Old July 24th, 2013, 07:49 AM   #1
Solunatic
Solunatic's Avatar
Motorcycle(s): 1990 Ninja 250 "Jolene"
exhaust leak
So the fitting where my right exhaust can attaches to the headers is loose, and it seems I cannot tighten the clamp enough to secure it.
Will I need to buy another exhaust clamp? Is there some sort of sealant that should have been reapplied when i put the can back on?
I also have a slightly rough idle that didn't go away with a clean, rebuild, synch and mixture adjust, could this be the source of that problem? I know just about squat about post combustion issues and how they could affect the system.
Solunatic is offline   Reply With Quote
Old July 26th, 2013, 04:29 AM   #2
n4mwd
n4mwd's Avatar
There should be a bushing inside the pipe. Check to make sure its still there.
Since the Ninja is a highly tuned engine, any change to the exhaust or intake flow will affect the engine performance. So yes, its possible that an exhaust leak could cause a problem.
My Ninja Blog
Exhaust leak on the right side Sirref 1986 - 2007 Ninja 250R Tech Talk 9 December 14th, 2014 08:01 PM
Worst Exhaust Leak Ever MarcoPolo 2008 - 2012 Ninja 250R Tech Talk 3 April 19th, 2014 10:13 PM
Exhaust leak chikenstrips 2008 - 2012 Ninja 250R Tech Talk 11 April 30th, 2012 09:22 AM
How much popping? (and exhaust leak) singlecoillover 2008 - 2012 Ninja 250R Tech Talk 30 May 30th, 2011 08:35 PM
Exhaust Leak Betlog 2008 - 2012 Ninja 250R Tech Talk 3 April 24th, 2010 10:27 PM
