 (Also POS...see a pattern? Posts: 207
Leaky carb bowl?
Hey guys I have a 2007 ninja just picked up a few weeks ago and when I put fresh fuel in her (she had been sitting a while with the previous owner) I started smelling gas. it appears that it is coming from the seal around the carburator bowl. Is this a common problem after this bike has been sitting for a while and any easy cheap fixes?
Thanks a ton |
December 6th, 2013, 06:40 AM | #2 |
Join Date: Apr 2013 Motorcycle(s): 2005 Ninja 250, 2006 SV650N Posts: 642
Yeah the gaskets go bad over time. Make sure the petcock isn't bad as well because I had a similar problem and it ended up being the seals on petcock had gone bad.
December 6th, 2013, 11:32 AM | #3 |
I did take the tank off to check the petcock and didn't get any leaks while it was off. I guess it sounds like I need a few seals
December 6th, 2013, 11:45 AM | #4 |
So I took the carb bowls out and the seals were pretty dry, I used just a touch of oil on them and re positioned them in the seat. I just checked a little bit ago and there is no gas smell and no visible dampness ^_^
The process was quite a bit easier then expected using you guide on carberator removal. |
December 6th, 2013, 12:14 PM | #5 | |
At this point you most likely don't have any fuel in the floatbowls unless you've run it. It takes vacuum (or turning the petcock to "prime" if you have it) to get fuel to flow. When the fuel is at the proper level it shouldn't be high enough to run out of the bowl gasket area. It would only leak a significant amount of fuel out of the gasket if the needle and seat were not sealing completely or the float level is set too high. |
December 6th, 2013, 01:59 PM | #6 |
Turn the petcock to ON with the bike off and see if it leaks. If it leaks then it's bad. It's only supposed to let out gas when vacuum is applied which means the bike would have to be on. If it doesn't leak then it's not the petcock so that would leave the carbs. Check float level and and replace gasket(s) on whatever side is leaking.
December 6th, 2013, 03:19 PM | #7 | |
December 6th, 2013, 03:24 PM | #8 | |
December 7th, 2013, 04:09 PM | #9 |
Join Date: Oct 2010 Motorcycle(s): '02 Ninja 250, '98 Triumph Sprint 900, '69 H-D Sportster XLCH 900 Posts: 80
Those bowl gaskets ain't cheap. My local dealer hosed me $12 for a pair just last year.
j98sprint |
December 7th, 2013, 09:02 PM | #10 |
Oh that sucks, well luckily I don't have any leaks now so something went right for me. Thanks a ton for the help. here is to many happy days riding!
Leaky Tank Fix | mjegan | 1986 - 2007 Ninja 250R Tech Talk | 5 | April 20th, 2013 04:13 PM |
Leaky petcock | Cuongism | 2008 - 2012 Ninja 250R Tech Talk | 4 | August 18th, 2011 07:31 AM |
Leaky brake fluid reservoir - What now? | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 11 | June 25th, 2011 08:50 PM |
Carb - leaky float valve questions | ako | 1986 - 2007 Ninja 250R Tech Talk | 34 | June 15th, 2011 10:04 AM |
Leaky Front Brake Reservoir | NicoleH28 | 2008 - 2012 Ninja 250R Tech Talk | 26 | June 3rd, 2011 09:26 AM |
